I’m a newbie using the esp32 board(esp-wrover-kit) for the first time, and I have the following questions;
- I opened the espidf-arduino-blink project in platformio, and I could see that framework = arduino, espidf was set. Can I use both frameworks?
[env]
-D CONFIG_BLINK_GPIO=2
- When debugging the esp-wrover-kit board (ftdi interface), the following warning message is displayed. How can I modify it?
undefinedC:\Users\JJS\.platformio\packages\toolchain-xtensa-esp32\bin\xtensa-esp32-elf-gdb.exe: warning: Couldn't determine a path for the index cache directory.
Reading symbols from c:\Users\JJS\Documents\PlatformIO\Projects\esp_wrover_kit_ve\.pio\build\esp-wrover-kit\firmware.elf...
PlatformIO: debug_tool = ftdi
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp32-wrover.cfg is deprecated, and may be removed in a future release.
If your board is ESP32-WROVER-KIT, use board/esp32-wrover-kit-1.8v.cfg instead.
adapter speed: 5000 kHz
- Debugging with ftdi is too slow, is there any way to speed it up?
[env:esp-wrover-kit]
board = esp-wrover-kit
- What is the default debugger for platformio? openocd?
