ESP32-C3 - esp_ble_gap_start_advertising
I have a Bluetooth project for an ESP32 devkit and want to compile it for an ESP32-C3. I use the newest ESP32 Arduino core as a component with esp-idf and the following configuration for PlatformIO:
[platformio]
src_dir = src
default_envs = debug
# Common build environment that is used for each of the tasks
[env]
framework = espidf
board = esp32-c3-devkitm-1
# 4 MB module version
board_upload.flash_size = 4MB
board_upload.maximum_size = 4194304
board_build.partitions = partitions.csv
# Settings for serial upload
upload_speed = 921600
upload_port = COM2
# Settings for serial console
monitor_port = COM2
# Additional packages
platform_packages =
# Aditional build scripts for all environments to run before (`pre`) and after (`post`) the main build script
extra_scripts =
# Common build flags for all environments
    bblanchon/ArduinoJson@^6.18.0
[env:debug]
build_type = debug
    ${env.build_flags}
    -D DEBUG
    -D APP_VERSION_POST='debug'
    ${env.lib_deps}
extra_scripts =
    ${env.extra_scripts}
[env:release]
build_type = debug
    ${env.build_flags}
    -D RELEASE
    ${env.lib_deps}
extra_scripts =
I use the following toolchain:
 - framework-espidf @ 3.40401.0 (4.4.1)
 - tool-cmake @ 3.16.4
 - tool-idf @ 1.0.1
 - tool-mconf @ 1.4060000.20190628 (406.0.0)
 - tool-ninja @ 1.9.0
 - toolchain-riscv32-esp @ 8.4.0+2021r2-patch3
But I got the following error during the linking:
.platformio/packages/toolchain-riscv32-esp/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: .pio\build\debug\esp-idf\arduino-esp32\libarduino-esp32.a(BLEAdvertising.o): in function `BLEAdvertising::start()':
components/arduino-esp32/libraries/BLE/src/BLEAdvertising.cpp:247: undefined reference to `esp_ble_gap_start_advertising'
.platformio/packages/toolchain-riscv32-esp/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: components/arduino-esp32/libraries/BLE/src/BLEAdvertising.cpp:214: undefined reference to `esp_ble_gap_config_adv_data'
.platformio/packages/toolchain-riscv32-esp/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: components/arduino-esp32/libraries/BLE/src/BLEAdvertising.cpp:225: undefined reference to `esp_ble_gap_config_adv_data'
A verbose build outputs the following command before the error appears:
riscv32-esp-elf-g++ -o .pio\build\debug\firmware.elf -T memory.ld -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u start_app -T sections.ld
-u __ubsan_include -T esp32c3.rom.ld -T esp32c3.rom.api.ld -T esp32c3.rom.libgcc.ld -T esp32c3.rom.newlib.ld -T esp32c3.rom.version.ld -T esp32c3.rom.newlib-time.ld -T esp32c3.rom.eco3.ld -u __assert_func -u vfs_include_syscalls_impl -T esp32c3.peripherals.ld -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -u __cxx_fatal_exception --specs=nosys.specs -Wl,--Map=C:/Projects/firmware-loader/.pio/build/debug/Firmware-Loader.map -Wl,--cref -Wl,--gc-sections -Wl,--undefined=uxTopUsedPriority -Wl,--wrap=_Unwind_Backtrace -Wl,--wrap=_Unwind_DeleteException -Wl,--wrap=_Unwind_FindEnclosingFunction -Wl,--wrap=_Unwind_Find_FDE
