Hi, I have problem that I couldn’t find any solution or whatsoever on google. So I will ask here. So basiclly I want to upload basicOTA example from Platformio library example for Esp32. I tried example from Arduino editor and it works fine. But in platformio same code with same libraries won’t compile.
I checked compiler standard and it is c++11, installed ArduinoOTA library globaly and specific to project and still wont compile, below is compiler output. Thank you soo much for any help, I would really appreciate it! I forgot, board is DOIT Esp32
Archiving .pio\build\esp32doit-devkit-v1\lib7af\libSD.a
src\main.cpp: In function ‘void setup()’:
src\main.cpp:35:6: error: ‘class ArduinoOTAMdnsClass<WiFiServer, WiFiClient, WiFiUDP>’ has no member named ‘onStart’
.onStart( {
src\main.cpp: In lambda function:
src\main.cpp:37:22: error: ‘class ArduinoOTAMdnsClass<WiFiServer, WiFiClient, WiFiUDP>’ has no member named ‘getCommand’
if (ArduinoOTA.getCommand() == U_FLASH)
src\main.cpp:37:38: error: ‘U_FLASH’ was not declared in this scope
src\main.cpp:51:17: error: ‘ota_error_t’ has not been declared
.onError((ota_error_t error) {
src\main.cpp:53:20: error: ‘OTA_AUTH_ERROR’ was not declared in this scope
if (error == OTA_AUTH_ERROR) Serial.println(“Auth Failed”);
src\main.cpp:54:25: error: ‘OTA_BEGIN_ERROR’ was not declared in this scope
else if (error == OTA_BEGIN_ERROR) Serial.println(“Begin Failed”);
src\main.cpp:55:25: error: ‘OTA_CONNECT_ERROR’ was not declared in this scope
else if (error == OTA_CONNECT_ERROR) Serial.println(“Connect Failed”);
src\main.cpp:56:25: error: ‘OTA_RECEIVE_ERROR’ was not declared in this scope
else if (error == OTA_RECEIVE_ERROR) Serial.println(“Receive Failed”);
src\main.cpp:57:25: error: ‘OTA_END_ERROR’ was not declared in this scope
else if (error == OTA_END_ERROR) Serial.println(“End Failed”);
src\main.cpp:60:20: error: no matching function for call to ‘ArduinoOTAMdnsClass<WiFiServer, WiFiClient, WiFiUDP>::begin()’
ArduinoOTA.begin();
In file included from src\main.cpp:5:0:
C:/Users/lesko/.platformio/lib/ArduinoOTA_ID6178/src/ArduinoOTA.h:91:8: note: candidate: void ArduinoOTAMdnsClass<NetServer, NetClient, NetUDP>::begin(IPAddress, const char*, const char*, OTAStorage&) [with NetServer = WiFiServer; NetClient = WiFiClient; NetUDP = WiFiUDP]
void begin(IPAddress localIP, const char* name, const char* password, OTAStorage& storage) {
C:/Users/lesko/.platformio/lib/ArduinoOTA_ID6178/src/ArduinoOTA.h:91:8: note: candidate expects 4 arguments, 0 provided
Compiling .pio\build\esp32doit-devkit-v1\lib527\WiFi101_ID299\WiFi.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib527\WiFi101_ID299\WiFiClient.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib527\WiFi101_ID299\WiFiMDNSResponder.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib527\WiFi101_ID299\WiFiSSLClient.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\lib527\WiFi101_ID299\WiFiServer.cpp.o
*** [.pio\build\esp32doit-devkit-v1\src\main.cpp.o] Error 1
C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFiMDNSResponder.cpp:24:26: fatal error: avr/pgmspace.h: No such file or directory
compilation terminated.
*** [.pio\build\esp32doit-devkit-v1\lib527\WiFi101_ID299\WiFiMDNSResponder.cpp.o] Error 1
In file included from C:\Users\lesko.platformio\packages\framework-arduinoespressif32\tools\sdk\include\newlib/time.h:10:0,
from C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFi.cpp:28:
C:\Users\lesko.platformio\packages\framework-arduinoespressif32\tools\sdk\include\newlib/sys/unistd.h:30:9: error: conflicting declaration of C function ‘int close(int)’
int _EXFUN(close, (int __fildes ));
In file included from C:\Users\lesko.platformio\lib\WiFi101_ID299\src\utility/WiFiSocket.h:24:0,
from C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFi.cpp:36:
C:\Users\lesko.platformio\lib\WiFi101_ID299\src/socket/include/socket.h:1839:15: note: previous declaration ‘sint8 close(SOCKET)’
NMI_API sint8 close(SOCKET sock);
In file included from C:\Users\lesko.platformio\packages\framework-arduinoespressif32\tools\sdk\include\newlib/stdio.h:29:0,
from C:\Users\lesko.platformio\packages\framework-arduinoespressif32\cores\esp32/Arduino.h:27,
from C:\Users\lesko.platformio\lib\WiFi101_ID299\src\utility/WiFiSocket.h:28,
from C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFiClient.cpp:20:
from C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFiServer.cpp:20:
C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFi.cpp: In member function ‘int WiFiClass::init()’:
C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFi.cpp:303:46: error: invalid conversion from ‘void ()(uint8_t, uint32_t) {aka void ()(unsigned char, unsigned int)}’ to ‘tpfAppResolveCb {aka void ()(unsigned
char, long unsigned int)}’ [-fpermissive]
registerSocketCallback(socket_cb, resolve_cb);
C:\Users\lesko.platformio\lib\WiFi101_ID299\src/socket/include/socket.h:1047:14: note: initializing argument 2 of ‘void registerSocketCallback(tpfAppSocketCb, tpfAppResolveCb)’
NMI_API void registerSocketCallback(tpfAppSocketCb socket_cb, tpfAppResolveCb resolve_cb);
C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFi.cpp: At global scope:
C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFi.cpp:1133:10: error: prototype for ‘uint32_t WiFiClass::getTime()’ does not match any in class ‘WiFiClass’
In file included from C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFi.cpp:38:0:
C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFi101.h:157:16: error: candidate is: long unsigned int WiFiClass::getTime()
unsigned long getTime();
*** [.pio\build\esp32doit-devkit-v1\lib527\WiFi101_ID299\WiFiClient.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib527\WiFi101_ID299\WiFi.cpp.o] Error 1
In file included from C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFiClient.h:28:0,
from C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFiSSLClient.h:23,
from C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFiSSLClient.cpp:20:
C:\Users\lesko.platformio\lib\WiFi101_ID299\src\socket/include/socket.h:1839:32: error: conflicting declaration of C function ‘sint8 close(SOCKET)’
from C:\Users\lesko.platformio\lib\WiFi101_ID299\src\WiFiClient.h:23,
C:\Users\lesko.platformio\packages\framework-arduinoespressif32\tools\sdk\include\newlib/sys/unistd.h:30:9: note: previous declaration ‘int close(int)’
*** [.pio\build\esp32doit-devkit-v1\lib527\WiFi101_ID299\WiFiServer.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\lib527\WiFi101_ID299\WiFiSSLClient.cpp.o] Error 1
