zacdbg
September 7, 2023, 11:34am
1
Hello, i tried to compile ultra simple program for ESP32 C3 (literally no code) on windows but I am getting this:
Which means it tries to download incompatible toolchain?
my ini file:
[env:esp32-c3-devkitc-02]
; change microcontroller
board_build.mcu = esp32c3
I also tried different boards but result is the same, board is custom but schematic is super simple:
https://i.imgur.com/Ed9G2SH.png
Huh I’ve never seen that before. I assume this is Windows 11? Which IDE is this?
Maybe the toolchain is just corrupted, please remove all folders of the form
C:\Users\<user>\.platformio\packages\toolchain-xtensa*
C:\Users\<user>\.platformio\.cache
And rebuild the project.
zacdbg
September 7, 2023, 2:44pm
3
This is windows 10, IDE is clion
I removed cache and all toolchains
ran
pio pkg update
but error still remains
this is full log of pio run
╰ pio run
Processing esp32-c3-devkitc-02 (platform: espressif32; board: esp32dev; framework: arduino)
PLATFORM: Espressif 32 (6.4.0+sha.a9b9d09) > Espressif ESP32 Dev Module
HARDWARE: ESP32C3 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.20011.230801 (2.0.11)
Found 33 compatible libraries
Compiling .pio\build\esp32-c3-devkitc-02\src\main.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\HWCDC.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\Print.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\USB.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\USBCDC.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\USBMSC.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\esp32-hal-bt.c.o
Odmowa dost\xa9pu.
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\esp32-c3-devkitc-02\FrameworkArduino\esp32-hal-dac.c.o
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\Esp.cpp.o] Error 1
Odmowa dost\xa9pu.
Odmowa dost\xa9pu.
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\FunctionalInterrupt.cpp.o] Error 1
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\FirmwareMSC.cpp.o] Error 1
Odmowa dost\xa9pu.
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\HardwareSerial.cpp.o] Error 1
Odmowa dost\xa9pu.
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\HWCDC.cpp.o] Error 1
Odmowa dost\xa9pu.
Odmowa dost\xa9pu.
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\IPv6Address.cpp.o] Error 1
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\IPAddress.cpp.o] Error 1
Odmowa dost\xa9pu.
Odmowa dost\xa9pu.
Odmowa dost\xa9pu.
Odmowa dost\xa9pu.
Odmowa dost\xa9pu.
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\USBMSC.cpp.o] Error 1
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\WString.cpp.o] Error 1
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\USBCDC.cpp.o] Error 1
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\esp32-hal-cpu.c.o] Error 1
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\base64.cpp.o] Error 1
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\esp32-hal-bt.c.o] Error 1
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\esp32-hal-dac.c.o] Error 1
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\cbuf.cpp.o] Error 1
*** [.pio\build\esp32-c3-devkitc-02\FrameworkArduino\esp32-hal-adc.c.o] Error 1
Open a PlatformIO core CLI and execute:
cd C:\Users\<user>\.platformio\packages\toolchain-riscv32-esp\bin
.\riscv32-esp-elf-g++ --version
What’s the output?
zacdbg
September 8, 2023, 12:46am
5
My pio packages are moved to E:/.platformio
powershell says its not valid executable for this operating system (windows 10 pro 64bit)
E:/.platformio/packages/toolchain-riscv32-esp/bin
╰ .\riscv32-esp-elf-g++.exe --version
Program 'riscv32-esp-elf-g++.exe' failed to run: Wybrany plik wykonywalny nie jest prawidłową aplikacją tego systemu op
eracyjnego.At line:1 char:1
+ .\riscv32-esp-elf-g++.exe --version
At line:1 char:1
+ CategoryInfo : ResourceUnavailable: (:) [], ApplicationFailedException
+ FullyQualifiedErrorId : NativeCommandFailed
in windows bash there is nothing outputted
And trying same thing in CMD results in this popup that says app will not work on your system
So its clearly not valid toolchain
If a major toolchain was broken on Windows we’d know about it faster. “Works on my machine”
pio system info
What’s the output?
zacdbg
September 8, 2023, 8:23am
7
my system info
╰ pio system info
PlatformIO Core 6.1.11
Python 3.9.10-final.0
System Type windows_amd64
Platform Windows-10
File System Encoding utf-8
Locale Encoding cp1250
PlatformIO Core Directory E:\.platformio
PlatformIO Core Executable E:\.platformio\penv\Scripts\platformio.exe
Python Executable E:\.platformio\penv\Scripts\python.exe
Global Libraries 0
Development Platforms 16
Tools & Toolchains 65
Oh. Actually I just notice that your platformio.ini is very weird. You take a ESP32 base board and change the microcontroller to ESP32C3, I don’t think it’s possible that way.
Can you just use
board = esp32-c3-devkitc-02
instead?
zacdbg
September 8, 2023, 8:58am
9
This is really interesting, this is what i originally had: esp32-c3-devkitc-02
which you can probably guess from the env: name
now that i cleaned up the project pio did download new toolchain
pio run -t clean -e esp32-c3-devkitc-02
pio run
Tool Manager: Installing espressif/toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
Tool Manager: toolchain-riscv32-esp@8.4.0+2021r2-patch5 has been installed!
now both platformio.ini works (esp32-c3-devkitc-02 and esp32dev)! Not sure why i had some bogus toolchain installed but it was installed when i created project (originally i’ve chosen esp32-c3-devkitc-02).
Now no matter what i do, it downloads correct toolchain, really weird. So I cannot reproduce problem anymore
