Hallo,
I am new to ESP32 and I’ve never worked with BT(E) before, but I’ve some experience with Arduino.
I bought the Doit ESP32 DevKit.
The first big question for me was to choose the proper framework.
I decided to go for framework = arduino, espidf as it’s somewhat of a compatibility mode. I can have all the low level APIs from esp-idf but most the time I can use the Arduino libs.
I created a test project and trying to establish a BLE connection with a smartphone/computer to exchange data. I’ve huge configuration files and it’s probably a good idea to send the whole yml in a next step via BLE.
I created a small test project and followed some examples I’ve found on Github.
The first thing, I find strange, is that ~73% of my flash memory is gone, when using BLE. Is that possible?
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino, espidf)
PLATFORM: Espressif 32 (5.2.0) > DOIT ESP32 DEVKIT V1
- framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
- framework-espidf @ 3.40402.0 (4.4.2)
- tool-cmake @ 3.16.4
- tool-esptoolpy @ 1.40201.0 (4.2.1)
- tool-ninja @ 1.9.0
Warning! Arduino framework as an ESP-IDF component doesn't handle the `variant` field! The default `esp32` variant will be used.
Found 2 compatible libraries
|-- InterruptButton @ 1.0.0
Compiling .pio/build/esp32doit-devkit-v1/src/main.o
Linking .pio/build/esp32doit-devkit-v1/firmware.elf
Retrieving maximum program size .pio/build/esp32doit-devkit-v1/firmware.elf
Checking size .pio/build/esp32doit-devkit-v1/firmware.elf
RAM: [= ] 11.3% (used 36944 bytes from 327680 bytes)
Flash: [======= ] 73.0% (used 765701 bytes from 1048576 bytes)
Building .pio/build/esp32doit-devkit-v1/firmware.bin
esptool.py v4.2.1
Creating esp32 image...
Merged 25 ELF sections
I activated Bluetooth (controller mode BLE only, Bluedroid dual-mode) and used the following code:
#include "freertos/task.h"
#include "driver/gpio.h"
#include "InterruptButton.h"
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
InterruptButton button(GPIO_NUM_0, 0);
#define SERVICE_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
class MyCallbacks : public BLECharacteristicCallbacks
void onWrite(BLECharacteristic *pCharacteristic)
std::string value = pCharacteristic->getValue();
if (value.length() > 0)
printf("*********\n");
printf("New value: %s\n", value.c_str());
// std::string response = "The answer is no!";
// pCharacteristic->writeValue(response.c_str(), response.length());
printf("*********\n\n");
void configureLed()
gpio_reset_pin(GPIO_NUM_2);
gpio_set_direction(GPIO_NUM_2, GPIO_MODE_INPUT_OUTPUT);
void callback()
uint8_t state = gpio_get_level(GPIO_NUM_2);
printf("Toggeling LED: %i\n", state);
gpio_set_level(GPIO_NUM_2, !state);
extern "C" void app_main()
configureLed();
button.bind(Event_KeyDown, &callback);
BLEDevice::init("MyESP32");
BLEServer *pServer = BLEDevice::createServer();
BLEService *pService = pServer->createService(SERVICE_UUID);
BLECharacteristic *pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID,
BLECharacteristic::PROPERTY_READ |
BLECharacteristic::PROPERTY_WRITE);
pCharacteristic->setCallbacks(new MyCallbacks());
pService->start();
BLEAdvertising *pAdvertising = pServer->getAdvertising();
pAdvertising->start();
while (1)
vTaskDelay(10 / portTICK_PERIOD_MS);
