Okay, so you connect the ESP-Prog to the board and connect the PC to the ESP-Prog. ESP-Prog handles the boot mode thing with IO0. My Devkit has 12, 13, 14 and 15 exposed, and I’d need to push the Boot button.
That’s as far as I get.
Does my debug output look like I have the pins wrong?
This is the debug output:
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : clock speed 5000 kHz
Error: JTAG scan chain interrogation failed: all zeroes
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway…
Error: esp32.cpu0: IR capture error; saw 0x00 not 0x01
Warn : Bypassing JTAG setup events due to errors
Warn : target esp32.cpu0 examination failed
Warn : target esp32.cpu1 examination failed
Info : starting gdb server for esp32.cpu0 on pipe
Info : accepting ‘gdb’ connection from pipe
Error: Target not examined yet
Error executing event gdb-attach on target esp32.cpu0:
Is the target baord powered on its own?
Have you tried adding
debug_speed = 500
to the platformio.ini?
Are you sure every wire is connected correctly per ESP-Prog — PlatformIO v6.1 documentation? (Except VDD, the ESP-PROG shouldn’t power a power-hungry ESP32, the board should be connected via a USB cable to power).
I added debug speed.
I’ve tried it a few ways. Last time was USB into the ESP-Prog, wired FTDI style into the ESP32.
So I should get a USB power cable for the ESP32?
I’ve read that it helps to have the second VCC line turned on.
o_O double-powering is usually deadly. Differences in the supplied voltage can lead to really undesired currents flowing.
Yes. Just plug in a regular USB cable into the target ESP32 dev board and disconnect VCC between the esp-prog and target dev board (but keep common GND).
Thank you. This is a DOIT Devkit, with the boot button, by the way. It is plugged power-only into the PC, and a real USB is in the ESP Prog.
I just chose ‘Start debugging’ from Run.
Now it’s back to the original result:For bug reports, read
OpenOCD: Bug Reporting
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
DEPRECATED! use ‘adapter speed’ not ‘adapter_khz’
adapter speed: 5000 kHz
Error: unable to find a matching CMSIS-DAP device
Assertion failed!
Program: C:\Users\joema.platformio\packages\tool-openocd-esp32\bin\openocd.exe
File: …/src/jtag/core.c, Line 338
Expression: jtag_trst == 0
Remote communication error. Target disconnected.: Success.
The ESP-Prog is FTDI based, it makes no sense that it’s looking for a CMSIS-DAP device. Do you have
upload_protocol = esp-prog
debug_tool = esp-prog
in the platformio.ini?
I went online to confirm the pins and got the same result.
I did not have upload_protocol.
“Error: unable to find a matching CMSIS-DAP device”
debug_speed = 500
Wire
SD
SPI
WiFi
SPIFFS
esp_now
Arduino_JSON
prenticedavid/MCUFRIEND_kbv
arduino-libraries/NTPClient@^3.2.1
esphome/ESPAsyncWebServer-esphome@^2.1.0
adafruit/Adafruit GFX Library @ ^1.10.7
https://github.com/adafruit/Adafruit_BusIO.git
https://github.com/ImpulseAdventure/Arduino-TFT-Library-ILI9486.git
Please show the output of the project task “Advanced → Verbose Build”.
Sorry completely wrong instructions, it’s PlatformIO IDE for VSCode — PlatformIO latest documentation and Advanced → Verbose Upload.
Oh Jeez. Debug Console says the same thing it’s been saying, but Terminal says a whole lot of stuff I can’t understand.
