Hello, I recently started experimenting with FreeRTOS on the ESP32, I haven’t been able to run this simple program succesfully:
#include <freertos/FreeRTOS.h>
void test_service(void *pvParams)
while (1)
Serial.println("This is a test");
vTaskDelay(10 / portTICK_PERIOD_MS);
void setup()
Serial.begin(9600);
while (!Serial)
xTaskCreate(test_service,
"TEST",
2048,
NULL,
1,
NULL);
vTaskStartScheduler();
void loop() {}
Here’s my platformio.ini file:
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
Whenever I use PlatformIO to compile, upload and run this program, it crashes. Here’s the stack trace:
Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400e6db9 PS : 0x00060530 A0 : 0x800d0c8a A1 : 0x3ffb1f30
A2 : 0x00000006 A3 : 0x00000001 A4 : 0x00000800 A5 : 0x00000000
A6 : 0x00000001 A7 : 0x00000000 A8 : 0x800e6da9 A9 : 0x3ffb1b60
A10 : 0x00000006 A11 : 0xffffffff A12 : 0x00000000 A13 : 0x3f40516a
A14 : 0x00000001 A15 : 0x00000001 SAR : 0x0000001f EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000001 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
ELF file SHA256: 0000000000000000
Backtrace: 0x400e6db9:0x3ffb1f30 0x400d0c87:0x3ffb1f80 0x400d1eca:0x3ffb1fb0 0x40086125:0x3ffb1fd0
Decoded:
PC: 0x400e6db9: snprintf at ../../../.././newlib/libc/stdio/snprintf.c line 121
Decoding stack results
0x400d0c87: setup() at src/main.cpp line 88
0x400d1eca: loopTask(void*) at /home/mcontenla/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp line 18
0x40086125: vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c line 143
However, if I use the Arduino IDE to compile and upload this exact program, it runs succesfully, giving me the output I would expect.
Does anyone have any clue about what’s going on? I’ve tried with different boards, but the result has been the same. Reinstalling PlatformIO has not worked either.
Any help would be appreciated.
Thank you.
