Update: Solved - in platformio I had a library that the code wasn’t using but it must have redefined something critical:
git@github.com:sandeepmistry/arduino-CAN.git
Original Post:
I suspect this is a build flag or platform version issue but I need help tracking it down.
The sample below compiles, uploads and runs fine in both IDEs but only arduino prints out the Received: <frameid> message in loop() in response to a CAN message from another device on my can bus.
#include <driver/can.h>
#include <driver/gpio.h>
void setup_can() {
can_general_config_t general_config = {
.mode = CAN_MODE_NORMAL,
.tx_io = (gpio_num_t)GPIO_NUM_5,
.rx_io = (gpio_num_t)GPIO_NUM_4,
.clkout_io = (gpio_num_t)CAN_IO_UNUSED,
.bus_off_io = (gpio_num_t)CAN_IO_UNUSED,
.tx_queue_len = 5,
.rx_queue_len = 5,
.alerts_enabled = CAN_ALERT_ALL,
.clkout_divider = 0,
can_timing_config_t timing_config = CAN_TIMING_CONFIG_250KBITS();
can_filter_config_t filter_config = CAN_FILTER_CONFIG_ACCEPT_ALL();
esp_err_t error;
error = can_driver_install(&general_config, &timing_config, &filter_config);
if(error == ESP_OK) {
Serial.println("CAN Driver Istalllation OK");
} else {
Serial.println("CAN Driver Istalllation Failed");
error = can_start();
Serial.println("CAN Driver Start OK");
} else {
Serial.println("CAN Driver Start Failed");
delay(1000);
setup_can();
can_message_t rx_frame;
if (can_receive(&rx_frame, pdMS_TO_TICKS(1000))==ESP_OK) {
Serial.print("Received: ");
Serial.println(rx_frame.identifier);
} else {
Serial.print(".");
- In Arduino
- boardmanager url -
https://dl.espressif.com/dl/package_esp32_index.json - installed latest
1.0.4ofarduino-esp32- xtensa-esp32-elf-gcc 1.22
- esptool_py 2.6.1
- mkspiffs 0.2.3
- In Platformio
- espressif32 @ 2.1.0 (latest)
- toolchain-xtensa32 @ ~2.50200.0
- tool-esptoolpy @ ~1.30000.0
- framework-arduinoespressif32 @ ~3.10004.191002
I can’t see where platformio references the arduino-esp32 version which I assume it is using. Any suggestions on how to get this sample working in platformio?
