I cant get debugger working properly. it stopped once or twice at app_main, but now it never stops in source code so I can’t debug it step by step.
it tells that it stopped, but its not
my setup: ubuntu 18.04, vscode, esp32dev module, CJMCU-2232 breakout board.
FTDI AD0 -> ESP32 GPIO13 (TCK)
FTDI AD1 -> ESP32 GPIO12 (TDI)
FTDI AD2 -> ESP32 GPIO15 (TDO)
FTDI AD3 -> ESP32 GPIO14 (TMS)
FTDI AC2 -> ESP32 EN (RST)
FTDI GND -> ESP32 GND
FTDI 3V3 -> ESP32 3V3
platformio.ini:
debug_tool = minimodule
here is log from debug window. in the end i clicked pause and it doesnt show me where it stopped. step over, step into not working as well.
Reading symbols from /home/user/Documents/PlatformIO/Projects/esp32-blink/.pioenvs/esp32dev/firmware.elf...
done.
PlatformIO Unified Debugger > http://bit.ly/pio-debug
Open On-Chip Debugger 0.10.0-dev (2018-06-04-09:50)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
esp32 interrupt mask on
force hard breakpoints
Info : tcl server disabled
Info : telnet server disabled
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core was reset (pwrstat=0x5F, after clear 0x0F).
cpu0: Current bits set: BreakIn BreakOut RunStallIn
cpu1: Current bits set: none
Info : Target halted. PRO_CPU: PC=0x40009394 (active) APP_CPU: PC=0x00000000
esp32: target state: halted
Info : Use core0 of target 'esp32'
Info : Target halted. PRO_CPU: PC=0x40091D07 (active) APP_CPU: PC=0x00000000
Info : Auto-detected flash size 4096 KB
Info : Using flash size 4096 KB
0x40009394 in ?? ()
Not implemented stop reason (assuming exception): undefined
Error: Too large number of threads 19205715!
Hardware assisted breakpoint 1 at 0x401207eb: file /home/user/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp, line 21.
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core was reset (pwrstat=0x1F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
** Programming Started **
auto erase enabled
auto erase enabled
Info : Target halted. PRO_CPU: PC=0x40091D07 (active) APP_CPU: PC=0x400076DD
wrote 16384 bytes from file /home/user/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin in 0.817486s (19.572 KiB/s)
** Programming Finished **
** Verify Started **
Info : Target halted. PRO_CPU: PC=0x40091D07 (active) APP_CPU: PC=0x400076E2
read 15088 bytes from file /home/user/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_40m.bin and flash bank 0 at offset 0x00001000 in 0.304486s (48.391 KiB/s)
contents match
contents match
** Verified OK **
** Verified OK **
cpu1: Current bits set: BreakIn BreakOut RunStallIn
auto erase enabled
auto erase enabled
wrote 4096 bytes from file /home/user/Documents/PlatformIO/Projects/esp32-blink/.pioenvs/esp32dev/partitions.bin in 0.618787s (6.464 KiB/s)
read 3072 bytes from file /home/user/Documents/PlatformIO/Projects/esp32-blink/.pioenvs/esp32dev/partitions.bin and flash bank 0 at offset 0x00008000 in 0.261835s (11.458 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 8192 bytes from file /home/user/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin in 0.686053s (11.661 KiB/s)
read 8192 bytes from file /home/user/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin and flash bank 0 at offset 0x0000e000 in 0.291061s (27.486 KiB/s)
contents match
** Verified OK **
contents match
** Verified OK **
auto erase enabled
auto erase enabled
wrote 688128 bytes from file /home/user/Documents/PlatformIO/Projects/esp32-blink/.pioenvs/esp32dev/firmware.bin in 5.302926s (126.722 KiB/s)
read 686224 bytes from file /home/user/Documents/PlatformIO/Projects/esp32-blink/.pioenvs/esp32dev/firmware.bin and flash bank 0 at offset 0x00010000 in 2.643653s (253.490 KiB/s)
contents match
contents match
** Verified OK **
** Verified OK **
PlatformIO: Resume the execution to `debug_init_break = thb app_main`
Info : Target halted. PRO_CPU: PC=0x40007A2E (active) APP_CPU: PC=0x400076DD
Program received signal
SIGINT, Interrupt.
0x40007a2e in ?? ()
