Demo compiles and runs with no issues under espidf. The trouble begins when I try to build under pio.
Build output
> Executing task in folder SoftAP_pio: platformio run <
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: espidf)
PLATFORM: Espressif 32 1.9.0 > DOIT ESP32 DEVKIT V1
PACKAGES: toolchain-xtensa32 2.50200.80 (5.2.0), framework-espidf 3.30202.190627 (3.2.2), tool-esptoolpy 1.20600.0 (2.6.0)
Found 0 compatible libraries
Compiling .pio/build/esp32doit-devkit-v1/src/main.o
src/main.cpp: In function 'void wifi_event_handler(void*, esp_event_base_t, int32_t, void*)':
src/main.cpp:45:21: error: 'WIFI_EVENT_AP_STACONNECTED' was not declared in this scope
if (event_id == WIFI_EVENT_AP_STACONNECTED)
src/main.cpp:47:9: error: 'wifi_event_ap_staconnected_t' was not declared in this scope
wifi_event_ap_staconnected_t *event = (wifi_event_ap_staconnected_t *)event_data;
src/main.cpp:47:39: error: 'event' was not declared in this scope
src/main.cpp:47:78: error: expected primary-expression before ')' token
src/main.cpp:51:26: error: 'WIFI_EVENT_AP_STADISCONNECTED' was not declared in this scope
else if (event_id == WIFI_EVENT_AP_STADISCONNECTED)
src/main.cpp:53:9: error: 'wifi_event_ap_stadisconnected_t' was not declared in this scope
<truncated for sanity >
/* WiFi softAP Example
This example code is in the Public Domain (or CC0 licensed, at your option.)
Unless required by applicable law or agreed to in writing, this
software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
CONDITIONS OF ANY KIND, either express or implied.
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/sys.h"
/* The examples use WiFi configuration that you can set via project configuration menu.
If you'd rather not, just change the below entries to strings with
the config you want - ie #define EXAMPLE_WIFI_SSID "mywifissid"
#define EXAMPLE_ESP_WIFI_SSID CONFIG_ESP_WIFI_SSID
#define EXAMPLE_ESP_WIFI_PASS CONFIG_ESP_WIFI_PASSWORD
#define EXAMPLE_MAX_STA_CONN CONFIG_ESP_MAX_STA_CONN
#define NONSENCE BLAH
static const char *TAG = "wifi softAP";
extern "C"
void app_main(void);
static void wifi_event_handler(void *arg, esp_event_base_t event_base,
int32_t event_id, void *event_data)
ESP_LOGI(TAG, "station " MACSTR " join, AID=%d",
MAC2STR(event->mac), event->aid);
wifi_event_ap_stadisconnected_t *event = (wifi_event_ap_stadisconnected_t *)event_data;
ESP_LOGI(TAG, "station " MACSTR " leave, AID=%d",
void wifi_init_softap(void)
tcpip_adapter_init();
ESP_ERROR_CHECK(esp_event_loop_create_default());
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&cfg));
ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler, NULL));
wifi_config_t wifi_config = {
.ap = {
.ssid = EXAMPLE_ESP_WIFI_SSID,
.ssid_len = strlen(EXAMPLE_ESP_WIFI_SSID),
.password = EXAMPLE_ESP_WIFI_PASS,
.max_connection = EXAMPLE_MAX_STA_CONN,
.authmode = WIFI_AUTH_WPA_WPA2_PSK},
if (strlen(EXAMPLE_ESP_WIFI_PASS) == 0)
wifi_config.ap.authmode = WIFI_AUTH_OPEN;
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
ESP_LOGI(TAG, "wifi_init_softap finished. SSID:%s password:%s",
EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
void app_main(void)
//Initialize NVS
esp_err_t ret = nvs_flash_init();
if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND)
ESP_ERROR_CHECK(nvs_flash_erase());
ESP_ERROR_CHECK(ret);
ESP_LOGI(TAG, "ESP_WIFI_MODE_AP");
wifi_init_softap();
Thank you for your advise.
