I am working on ESP32-S3-DevKitC-1 board, with module ESP32-S3-WROOM-2, MON32R8V.
When I use esptool.py to identify the board it says as below.
But when I compile code the result shows
Please tell me what might be the reason why Flash usage is 91.3% from 1048576 bytes, while I have 32MB actual flash.
Do I need to configure in the board json file, or platformio.ini file. If yes, please tell me where can I find documentation for settings accordingly.
Thank you.
Lhagva
