I had the ESP-Prog debugger working a few weeks ago on a WeMos D1 Mini ESP32 board.
Now when I try to debug on the same board, I get errors saying “Failed to get flash maps(1073405888)” and “esp32.cpu0: Failed to write breakpoint instruction (-4)!”. Then the debugger aborts.
My platformio.ini:
[env:wemos_d1_mini32]
board = wemos_d1_mini32
debug_tool = esp-prog
paulstoffregen/OneWire@^2.3.6
milesburton/DallasTemperature@^3.9.1
bblanchon/ArduinoJson@^6.19.4
mcxiaoke/ESPDateTime@^1.0.4
Output from the Debug Console:
undefinedC:\Users\PatsCot\.platformio\packages\toolchain-xtensa-esp32\bin\xtensa-esp32-elf-gdb.exe: warning: Couldn't determine a path for the index cache directory.
Reading symbols from c:\Users\PatsCot\Documents\PlatformIO\Projects\XL200_Test_Probe\.pio\build\wemos_d1_mini32\firmware.elf...
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.11.0-esp32-20220411 (2022-04-11-08:48)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
DEPRECATED! use 'adapter speed' not 'adapter_khz'
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 5000 kHz
Info : starting gdb server for esp32.cpu0 on pipe
Info : esp32.cpu0: Target halted, PC=0x40144B52, debug_reason=00000000
Info : Set GDB target to 'esp32.cpu0'
Info : esp32.cpu1: Target halted, PC=0x400DA7C8, debug_reason=00000000
Warn : No symbols for FreeRTOS!
Info : esp32.cpu0: Target halted, PC=0x400803C0, debug_reason=00000001
Error: Failed to get flash maps (1073405888)!
Warn : Failed to get flash mappings (-4)!
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 320 KB
Info : Using flash bank 'esp32.cpu0.flash' size 320 KB
Error: Failed to get flash maps (327732)!
Info : Using flash bank 'esp32.cpu0.irom' size 0 KB
Info : Using flash bank 'esp32.cpu0.drom' size 0 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
0x40144b52 in __ssvfiscanf_r (rptr=<optimized out>, fp=<optimized out>, fmt0=<optimized out>, ap=...) at /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/stdio/vfscanf.c:1219
1219 /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/stdio/vfscanf.c: No such file or directory.
Warn : Error reading FreeRTOS thread 0x0 name!
Warn : Error reading FreeRTOS thread 0x18 name!
Info : esp32.cpu0: Core was reset.
Info : esp32.cpu0: Target halted, PC=0x40000400, debug_reason=00000000
Info : esp32.cpu1: Core was reset.
Info : esp32.cpu1: Target halted, PC=0x40000400, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x400003C0, debug_reason=00000001
Warn : Empty flash mapping!
Warn : Failed to get flash mappings (0)!
Error: Failed to get flash size!
Error: Failed to probe flash, size 0 KB
Error: auto_probe failed
Error: Failed to find bank 'esp32.cpu1.flash'!
auto_probe failed
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Target halted, PC=0x500000CF, debug_reason=00000000
Info : esp32.cpu1: Debug controller was reset.
auto_probe failed
auto_probe failed
auto_probe failed
Temporary breakpoint 1 at 0x400d4ae4: file src/main.cpp, line 261.
PlatformIO: Resume the execution to `debug_init_break = tbreak setup`
PlatformIO: More configuration options -> https://bit.ly/pio-debug
Warn : address 0x400d4ae4 not writable
Error: esp32.cpu0: Failed to write breakpoint instruction (-4)!
Error: esp32.cpu0: Failed to add SW breakpoint!
Error: can't add breakpoint: unknown reason
Warn : address 0x400d9d2a not writable
Warn : address 0x400d9d8a not writable
Warning:
Cannot insert breakpoint 1.
Cannot access memory at address 0x400d4ae4
Cannot insert breakpoint 2.
Cannot access memory at address 0x400d9d2a
Cannot insert breakpoint 3.
Cannot access memory at address 0x400d9d8a
Command aborted.
(maxgerhardt is my hero)
