ESp2 s3 Amoled 1.75 setup
Hello, I try to build a project with the esp32 S3 amoled touch 1.75 from waveshare and I try to use platformio for it.
I have tried using the following ressource of the official waveshare : Setup Arduino IDE
Then I tried a default code that works that just print a timer and it works well. Then I would like to add some Wifi functionalities and there is a issue.
This is the platformio.ini:
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
; Display configuration
board_build.partitions = default.csv
board_build.f_flash = 80000000L
board_build.flash_mode = qio
; Memory settings
board_upload.flash_size = 16MB
board_upload.maximum_ram_size = 327680
; Monitor settings
monitor_dtr = 1          ; Important pour ESP32
monitor_rts = 1
; Upload settings
upload_speed = 460800
	-I include
    -DBOARD_HAS_PSRAM
    -mfix-esp32-psram-cache-issue
	-DLV_CONF_INCLUDE_SIMPLE
    Wifi
    lvgl/lvgl@^8.4.0
    lewisxhe/SensorLib@^0.3.1
    moononournation/GFX Library for Arduino@1.6.0
    lzw655/ESP32_IO_Expander@^1.1.0
    lewisxhe/XPowersLib@^0.2.6
    https://github.com/ricmoo/QRCode.git
    https://github.com/espressif/arduino-esp32.git
And this is the code that don’t work :
#include "Arduino_GFX_Library.h"
#include "pin_config.h"
#include <Wire.h>
#include <time.h>
#include <Preferences.h>
#include <WiFi.h>
#include <qrcode.h>
Arduino_DataBus *bus = new Arduino_ESP32QSPI(
  LCD_CS, LCD_SCLK, LCD_SDIO0, LCD_SDIO1,
  LCD_SDIO2, LCD_SDIO3);
// CO5300 driver - 466x466
Arduino_CO5300 *gfx = new Arduino_CO5300(
  bus,           // DataBus
  LCD_RESET,     // RST pin
  0,             // Rotation (0, 1, 2, 3)
  false,         // IPS mode (false pour ce modèle)
  LCD_WIDTH,     // Largeur
  LCD_HEIGHT,    // Hauteur
  6,             // col_offset1
  0,             // row_offset1
  0,             // col_offset2
  0              // row_offset2
unsigned long lastUpdate = 0;
const unsigned long UPDATE_INTERVAL = 1000;
void QRcode_generation(const char *text, int x, int y, int size) {
  QRCode qrcode;
  uint8_t qrcodeData[qrcode_getBufferSize(3)];
  qrcode_initText(&qrcode, qrcodeData, 3, ECC_LOW, text);
  for (int i = 0; i < qrcode.size; i++) {
    for (int j = 0; j < qrcode.size; j++) {
      if (qrcode_getModule(&qrcode, j, i)) {
        gfx->fillRect(x + j * size, y + i * size, size, size, RGB565_BLACK);
      } else {
        gfx->fillRect(x + j * size, y + i * size, size, size, RGB565_WHITE);
void setup(void) {
  delay(1500);
  Wire.begin(IIC_SDA, IIC_SCL);
  if (!gfx->begin()) {
    Serial.println("gfx->begin() failed!");
    return;
  gfx->fillScreen(RGB565_BLACK);
  gfx->setBrightness(255);
  // Initialisez l'heure du système (optionnel)
  configTime(0, 0, "pool.ntp.org", "time.nist.gov");
  Serial.println("Horloge ready!");
  QRcode_generation("https://example.com", 10, 10, 5);
  delay(4000);
When I try to upload this I got the error :
In file included from .pio/libdeps/esp32-s3-devkitc-1/ArduinoOTA/src/ArduinoOTA.cpp:20:
.pio/libdeps/esp32-s3-devkitc-1/ArduinoOTA/src/ArduinoOTA.h:18:10: fatal error: Network.h: No such file or directory
* Looking for Network.h dependency? Check our library registry!
* CLI  > platformio lib search "header:Network.h"
* Web  > https://registry.platformio.org/search?q=header:Network.h
 #include "Network.h"
I saw on some feed that I can use a custom opensource platform of dev but it doesn’t work too I have issue with the FreeRtos.h
Does someone knows how can I do it ?
Thanks in advanced !!
No. You can’t just add the latest Arduino-ESP32 arduino core as a “libary”. This a framework and compiling it is handled by the platform. If you need the latest Arduino-ESP32 core, set your platform as PIOArduino per https://github.com/pioarduino/platform-espressif32. Remove it from lib_deps.
This is wrongly written for WiFi, which is a builtin library of the Arduino core, which means that it shouldn’t appear in that list at all.
First thanks for the response, I modify what you told me to have this platformio.ini:
platform = https://github.com/espressif/arduino-esp32.git
; Memory settings
; Monitor settings
monitor_rts = 1
; Upload settings
	-I include
    -DBOARD_HAS_PSRAM
    lvgl/lvgl@^8.4.0
This is the result that I get, how can I do it because I use the esp32 s3 and on paltformio it’s hard to find documentation.
Processing esp32-s3-devkitc-1 (platform: https://github.com/espressif/arduino-esp32.git; board: esp32-s3-devkitc-1; framework: arduino)
Platform Manager: Installing git+https://github.com/espressif/arduino-esp32.git
git version 2.52.0.windows.1
Cloning into 'C:\Users\robin\.platformio\.cache\tmp\pkg-installing-d1_u_58e'...
remote: Enumerating objects: 3316, done.
remote: Counting objects: 100% (3316/3316), done.
remote: Compressing objects: 100% (2311/2311), done.
remote: Total 3316 (delta 802), reused 2015 (delta 563), pack-reused 0 (from 0)
Receiving objects: 100% (3316/3316), 58.57 MiB | 13.83 MiB/s, done.
Resolving deltas: 100% (802/802), done.
Updating files: 100% (2584/2584), done.
MissingPackageManifestError: Could not find one of 'platform.json' manifest files in the package
 *  The terminal process "C:\Users\robin\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'esp32-s3-devkitc-1'" terminated with exit code: 1.
How can I do ?
No, you misunderstood my post. I told you to use PIOArduino if you want the latest Arduino-ESP32 core. You cannot set the Arduino-ESP32 git url as your platform.
Please review https://github.com/pioarduino/platform-espressif32 carefully. To get Arduino-ESP32 3.3.9, you can e.g. set
platform = https://github.com/pioarduino/platform-espressif32/releases/download/55.03.39/platform-espressif32.zip