What’s this:
section size addr
.rtc.text
0 1074528256
.rtc.dummy
0 1073217536
.rtc.force_fast
0 1073217536
.rtc.data
16 1342177792
.rtc_noinit
0 1342177808
.rtc.force_slow
0 1342177808
.iram0.vectors 1027 1074266112
.iram0.text 73591 1074267140
.dram0.data 20792 1073470304
.ext_ram_noinit
0 1065353216
.noinit
0 1073491096
.ext_ram.bss
0 1065353216
.dram0.bss 17944 1073491096
.flash.appdesc
256 1061158944
.flash.rodata 95764 1061159200
.flash.rodata_noload 14910 1061254964
.flash.text 500239 1074593824
.phyiram.20
97 1075094064
.phyiram.18
270 1075094164
.phyiram.19
144 1075094436
.phyiram.17
727 1075094580
.phyiram.0
43 1075095308
.phyiram.1
125 1075095352
.phyiram.2
542 1075095480
.phyiram.3
171 1075096024
.phyiram.4
255 1075096196
.phyiram.6
131 1075096452
.phyiram.7
511 1075096584
.phyiram.8
375 1075097096
.phyiram.9
142 1075097472
.phyiram.13
186 1075097616
.phyiram.12
235 1075097804
.phyiram.14
459 1075098040
.phyiram.16
114 1075098500
.phyiram.11
120 1075098616
.phyiram.15
186 1075098736
.phyiram.21
74 1075098924
.phyiram.22
49 1075099000
.phyiram.23
259 1075099052
.phyiram.24
135 1075099312
.iram0.text_end
1 1074340731
.iram0.data
0 1074340732
.iram0.bss
0 1074340732
.dram0.heap_start
0 1073509040
.xtensa.info
56 0
.comment
282 0
.xt.prop._ZN5Print17availableForWriteEv
36 0
.xt.prop._ZN6Stream9readBytesEPhj
36 0
.xt.prop._ZTV7TwoWire
12 0
.xt.lit._ZNSt8functionIFv18arduino_event_id_t20arduino_event_info_tEEC5ERKS3_
0 0
.xt.lit._ZN15WiFiEventCbListC5ERKS_
0 0
.xt.prop._ZNSt8functionIFv18arduino_event_id_t20arduino_event_info_tEEC5ERKS3_
0 0
.xt.prop._ZN15WiFiEventCbListC5ERKS_
0 0
.xt.prop._ZNSt14_Function_baseD2Ev
36 0
.xt.prop._ZNSt8functionIFv18arduino_event_id_t20arduino_event_info_tEEC2ERKS3_
60 0
.xt.prop._ZN15WiFiEventCbListC2ERKS_
36 0
.xt.lit._ZNKSt8functionIFv22hardwareSerial_error_tEEclES0_
0 0
.xt.prop._ZNKSt8functionIFv22hardwareSerial_error_tEEclES0_
48 0
.xt.prop._ZTV14HardwareSerial
12 0
.xt.lit._ZN9IPAddressD5Ev
0 0
.xt.prop._ZN9IPAddressD5Ev
0 0
.xt.prop._ZN9IPAddressD2Ev
36 0
.xt.prop._ZN9IPAddressD0Ev
36 0
.xt.prop._ZTV9IPAddress
12 0
.xt.lit._ZN5Print5writeEPKc
0 0
.xt.prop._ZN5Print5writeEPKc
48 0
.xt.lit._ZN6String4initEv
0 0
.xt.prop._ZN6String4initEv
36 0
.xt.prop._ZNK6String3lenEv
60 0
.xt.prop._ZN6String6setLenEi
72 0
.xt.lit._ZN3nvs4Lock4initEv
0 0
.xt.prop._ZN3nvs4Lock4initEv
72 0
.xt.prop._ZN14intrusive_listI14NVSHandleEntryE5eraseENS1_8iteratorE
84 0
.xt.lit._ZN14intrusive_listIN3nvs7Storage14NamespaceEntryEE17clearAndFreeNodesEv
0 0
.xt.lit._ZN19CompressedEnumTableIbLj1ELj256EE3setEjb
8 0
.xt.prop._ZN14intrusive_listIN3nvs7Storage14NamespaceEntryEE17clearAndFreeNodesEv
108 0
.xt.prop._ZN19CompressedEnumTableIbLj1ELj256EE3setEjb
60 0
.xt.prop._ZN14intrusive_listIN3nvs7Storage14NamespaceEntryEE9push_backEPS2_
60 0
.xt.prop._ZTVN3nvs15NVSHandleSimpleE
12 0
.xt.lit._ZN3nvs12NVSPartitionD5Ev
0 0
.xt.prop._ZN3nvs12NVSPartitionD5Ev
0 0
.xt.prop._ZN3nvs12NVSPartitionD2Ev
36 0
.xt.prop._ZN3nvs12NVSPartitionD0Ev
36 0
.xt.prop._ZTVN3nvs12NVSPartitionE
12 0
