Esp32 and updating xtensa toolchain 12
Hello
Recently I have been trying to update xtensa toolchain to 12 (or 11 but same result) to finally make use of c++ modules
Here is my recent ini file:
platform = espressif32@^6.4.0
build_unflags = -std=gnu++11
	-fmodules-ts
	-std=gnu++2a
platform_packages =
	framework-arduinoespressif32
	espressif/toolchain-xtensa-esp32@12.2.0+20230208
However any attempts ends up with tons of errors like these:
Any ideas if updating toolchain is possible? Do i need to update core as well? if so, then to which version?
Havae you tried what’s written in https://github.com/platformio/platform-espressif32/issues/1211 instead?
Yes I did but it turns out, error was somewhere else (the ini above works), I was able to partially use C++ 20 modules, some example
// Order of this is important, first module, then includes, then export
module;
#include <NimBLECharacteristic.h>
export module UARTWrapper;
export struct __attribute__((packed)) UartDataPacket {
	uint32_t dataLength;
	uint8_t data[256];
export struct __attribute__((packed)) UartBeginRequest {
	uint32_t baud;
	uint32_t config;
export class UARTWrapper {
	public:
	bool started;
	NimBLECharacteristic* bleCharacteristic;
	QueueDefinition* queue;
	UARTWrapper() {
		started = false;
		bleCharacteristic = nullptr;
		queue = xQueueGenericCreate(10, sizeof(UartDataPacket), queueQUEUE_TYPE_BASE);
	void begin(UartBeginRequest* request, NimBLECharacteristic* bleChar) {
	void onReceive() {
	static void sendQueue(void* p) {
	void end() {
	void send(UartDataPacket* pPacket) {
However there are several problems, perhaps with pio build scripts:
  1. Clean does not clean module cache, files like that remains:
  2. Probably build order isn’t correct because i am getting errors sometimes - am i correct pio build scripts would need update?:
UARTWrapper: error: failed to read compiled module: No such file or directory
UARTWrapper: note: compiled module file is 'gcm.cache/UARTWrapper.gcm'
UARTWrapper: note: imports must be built before being imported
UARTWrapper: fatal error: returning to the gate for a mechanical issue
  1. -fmodules-ts needs to be applied only for C++ files, is there a way to do so with pio ini? Adding this to build flags works but produces tons of warnings
  2. And current issues i am struggling with and unable to pinpoint:
src/AppSerial.cpp:17:8: internal compiler error: in write_location, at cp/module.cc:15635
   17 | export module AppSerial;
libbacktrace could not find executable to open
Would be nice to work out even partial support for modules, i have been waiting for this for a very long time :slight_smile:
Can you file an issue with Arduino-ESP32 so that they pull it in officially first?
I believe updating toolchain is not ready yet as besides the issues with modules, normal compilation gives pretty high amount of warnings. While my project did compile i did not test even a third of functions.
I have also pushed my module tests here: GitHub - kaminaris/Esp32DiagnosticDongle at modules-test
branch modules-test contains almost compiling code, at some point it even worked.
