just started trying to program my ESP32 WROOM dev board with PlatformIO.
I copied the a2dp_sink Bluetooth example from espressif’s own esp-idf distribution which I downloaded off github into a PlatformIO project folder, with no changes whatsoever, and it didn’t compile.
This is how my platformio.ini is currently configured:
framework = espidf
monitor_baud = 115200
And these are the compile errors I get:
src\main.c: In function 'app_main':
src\main.c:76:23: error: 'CONFIG_I2S_BCK_PIN' undeclared (first use in this function)
.bck_io_num = CONFIG_I2S_BCK_PIN,
src\main.c:76:23: note: each undeclared identifier is reported only once for each function it appears in
src\main.c:77:22: error: 'CONFIG_I2S_LRCK_PIN' undeclared (first use in this function)
.ws_io_num = CONFIG_I2S_LRCK_PIN,
src\main.c:78:25: error: 'CONFIG_I2S_DATA_PIN' undeclared (first use in this function)
.data_out_num = CONFIG_I2S_DATA_PIN,
*** [.pioenvs\esp32dev\src\main.o] Error 1
How do I get my code to run on my devboard with PlatformIO?
Cheers,
brainbug