.xt.lit._ZN3nvs19NVSPartitionManagerD5Ev
0 0
.xt.prop._ZN3nvs19NVSPartitionManagerD5Ev
0 0
.xt.prop._ZN3nvs19NVSPartitionManagerD2Ev
36 0
.xt.prop._ZN3nvs19NVSPartitionManagerD0Ev
36 0
.xt.prop._ZN14intrusive_listIN3nvs12NVSPartitionEE5eraseENS2_8iteratorE
84 0
.xt.prop._ZN14intrusive_listIN3nvs15NVSHandleSimpleEE5eraseENS2_8iteratorE
84 0
.xt.prop._ZTVN3nvs19NVSPartitionManagerE
12 0
.xt.prop._ZN14intrusive_listIN3nvs8HashList13HashListBlockEE5eraseENS3_8iteratorE
84 0
.xt.lit._ZN3nvs4ItemC5EhNS_8ItemTypeEhPKch
0 0
.xt.lit._ZNK19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3getEj
8 0
.xt.lit._ZN19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3setEjS2_
8 0
.xt.prop._ZN3nvs4ItemC5EhNS_8ItemTypeEhPKch
0 0
.xt.prop._ZNK19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3getEj
60 0
.xt.prop._ZN19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3setEjS2_
60 0
.xt.prop._ZN3nvs20isVariableLengthTypeENS_8ItemTypeE
48 0
.xt.prop._ZN3nvs4ItemC2EhNS_8ItemTypeEhPKch
60 0
.xt.lit._ZN14intrusive_listIN3nvs4PageEE5clearEv
0 0
.xt.prop._ZN14intrusive_listIN3nvs4PageEE5clearEv
60 0
.xt.prop._ZN14intrusive_listIN3nvs4PageEE9push_backEPS1_
60 0
.xt.prop._ZN14intrusive_listIN3nvs4PageEE5eraseENS2_8iteratorE
84 0
.xt.prop._ZTISt9exception
12 0
.xt.prop._ZTISt9bad_alloc
12 0
.xt.prop._ZTVN10__cxxabiv117__class_type_infoE
12 0
.xt.prop._ZTVN10__cxxabiv120__si_class_type_infoE
12 0
.xt.prop._ZTISt17bad_function_call
12 0
.xt.prop._ZTVSt17bad_function_call
12 0
.xt.prop._ZTVSt9bad_alloc
12 0
.xt.lit._ZNK9__gnu_cxx24__concurrence_lock_error4whatEv
8 0
.xt.lit._ZNK9__gnu_cxx26__concurrence_unlock_error4whatEv
8 0
.xt.lit._ZN9__gnu_cxx24__concurrence_lock_errorD5Ev
8 0
.xt.lit._ZN9__gnu_cxx26__concurrence_unlock_errorD5Ev
8 0
.xt.lit._ZN9__gnu_cxx7__mutex4lockEv
8 0
.xt.lit._ZN9__gnu_cxx13__scoped_lockD5Ev
8 0
.xt.prop._ZNK9__gnu_cxx24__concurrence_lock_error4whatEv
48 0
.xt.prop._ZNK9__gnu_cxx26__concurrence_unlock_error4whatEv
48 0
.xt.prop._ZN9__gnu_cxx24__concurrence_lock_errorD5Ev
12 0
.xt.prop._ZN9__gnu_cxx26__concurrence_unlock_errorD5Ev
12 0
.xt.prop._ZN9__gnu_cxx7__mutex4lockEv
48 0
.xt.prop._ZN9__gnu_cxx13__scoped_lockD5Ev
12 0
.xt.prop._ZN9__gnu_cxx24__concurrence_lock_errorD2Ev
36 0
.xt.prop._ZN9__gnu_cxx26__concurrence_unlock_errorD2Ev
36 0
.xt.prop._ZN9__gnu_cxx24__concurrence_lock_errorD0Ev
36 0
.xt.prop._ZN9__gnu_cxx26__concurrence_unlock_errorD0Ev
36 0
.xt.prop._ZN9__gnu_cxx13__scoped_lockD2Ev
72 0
.xt.prop._ZTIN9__gnu_cxx24__concurrence_lock_errorE
12 0
.xt.prop._ZTIN9__gnu_cxx26__concurrence_unlock_errorE
12 0
.xt.prop._ZTVN9__gnu_cxx24__concurrence_lock_errorE
12 0
.xt.prop._ZTVN9__gnu_cxx26__concurrence_unlock_errorE
12 0
.debug_frame 116528 0
.debug_info 4937961 0
.debug_abbrev 415471 0
.debug_loc 850897 0
.debug_aranges 45488 0
.debug_ranges 109368 0
.debug_line 2104645 0
.debug_str 416477 0
Total 9729487
That’s just listing the size and address of every section in the ELF file. What’s more important is the very last bit where it should try to upload via the ESP-Prog and openocd.
