Some weeks nothing seems to go right, and I appear to be having one this week all I’m trying to do is create a static IP address.
I have tried all sorts of permutations and obviously missing something
I have gone back to basics and tried using one of the examples.
and even this fails to connect I have tried three brand-new boards and there is no difference with any of them
no connection at this point
Any suggestions
¬¬¬cpp
Example of connection using Static IP
by Evandro Luis Copercini
Public domain - 2017
#include <WiFi.h>
const char* ssid = “***";
const char* password = "”;
const char* host = “google.co.uk”;
const char* url = “/index.html”;
IPAddress local_IP(192, 168, 1, 205);
IPAddress gateway(192, 168, 1, 254);
IPAddress subnet(255, 255, 255, 0);
IPAddress primaryDNS(8, 8, 8, 8); //optional
IPAddress secondaryDNS(8, 8, 4, 4); //optional
void setup()
if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
Serial.println(“STA Failed to configure”);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.disconnect();
WiFi.begin(ssid, password);
delay(500);
Serial.print(“.”);
Serial.println(“”);
Serial.println(“WiFi connected!”);
Serial.print("IP address: ");
Serial.print("ESP Mac Address: ");
Serial.println(WiFi.macAddress());
Serial.print("Subnet Mask: ");
Serial.println(WiFi.subnetMask());
Serial.print("Gateway IP: ");
Serial.println(WiFi.gatewayIP());
Serial.print("DNS: ");
Serial.println(WiFi.dnsIP());
void loop()
delay(5000);
Serial.print("connecting to ");
Serial.println(host);
// Use WiFiClient class to create TCP connections
WiFiClient client;
const int httpPort = 80;
if (!client.connect(host, httpPort)) {
Serial.println(“connection failed”);
return;
Serial.print("Requesting URL: ");
Serial.println(url);
// This will send the request to the server
client.print(String(“GET “) + url + " HTTP/1.1\r\n” +
“Host: " + host + “\r\n” +
“Connection: close\r\n\r\n”);
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(”>>> Client Timeout !”);
client.stop();
return;
// Read all the lines of the reply from server and print them to Serial
while (client.available()) {
String line = client.readStringUntil(‘\r’);
Serial.print(line);
Serial.println();
Serial.println(“closing connection”);
