Hi there,
I was using an ESP32 with Arduino framework and the BLE libraries:
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
The problem is that I want to advertise more than 8 services, and as I’m using Arduino framework I don’t have access to this macro in sdkconfig.h:
#define CONFIG_BT_GATT_MAX_SR_PROFILES 8
My first question is how can I change this?
I have never used ESP-IDF framework, I tried combining both frameworks in Platformio like this:
framework = arduino, espidf
The first error is with all the BLE configuration, as an example:
#include <ble_uuids.h>
class MyBLEProfile
public:
MyBLEProfile() {}
BLEService *deviceService;
… code continues
Here I have the first error:
src/BLE_profile.h:20:5: error: ‘BLEService’ does not name a type
Any suggestion? Mainly I just want to use more than 8 services, but it would be also interesting to be able to use ESP-IDF framework.
Thank you.
pablogonzaleziei:
Yes exactly like this.
Can you clone platform-espressif32/examples/espidf-arduino-blink at develop · platformio/platform-espressif32 · GitHub as a base project and try to make the changes from there?
Note that you can get the base config from esp32-arduino-lib-builder/configs/defconfig.esp32 at master · espressif/esp32-arduino-lib-builder · GitHub .
So the first thing I notice when cloning the project is that the sdkconfig on my project has way more configurations. I found out that BLEDevice.h needs CONFIG_BLUEDROID_ENABLED to be enabled, this option is actually deprecated, maybe that’s why I can’t use it in the cloned project “espidf-arduino-blink”, I checked the sdkconfig.h of this project and I don’t find it. I also don’t find CONFIG_BT_GATT_MAX_SR_PROFILES.
Yeah… I think you wanna copy https://raw.githubusercontent.com/espressif/arduino-esp32/72c41d09538663ebef80d29eb986cd5bc3395c2d/tools/sdk/esp32/sdkconfig as your starting sdkconfig after all and modify it. Delete all previous sdkconfig files in the project before that.
