Problem Summery
I am using an ESP32-S2 board (devkitM-1U) [uses the ‘saola’ board def] with a esp-prog debugger board and I cannot seem to get the two working together. It seems that the esp-prog detects the esp32s2, halts it correctly, but then cannot read any form of flash memory from it. I admit that I am new to the concepts of JTAG, but I am to presume (put simply) that it is a communication interface and the debugger needs the memory mapped before the program starts to be able to set watches or pretty much do anything.
Enviroment:
Windows 10 pro x64 bit.
VScode 1.56.2
PlatformIO core 5.1.1
PlatformIO home 3.3.4
esp framework version in the debug log. It is latest as of 5/20/21
Troubleshooting attempts:
I have followed the standard steps from the espressif website and even followed the popular referenced video tutorial on youtube (I forget the authors name). I have the FTDI VCP Drivers installed, along with the Zadig WinUSB drivers on both interface 0 and 1 (debugger/programmer channels). I restarted the computer to ensure the drivers were initializing correctly. The S2 revision of the board has different JTAG pins and so I made sure to find and connect them all (GPIO 39-42). I verified these connections multiple times with the online documentation. The jumpers on the esp prog are set to 5v for both boards (prog/esp).
The Test:
For the test, I wanted to run the debugger on my program. The program compiles and runs correctly, but there is a pointer variable that is being reset and I cannot source the problem for it. Hence, the debugger would help here.
I heard that inserting breakpoints in app_main()
can be finicky or cause problems, so instead, I put a breakpoint a bit deeper in the source where other stuff is happening. Regardless of where I put it though, this does not seem to matter much if the esp-prog cannot read the chip’s flash memory.
platformio.ini
[env:esp32-s2-saola-1]
board = esp32-s2-saola-1
framework = espidf
upload_port = COM4
debug_tool = esp-prog
This is the Debug Console output when run:
Processing esp32-s2-saola-1 (platform: espressif32; board: esp32-s2-saola-1; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32-s2-saola-1.html
PLATFORM: Espressif 32 (3.2.0) > Espressif ESP32-S2-Saola-1
HARDWARE: ESP32S2 240MHz, 320KB RAM, 4MB Flash
- framework-espidf 3.40200.210118 (4.2.0)
- tool-cmake 3.16.4
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- toolchain-esp32s2ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32s2 1.80400.210211 (8.4.0)
Found 1 compatible libraries
|-- <StepperDriver>
Building in debug mode
Generating project linker script .pio\build\esp32-s2-saola-1\esp32s2.project.ld
Linking .pio\build\esp32-s2-saola-1\firmware.elf
Retrieving maximum program size .pio\build\esp32-s2-saola-1\firmware.elf
Checking size .pio\build\esp32-s2-saola-1\firmware.elf
RAM: [ ] 2.9% (used 9648 bytes from 327680 bytes)
Flash: [= ] 14.1% (used 147722 bytes from 1048576 bytes)
========================= [SUCCESS] Took 28.60 seconds =========================
Reading symbols from C:\Users\admin\Documents\Github\C++\ESP32-S2-Saola\ESP32_S2_Saola1\.pio\build\esp32-s2-saola-1\firmware.elf...
done.
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.10.0-esp32-20201202 (2020-12-02-17:38)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
Info : FreeRTOS creation
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 5000 kHz
Info : JTAG tap: esp32s2.cpu tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : esp32s2: Debug controller was reset.
Info : esp32s2: Core was reset.
Warn : No symbols for FreeRTOS!
Info : esp32s2: Target halted, PC=0x40016102, debug_reason=00000000
Info : Detected ESP32-S2 chip
Info : esp32s2: Target halted, PC=0x400314BA, debug_reason=00000001
Warn : Empty flash mapping!
Warn : Failed to get flash mappings (0)!
Info : Auto-detected flash bank 'esp32s2.flash' size 4096 KB
Info : Using flash bank 'esp32s2.flash' size 4096 KB
Info : Using flash bank 'esp32s2.irom' size 0 KB
Error: Target not examined yet
Error: Failed to wait algorithm (-4)!
Error: failed to restore 28 bytes of working area at address 0x400314a4
Error: failed to restore 1024 bytes of working area at address 0x3ffe007c
Error: failed to restore 5284 bytes of working area at address 0x40030000
Error: failed to restore 124 bytes of working area at address 0x3ffe0000
Error: Algorithm run failed (-4)!
Error: Failed to run flasher stub (-4)!
Info : Using flash bank 'esp32s2.drom' size 0 KB
0x400314a4 in ?? ()
Warn : Target not HALTED!
Error: Could not read FreeRTOS thread count from target!
Info : esp32s2: Target halted, PC=0x40012734, debug_reason=00000000
Info : esp32s2: Target halted, PC=0x40000400, debug_reason=00000000
** Programming Started **
** Programming Finished **
** Verify Started **
** Verified OK **
** Verified OK **
.pioinit:12: Error in sourced command file:
Remote communication error. Target disconnected.: Success.