-Wl,--wrap=_Unwind_ForcedUnwind -Wl,--wrap=_Unwind_GetCFA -Wl,--wrap=_Unwind_GetDataRelBase -Wl,--wrap=_Unwind_GetGR -Wl,--wrap=_Unwind_GetIP -Wl,--wrap=_Unwind_GetIPInfo -Wl,--wrap=_Unwind_GetLanguageSpecificData -Wl,--wrap=_Unwind_GetRegionStart -Wl,--wrap=_Unwind_GetTextRelBase -Wl,--wrap=_Unwind_RaiseException -Wl,--wrap=_Unwind_Resume -Wl,--wrap=_Unwind_Resume_or_Rethrow -Wl,--wrap=_Unwind_SetEnableExceptionFdeSorting -Wl,--wrap=_Unwind_SetGR -Wl,--wrap=_Unwind_SetIP -Wl,--wrap=__cxa_call_unexpected -Wl,--wrap=__deregister_frame_info -Wl,--wrap=__deregister_frame_info_bases -Wl,--wrap=__gxx_personality_v0 -Wl,--wrap=__register_frame -Wl,--wrap=__register_frame_info -Wl,--wrap=__register_frame_info_bases -Wl,--wrap=__register_frame_info_table -Wl,--wrap=__register_frame_info_table_bases -Wl,--wrap=__register_frame_table -fno-lto -fno-rtti -march=rv32imc -nostartfiles -Og -g2 -ggdb2 .pio\build\debug\src\Devices\JERRY\jerry.o .pio\build\debug\src\Devices\Memory\memory.o .pio\build\debug\src\Devices\TOM\I2CM.o .pio\build\debug\src\Devices\TOM\tom.o .pio\build\debug\src\Loader\loader.o .pio\build\debug\src\Version\version.o .pio\build\debug\src\main.o -L.pio\build\debug -LC:\.platformio\packages\framework-espidf\components\bt\controller\lib_esp32c3_family\esp32c3 -LC:\.platformio\packages\framework-espidf\components\esp_wifi\lib\esp32c3 -LC:\.platformio\packages\framework-espidf\components\esp_phy\lib\esp32c3 -L.pio\build\debug\esp-idf\esp_system\ld -LC:\.platformio\packages\framework-espidf\components\esp_rom\esp32c3\ld -LC:\.platformio\packages\framework-espidf\components\esp_wifi\lib\esp32c3 -LC:\.platformio\packages\framework-espidf\components\soc\esp32c3\ld -Wl,--start-group .pio\build\debug\esp-idf\esp_ringbuf\libesp_ringbuf.a .pio\build\debug\esp-idf\asio\libasio.a .pio\build\debug\esp-idf\protobuf-c\libprotobuf-c.a .pio\build\debug\esp-idf\esp_lcd\libesp_lcd.a .pio\build\debug\esp-idf\mdns\libmdns.a .pio\build\debug\esp-idf\protocomm\libprotocomm.a .pio\build\debug\esp-idf\cbor\libcbor.a .pio\build\debug\esp-idf\cmock\libcmock.a .pio\build\debug\esp-idf\unity\libunity.a .pio\build\debug\esp-idf\bt\libbt.a .pio\build\debug\esp-idf\coap\libcoap.a .pio\build\debug\esp-idf\esp_adc_cal\libesp_adc_cal.a .pio\build\debug\esp-idf\esp_hid\libesp_hid.a .pio\build\debug\esp-idf\wear_levelling\libwear_levelling.a .pio\build\debug\esp-idf\esp_local_ctrl\libesp_local_ctrl.a .pio\build\debug\esp-idf\esp_websocket_client\libesp_websocket_client.a .pio\build\debug\esp-idf\expat\libexpat.a .pio\build\debug\esp-idf\fatfs\libfatfs.a .pio\build\debug\esp-idf\freemodbus\libfreemodbus.a .pio\build\debug\esp-idf\spiffs\libspiffs.a .pio\build\debug\esp-idf\openssl\libopenssl.a .pio\build\debug\esp-idf\libsodium\liblibsodium.a .pio\build\debug\esp-idf\jsmn\libjsmn.a .pio\build\debug\esp-idf\mqtt\libmqtt.a .pio\build\debug\esp-idf\json\libjson.a .pio\build\debug\esp-idf\wifi_provisioning\libwifi_provisioning.a .pio\build\debug\esp-idf\arduino-esp32\libarduino-esp32.a .pio\build\debug\esp-idf\RAK3172\libRAK3172.a .pio\build\debug\esp-idf\app_trace\libapp_trace.a .pio\build\debug\esp-idf\app_update\libapp_update.a .pio\build\debug\esp-idf\bootloader_support\libbootloader_support.a .pio\build\debug\esp-idf\console\libconsole.a .pio\build\debug\esp-idf\cxx\libcxx.a .pio\build\debug\esp-idf\driver\libdriver.a .pio\build\debug\esp-idf\efuse\libefuse.a .pio\build\debug\esp-idf\esp-tls\libesp-tls.a .pio\build\debug\esp-idf\esp_common\libesp_common.a .pio\build\debug\esp-idf\esp_event\libesp_event.a .pio\build\debug\esp-idf\esp_gdbstub\libesp_gdbstub.a .pio\build\debug\esp-idf\esp_http_client\libesp_http_client.a .pio\build\debug\esp-idf\esp_http_server\libesp_http_server.a .pio\build\debug\esp-idf\esp_https_ota\libesp_https_ota.a .pio\build\debug\esp-idf\esp_hw_support\libesp_hw_support.a .pio\build\debug\esp-idf\esp_ipc\libesp_ipc.a .pio\build\debug\esp-idf\esp_netif\libesp_netif.a .pio\build\debug\esp-idf\esp_phy\libesp_phy.a .pio\build\debug\esp-idf\esp_pm\libesp_pm.a .pio\build\debug\esp-idf\esp_rom\libesp_rom.a .pio\build\debug\esp-idf\esp_serial_slave_link\libesp_serial_slave_link.a .pio\build\debug\esp-idf\esp_system\libesp_system.a .pio\build\debug\esp-idf\esp_timer\libesp_timer.a .pio\build\debug\esp-idf\esp_wifi\libesp_wifi.a .pio\build\debug\esp-idf\espcoredump\libespcoredump.a .pio\build\debug\esp-idf\freertos\libfreertos.a .pio\build\debug\esp-idf\hal\libhal.a .pio\build\debug\esp-idf\heap\libheap.a .pio\build\debug\esp-idf\log\liblog.a .pio\build\debug\esp-idf\lwip\liblwip.a .pio\build\debug\esp-idf\mbedtls\libmbedtls.a .pio\build\debug\esp-idf\newlib\libnewlib.a .pio\build\debug\esp-idf\nghttp\libnghttp.a .pio\build\debug\esp-idf\nvs_flash\libnvs_flash.a .pio\build\debug\esp-idf\pthread\libpthread.a .pio\build\debug\esp-idf\riscv\libriscv.a .pio\build\debug\esp-idf\sdmmc\libsdmmc.a .pio\build\debug\esp-idf\soc\libsoc.a .pio\build\debug\esp-idf\spi_flash\libspi_flash.a .pio\build\debug\esp-idf\tcp_transport\libtcp_transport.a .pio\build\debug\esp-idf\tcpip_adapter\libtcpip_adapter.a .pio\build\debug\esp-idf\vfs\libvfs.a .pio\build\debug\esp-idf\wpa_supplicant\libwpa_supplicant.a .pio\build\debug\esp-idf\mbedtls\mbedtls\library\libmbedcrypto.a .pio\build\debug\esp-idf\mbedtls\mbedtls\library\libmbedtls.a .pio\build\debug\esp-idf\mbedtls\mbedtls\library\libmbedx509.a -lbtdm_app -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lbtbb -lgcov -lc -lm -lstdc++ -lgcc -Wl,--end-group
It looks like libbt.a isn´t linked. May this cause this issue? How can I fix it or where do I find the required part in the build system of pio?
Are you sure CONFIG_BT_ENABLED=y in the sdkconfig?
Hi @maxgerhardt,
yes it´s enabled. The code can get compiled successfully when switching to an ESP32 instead of the C3.
Hi @kampi ! The missing functions are wrapped by the BLE_42_FEATURE_SUPPORT macro. Could you please double check that the BLE 4.2 features are enabled in your sdkconfig? I guess the CONFIG_BT_BLE_42_FEATURES_SUPPORTED=y is the right option.
thank you! This was the final hint. I also have seen that my sdkconfig contains also CONFIG_BT_BLE_50_FEATURES_SUPPORTED. Is there some documentation to find out the function of these two macros? I only have found this link and it wasn´t very helpful :frowning:
