Esp32-c6 supported from Platformio
Hi community…
I would like to know if this mcu
https://espressif-docs.readthedocs-hosted.com/projects/espressif-esp-dev-kits/en/latest/esp32c6/esp32-c6-devkitc-1/user_guide.html
will be supported from platformio and arduino Ide
Thanks @maxgerhardt and @ivankravets
Please file a feature request at
I recently bought an ESP32-C6 and was doing some digging, @simogaspa84 also asked this question again in a new topic (Esp32 c6 support) so I decided to share my findings. It seems that we’re still waiting for Arduino ESP32 Core support. There’s an open issue about it (https://github.com/espressif/arduino-esp32/issues/7713). Fortunately it’s currently in review, as can be seen in the Arduino ESP32 Core roadmap.
Comments on the issue mention that Arduino support should mostly work using the master branch of Arduino ESP32 Core and I was hoping that someone could figure out a way to use that in PlatformIO while we wait for official support. I gave it a try but I’m not a platformio.ini expert.
I’m embarrassed to admit that I didn’t try the simplest solution, using the ESP32-C6 config from Espressif ESP32-C6-DevKitC-1 — PlatformIO latest documentation and adding framework = arduino. I’ve successfully uploaded code to the ESP32-C6 with the following platformio.ini:
[env:esp32-c6-devkitm-1]
board = esp32-c6-devkitm-1
Sorry, this is not working :
Error: This board doesn’t support arduino framework!
The ESP32-C6 is only supported from Arduino 3.0 upwards with ESP-IDF 5.1 as the basis: Release Arduino Alpha Release v3.0.0 based on ESP-IDF v5.1 · espressif/arduino-esp32 · GitHub
However, this is still in the alpha stage and is not yet officially supported by PlatformIO.
This should work
[env:esp32c6]
board = esp32-c6-devkitc-1
platform = https://github.com/platformio/platform-espressif32.git
platform_packages =
	platformio/framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git
	platformio/framework-arduinoespressif32-libs @ https://github.com/espressif/esp32-arduino-libs.git#idf-release/v5.1
and add in the boards.json the framework arduino or use a custom boards.json in your project folder boards/esp32-c6-devkitc-1.json
  "build": {
    "core": "esp32",
    "f_cpu": "160000000L",
    "f_flash": "80000000L",
    "flash_mode": "qio",
    "mcu": "esp32c6",
    "variant": "esp32c6"
  "connectivity": [
    "wifi"
  "debug": {
    "openocd_target": "esp32c6.cfg"
  "frameworks": [
    "arduino",
    "espidf"
  "name": "Espressif ESP32-C6-DevKitC-1",
  "upload": {
    "flash_size": "8MB",
    "maximum_ram_size": 327680,
    "maximum_size": 8388608,
    "require_upload_port": true,
    "speed": 460800
  "url": "https://docs.espressif.com/projects/espressif-esp-dev-kits/en/latest/esp32c6/esp32-c6-devkitc-1/index.html",
  "vendor": "Espressif"
Seems like its not quite the full story - PlatformIO itself seems happy with this configuration, but the compiler fails for all project files with the following message:
riscv32-esp-elf-g++: error: unrecognized command line option '-mlongcalls'
If I figure it out I’ll post my solution, but don’t hold your breath. Probably Espressif will release the working version first :rofl:
@runger1101001 @jason2866 any final news from support of platformio arduino framework for ESP32C6?
Thanks
Nope. Idk if there will be ever official support for. I forked and use my own.
Hi @jason2866 … thanks.
Are you going to share your forked repo?
Thanks
It is a fork for reasons. Some stuff removed. You won’t find SPIFFS and mbedtls stuff
Thanks… I use all of them (mbedtls and spiffis) in the project that i would like to port in the esp32c6 mcu.
Are you going to add them?
Did you tes in the esp32c6 real hw?
Thanks again
No will not add. I removed because it eats resources. Yes running Tasmota on a C6 and C2
Tasmota what do you mean ?? thanks
Tasmota firmware running on the C6
MY SOLUTION:
I found the fix on the seeed xiao esp32-c6 wiki. Their official documentation is outdated, but in the comments was nested this nugget of gold:
[env:seeed_xiao_esp32c6]
board = seeed_xiao_esp32c6
This fixed the “Error: This board doesn’t support arduino framework!” for me.