It didn’t upload. Just built:
“C:\Users\joema.platformio\penv\Scripts\python.exe” “C:\Users\joema.platformio\packages\tool-esptoolpy\esptool.py” --chip esp32 elf2image --flash_mode dio --flash_freq 40m --flash_size 4MB -o .pio\build\esp32dev\firmware.bin .pio\build\esp32dev\firmware.elf
esptool.py v3.3
Creating esp32 image…
Merged 25 ELF sections
============================= [SUCCESS] Took 13.80 seconds =
Are you sure you’re executing the Advanced → Verbose Upload project task?
No, that was verbose build. It failed to connect. COM33 is in Device Manager. Pins are triple-checked against a tutorial pinout I found.
esptool.py v3.3
Serial port COM33
Connecting…
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: Troubleshooting - ESP32 - — esptool.py latest documentation
*** [upload] Error 2
If it’s using a COM port it isn’t trying to use the JTAG interface of the ESP-Prog at all. I’m baffled by how you have the platformio.ini here but it still tries to use an entirely different configuration. Are you sure you’re editing the platformio.ini of the active project? Or maybe you need to use the project environment switcher to switch to the correct project?
If that still doesn’t work, please show a screenshot of your VSCode window with the opened platfomio.ini.
Okay. This time I got the platform correct and selected "PIO Debug (Phoenix_Dashboard_Receiver).
I got the same error in the image above.
I went out into the Platformio menu and selected Verbose Upload.
Terminal is freaking out.
.debug_abbrev
476805 0
DEPRECATED! use 'adapter speed' not 'adapter_khz'
.debug_loc
1056367 0
adapter speed: 500 kHz
.debug_aranges
53488 0
Info : clock speed 500 kHz
.debug_ranges
141520 0
Error: JTAG scan chain interrogation failed: all ones
Error: Trying to use configured scan chain anyway...
.debug_line
2373771 0
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
.debug_str
596626 0
Total
11555823
Info : starting gdb server for esp32.cpu0 on 3333
"C:\Users\joema\.platformio\penv\Scripts\python.exe" "C:\Users\joema\.platformio\packages\tool-esptoolpy\esptool.py" --chip esp32 elf2image --flash_mode dio --flash_freq 40m --flash_size 4MB -o .pio\build\esp32dev\firmware.bin .pio\build\esp32dev\firmware.elf
esptool.py v3.3
Creating esp32 image...
<lambda>(["upload"], [".pio\build\esp32dev\firmware.bin"])
AVAILABLE: cmsis-dap, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Info : esp32.cpu0: Debug controller was reset.
CURRENT: upload_protocol = esp-prog
Info : esp32.cpu0: Core was reset.
openocd -d2 -s C:/Users/joema/.platformio/packages/tool-openocd-esp32/share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg -c "adapter_khz 500" -c "program_esp {{.pio\build\esp32dev\firmware.bin}} 0x1000Error: Couldn't halt target before SoC reset
0 embedded:startup.tcl:1162: Error: ** Unable to reset target **
verify" -c "proin procedure 'program_esp'
grin procedure 'program_error' called at file "C:/Users/joema/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp_common.cfg", line 93
am_at file "embedded:startup.tcl", line 1162
esp*** [upload] Error 1
{{C:/Users/joema/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/bin/bootloader_dio_40m.bin}} 0x1000 verify" -c "program_esp {{C:/Users/joema/Documents/PlatformIO/Projects/Phoenix_Dashboard_Receiver/.pio/build/esp32dev/partitions.bin}} 0x8000 verify" -c "program_esp {{C:/Users/joema/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin}} 0xe000 verify" -c "reset run; shutdown"
============================= [FAILED]
It’s at least trying to use the ESP-PROG now, but it can’t find the ESP32 connected to it. Can you temporarily set upload_protocol = esptool so that you can upload via the serial port again and upload platform-espressif32/examples/arduino-blink/src/Blink.cpp at develop · platformio/platform-espressif32 · GitHub to it? Your current program may use the JTAG GPIO pins or do something else. Then set upload_protocol = esp-prog again and retry.
If that does not work, double check that all cables are connected properly, including power via the USB cable to the target ESP32 board.
