Hi there,
I justed started with PIO and tested it with an ESP32 borad. Compiling und uploading seems to work. At least this is what PIO tells me:
PLATFORM: Espressif 32 1.11.1 > Espressif ESP32 Dev Module
PACKAGES: toolchain-xtensa32 2.50200.80 (5.2.0), tool-mkspiffs 2.230.0 (2.30), framework-arduinoespressif32 2.10004.191002 (1.0.4), tool-esptoolpy 1.20600.0 (2.6.0)
Found 29 compatible libraries
|-- <SPI> 1.0
|-- <TFT_eSPI> 1.4.21
| |-- <SPIFFS> 1.0
| | |-- <FS> 1.0
| |-- <SPI> 1.0
| |-- <FS> 1.0
Retrieving maximum program size .pio/build/esp32dev/firmware.elf
Checking size .pio/build/esp32dev/firmware.elf
RAM: [ ] 4.8% (used 15804 bytes from 327680 bytes)
Flash: [== ] 20.4% (used 266839 bytes from 1310720 bytes)
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: /dev/cu.SLAB_USBtoUART
Uploading .pio/build/esp32dev/firmware.bin
esptool.py v2.6
Serial port /dev/cu.SLAB_USBtoUART
Connecting........_
Chip is ESP32D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
MAC: 24:6f:28:af:e9:68
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 15872 bytes to 10319...
Wrote 15872 bytes (10319 compressed) at 0x00001000 in 0.3 seconds (effective 503.0 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 128...
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 2671.9 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 9169.6 kbit/s)...
Compressed 266960 bytes to 138333...
Wrote 266960 bytes (138333 compressed) at 0x00010000 in 3.4 seconds (effective 626.2 kbit/s)...
Leaving...
Hard resetting via RTS pin...
============================================================ [SUCCESS] Took 12.21 seconds ============================================================
When I test the same code with the Arduino IDE everything works as expetected. Any Idea?
Thanks a lot …
