I looked at all the posts on this forum concerning esp-prog/esp32. Also explored several other youbube vids.
I followed the youtube vid:
Use the PIO Debugger on the ESP32 uing the esp-prog by Brian Lough.
I’m using ESP-WROOM-32 with the esp-prog (FT2232HL).
I installed FTDI and Zadig and verified all was fine in the DevMgr.
I connect 2 USB cables, 1 to esp32 (COM7) the other to esp-prog(COM9)
The PIO.ini file is:
;upload_port = COM9
;build_type = debug
debug_tool = esp-prog
The blink code builds successfully but won’t upload.
The following is the upload file:
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (1.11.2) > Espressif ESP32 Dev Module
Found 29 compatible libraries
Building in debug mode
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [ ] 4.7% (used 15356 bytes from 327680 bytes)
Flash: [== ] 16.1% (used 211029 bytes from 1310720 bytes)
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: COM9
Uploading .pio\build\esp32dev\firmware.bin
esptool.py v2.6
Serial port COM9
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
*** [upload] Error 2
================================================================================================================= [FAILED] Took 28.37 seconds =================================================================================================================
The terminal process "C:\Users\jake\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
Concerns:
- From what I’ve gleaned from other posts is that one of the USB connections can be removed but I’m not sure which to remove. I tried and got weird output.
- If I remove esp-prog board COM9 do I have to power board via 3v3?
