ESP32 C3 SuperMini / C3-Zero not responding
Hi there,
i am having trouble to get the ESP32 C3 SuperMini and C3-Zero working. i have a simple example code just Serial.println something every second.
The code uploads with these settings:
[env:lolin_c3_mini1]
board = lolin_c3_mini
board_upload.flash_size = 4MB
board_build.partitions = default.csv
  	-DARDUINO_USB_MODE=1
  	-DARDUINO_USB_CDC_ON_BOOT=1
	-DARDUINO_ESP32C3_DEV=1
example code:
  Serial.begin(9600);
  Serial.println("asdf");
  delay(10);
The issue is, that i just do not get any response from neither of these chips (after successfull upload of the image).
i know there are many threads asking for help with the serial output for the C3, and the solution seems to be DARDUINO_USB_CDC_ON_BOOT but here it just does not do the trick.
Even using example code to enable wifi networks or makeing it appear as a bluetooth device does not work. it just accepts the flash and then does not do anything more.
i also tried to upload example code using the arduino ide (selected CDCon boot and using Lolin C3 Mini), and experimented with different serial speeds. with exact the same result: no response after flash.
How can i get closer to the problem here?
Any help would be great!! Thanks a lot!
If this is the same module that i have, there is an LED on GPIO 8.
You can let it blink to see if the sketch is running or not.
Try the following platformio.ini
[env:esp32-c3-devkitm-1]
board = esp32-c3-devkitm-1
build_flags=
  -D ARDUINO_USB_CDC_ON_BOOT=1
  -D ARDUINO_USB_MODE=1
and main.cpp:
#define LED 8
    Serial.println("Hello World");
    pinMode(LED, OUTPUT);
    digitalWrite(LED, HIGH);
    delay(500);
    digitalWrite(LED, LOW);
    delay(500);
Some boards must be reset manually after uploading. Pressing the reset button after upload also may help.
Hi there,
thanks for your quick reply. i tried your suggested code + settings for the board with exactly the same result: nothing :wink:
here are the boards i am trying to run the code on:
i am running PlattformIO Core 6.1.16 / Home 3.4.4 on VSCode 1.98.0, OSX 15.1
Any other idea what i could do?
Thanks a lot!
My board is similiar to the right one on the picture.
To be honest, i have no clue why both of your ESP-C3 are not working.
I’m on windows & linux (WSL Ubuntu).
It works with the latest platform-espressi32 @ 6.10.0
platform = espressif32 @ 6.10.0
as well as pioarduino 53.03.11
platform = https://github.com/pioarduino/platform-espressif32/releases/download/53.03.11/platform-espressif32.zip
What I’m really wondering about is that the upload works without issues but then nothing happens.
Did you try pressing the reset button after uploading?
Thats interesting… i have just tried again if the arduino ide behaves differently:
With success.
PlattformIO just does not want to show anything - and: it does upload the code, but the LED is not flashing after sucessfull flash. so i guess the flashing process ist not correct, or some settings are not correct.
i will try it on a native linux. maybe it has something to do with osx?
Cheers
For comparison, i put the most important settings side by side.
Some of them comming from platformio.ini and most of them are comming from esp32-c3-devktim-1.json:
ArduinoIDE platformio.ini esp32-c3-devktim-1.json
Board: "ESP32C3 Dev Module board = esp32-c3-devkitm-1
USB CDC On Boot: “Enabled” -D ARDUINO_USB_CDC_ON_BOOT=1
CPU Frequency: "160MHz (WiFi) "f_cpu": "160000000L"
Flash Frequency: “80MHz” "f_flash": "80000000L"
Flash Mode: “QIO” "flash_mode": "qio"
Flash Size: "4MB (32Mb) "flash_size": "4MB"
"maximum_size": 4194304
Upload Speed: “921600” "speed": 460800
I can’t see any significant differences except for the upload_speed but this can be changed in platformio.ini:
upload_speed = 921600
I have found the problem! its a littlebit embarrassing, but the cable was the problem.
just by accident i swapped the cable and now it works in the arduino ide as well as vscode. i also get the serial prints from the controller.
I have no idea why that could be, but anyway - it works now.
Cheers and thanks for the help!
Found required PINOUT here
https://github.com/espressif/arduino-esp32/pull/9174/commits
Found suitable var here
c:\Users\ostro.platformio\packages\framework-arduinoespressif32\variants\nologo_esp32c3_super_mini
but have added own board.json. Don’t know why this board missing
Nobody has created one yet and/or nobody has created a pull request yet.
The following configuration should match the nologo_esp32c3_super_mini:
[env:nologo_esp32c3_super_mini]
board_build.variant = nologo_esp32c3_super_mini
board_build.extra_flags =
Alternatively, here is a matching nolog_esp32c3_super_mini.json:
and the corresponding platformio.ini
board = nologo_esp32c3_super_mini
The nolog_esp32c3_super_mini.json can be placed either
  1. in a “boards” folder located in the projects folder
  2. in a “boards” folder located in the .platformio folder (which is located in the users home folder)
Option 1 will only be available to the current project
Option 2 will make this board available for all your projects
