Hello, I am trying to get code onto an ESP32-DevKitM-1 board, but anytime I try uploading through platformio, it does not seem to work. I am using example code from the esp idf (\esp-idf\examples\get-started\hello_world). The code builds and uploads fine, but from looking at the serial monitor, it seems to be stuck in a loop while booting up. Here is what is output to the terminal.
— Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable,
send_on_enter, time
— More details at Redirecting...
— Miniterm on COM4 115200,8,N,1 —
— Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H —
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 188777542, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:7164
ho 0 tail 12 room 4
load:0x40078000,len:14292
load:0x40080400,len:3688
entry 0x40080678
␛[0;32mI (30) boot: ESP-IDF 4.3.0 2nd stage bootloader␛[0m
␛[0;32mI (30) boot: compile time 16:59:44␛[0m
␛[0;32mI (30) boot: chip revision: 3␛[0m
␛[0;32mI (33) boot_comm: chip revision: 3, min. bootloader chip revision: 0␛[0m
␛[0;32mI (40) boot.esp32: SPI Speed : 40MHz␛[0m
␛[0;32mI (44) boot.esp32: SPI Mode : DIO␛[0m
␛[0;32mI (49) boot.esp32: SPI Flash Size : 4MB␛[0m
␛[0;32mI (53) boot: Enabling RNG early entropy source…␛[0m
␛[0;32mI (59) boot: Partition Table:␛[0m
␛[0;32mI (62) boot: ## Label Usage Type ST Offset Length␛[0m
␛[0;32mI (70) boot: 0 nvs WiFi data 01 02 00009000 00006000␛[0m
␛[0;32mI (77) boot: 1 phy_init RF data 01 01 0000f000 00001000␛[0m
␛[0;32mI (85) boot: 2 factory factory app 00 00 00010000 00100000␛[0m
␛[0;32mI (92) boot: End of partition table␛[0m
␛[0;32mI (96) boot_comm: chip revision: 3, min. application chip revision: 0␛[0m
␛[0;32mI (103) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=06c94h ( 27796) map␛[0m
␛[0;32mI (122) esp_image: segment 1: paddr=00016cbc vaddr=3ffb0000 size=02940h ( 10560) load␛[0m
␛[0;32mI (127) esp_image: segment 2: paddr=00019604 vaddr=40080000 size=06a14h ( 27156) load␛[0m
␛[0;32mI (140) esp_image: segment 3: paddr=00020020 vaddr=400d0020 size=13870h ( 79984) map␛[0m
␛[0;32mI (171) esp_image: segment 4: paddr=00033898 vaddr=40086a14 size=04058h ( 16472) load␛[0m
␛[0;32mI (178) esp_image: segment 5: paddr=000378f8 vaddr=50000000 size=00010h ( 16) load␛[0m
␛[0;32mI (185) boot: Loaded app from partition at offset 0x10000␛[0m
␛[0;32mI (185) boot: Disabling RNG early entropy source…␛[0m
␛[0;32mI (199) cpu_start: Pro cpu up.␛[0m
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
entry 0x40080678
␛[0;32mI (45) boot.esp32: SPI Mode : DIO␛[0m
␛[0;32mI (54) boot: Enabling RNG early entropy source…␛[0m
␛[0;32mI (63) boot: ## Label Usage Type ST Offset Length␛[0m
␛[0;32mI (97) boot_comm: chip revision: 3, min. application chip revision: 0␛[0m
␛[0;32mI (104) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=06c94h ( 27796) map␛[0m
␛[0;32mI (123) esp_image: segment 1: paddr=00016cbc vaddr=3ffb0000 size=02940h ( 10560) load␛[0m
␛[0;32mI (141) esp_image: segment 3: paddr=00020020 vaddr=400d0020 size=13870h ( 79984) map␛[0m
␛[0;32mI (200) cpu_start: Pro cpu up.␛[0m
This output just repeats starting with the line:
I am new to ESP32 boards so I have no idea what to do here. Any help would be appreciated.
