ESP32 C++17 toolchain missing std::optional
I’ve been trying to get C++17 working, and for the most part it seemed to be working, but there is no std::optional in there.
My platformio.ini looks like this:
[env]
build_unflags = -std=gnu++11
build_flags = -std=c++17
If I have #include <optional> in my code, the error I get is:
In file included from src/main.cpp:12:0: fatal error: optional: No such file or directory
How can I get a fully working C++17 toolchain for ESP32?
After some time looking for answers, I’m just left even more confused about the different toolchains. What is the difference, for example, between toolchain-xtensa32 and toolchain-xtensa-esp32 and which one should I use? When I include toolchain-xtensa-esp32 it still uses the other one to build my application…
Looking into the contents of toolchain-xtensa32 it does have the optional header, so not sure why the toolchain can’t find it.
I updated to the platform you linked to, and it finally uses gcc 8.4, so that’s great news. But now I have an issue with the FreeRTOS.h header, AFAIK the ESP-IDF should contain FreeRTOS as well, so did something get renamed or what?
In file included from src/main.cpp:12: fatal error: FreeRTOS.h: No such file or directory
Ok, FreeRTOS.h header moved
before: #include <FreeRTOS.h>
after: #include <freertos/FreeRTOS.h>
Hi, @petoknm how did you manage to fix this? I’m using the following platformio.ini config, and keep receiving:
[env]
[env:esp32doit-devkit-v1]
platform = https://github.com/tasmota/platform-espressif32/releases/download/v2.0.2idf/platform-espressif32-2.0.2.zip
board = esp32doit-devkit-v1
extra_scripts =
Rather use gnu++17, I’ve seen it needing GNU extensions.
Works for me.
build_flags = -std=gnu++17
#include <optional>
void setup(){}
void loop(){}
>pio run
Processing esp32doit-devkit-v1 (platform: https://github.com/tasmota/platform-espressif32/releases/download/v2.0.2idf/platform-espressif32-2.0.2.zip; board: esp32doit-devkit-v1; framework: arduino)
PLATFORM: Espressif 32 (2.0.2) > DOIT ESP32 DEVKIT V1
 - framework-arduinoespressif32 2.0.2
 - tool-esptoolpy 1.30200.211025 (3.2.0)
 - tool-mklittlefs 1.203.210628 (2.3)
 - toolchain-xtensa-esp32 8.4.0+2021r2
Found 30 compatible libraries
Compiling .pio\build\esp32doit-devkit-v1\src\main.cpp.o
Generating partitions .pio\build\esp32doit-devkit-v1\partitions.bin
Archiving .pio\build\esp32doit-devkit-v1\libFrameworkArduinoVariant.a
Indexing .pio\build\esp32doit-devkit-v1\libFrameworkArduinoVariant.a
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\HWCDC.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\Print.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\USB.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\USBCDC.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\USBMSC.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-i2c-slave.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-tinyusb.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\firmware_msc_fat.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\main.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\esp32doit-devkit-v1\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\esp32doit-devkit-v1\libFrameworkArduino.a
Indexing .pio\build\esp32doit-devkit-v1\libFrameworkArduino.a
Linking .pio\build\esp32doit-devkit-v1\firmware.elf
Retrieving maximum program size .pio\build\esp32doit-devkit-v1\firmware.elf
Checking size .pio\build\esp32doit-devkit-v1\firmware.elf
RAM:   [          ]   4.2% (used 13668 bytes from 327680 bytes)
Flash: [=         ]  12.5% (used 163249 bytes from 1310720 bytes)
Building .pio\build\esp32doit-devkit-v1\firmware.bin
esptool.py v3.2
Merged 2 ELF sections
=====================[SUCCESS] Took 11.05 seconds =====================
This totally works! Awesome! Thank you very much :rocket:
