I’m using ESP32 Gateway revision F with a custom board file (just to enable revision F) and I want to enable PSRAM. I added -DBOARD_HAS_PSRAM and -mfix-esp32-psram-cache-issue inside platformio but when I call ESP.getFreePsram() it returns 0.
What should I do?
platformio.ini
[env:esp32-gateway]
board = esp32-gateway-rev-f
-DBOARD_HAS_PSRAM
monitor_speed = 256000
monitor_filters = time, log2file, esp32_exception_decoder, default
boards/esp32-gateway-rev-f.json
“build”: {
“arduino”:{
“ldscript”: “esp32_out.ld”
“core”: “esp32”,
“extra_flags”: “-DARDUINO_ESP32_GATEWAY=70”,
“f_cpu”: “240000000L”,
“f_flash”: “40000000L”,
“flash_mode”: “dio”,
“mcu”: “esp32”,
“variant”: “esp32-gateway”
“connectivity”: [
“wifi”,
“bluetooth”,
“ethernet”,
“can”
“debug”: {
“openocd_board”: “esp-wroom-32.cfg”
“frameworks”: [
“arduino”,
“espidf”
“name”: “OLIMEX ESP32-GATEWAY”,
“upload”: {
“flash_size”: “4MB”,
“maximum_ram_size”: 327680,
“maximum_size”: 4194304,
“require_upload_port”: true,
“speed”: 460800
“url”: “ESP32-GATEWAY - Open Source Hardware Board”,
“vendor”: “OLIMEX”
Thank you.
