I am having an issue debugging ESP32 wrover based boards using the esp-prog and PIO. In all cases, running debug fails with the following errors after running for a minute and successfully reading and writing:
Error: ftdi device did not return all data: 0, expected 12
Error: error while flushing MPSSE queue: -4
Error: libusb_handle_events() failed with LIBUSB_ERROR_PIPE
I haven’t been able to find anything similar searching the forums. This happens no matter what code I use (including Blink), and no matter what board I use. I have tried:
- Changing ESP32 Wrover boards, tried both Lolin D32 Pro and a custom board
- Changing the adapter speed to 200Khz, 2Mhz, 5Mhz, 10Mhz, and 20Mhz
- Powering the ESP boards via the esp-prog at 5v or 3.3v
- Powering the ESP boards via USB
PIO ini:
board = esp-wrover-kit
-w
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
src_build_flags =
-Wall
board_build.f_flash = 80000000L
debug_tool = esp-prog
Full log:
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp-wrover-kit.html
PLATFORM: Espressif 32 1.12.2 > Espressif ESP-WROVER-KIT
DEBUG: Current (esp-prog) On-board (ftdi) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
Found 29 compatible libraries
Building in debug mode
Retrieving maximum program size .pio/build/esp-wrover-kit/firmware.elf
Checking size .pio/build/esp-wrover-kit/firmware.elf
RAM: [= ] 13.6% (used 44440 bytes from 327680 bytes)
Flash: [======= ] 65.8% (used 862398 bytes from 1310720 bytes)
========================= [SUCCESS] Took 3.57 seconds =========================
Reading symbols from /Users/.../Documents/.../.pio/build/esp-wrover-kit/firmware.elf...
done.
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.10.0-esp32-20190708 (2019-07-08-11:04)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 10000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 10000 kHz
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : Detected debug stubs @ 3ffc2efc on core0 of target 'esp32'
Error: No symbols for FreeRTOS
Info : Target halted. PRO_CPU: PC=0x4014F472 (active) APP_CPU: PC=0x400D747E
Info : Target halted. PRO_CPU: PC=0x400916EE (active) APP_CPU: PC=0x400D747E
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 198 KB
Info : Flash mapping 1: 0x50018 -> 0x400d0018, 513 KB
Info : Auto-detected flash size 8192 KB
Info : Using flash size 8192 KB
Info : Using flash size 516 KB
Info : Using flash size 200 KB
0x4014f472 in pm_rx_beacon_process ()
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core 0 was reset (pwrstat=0x1F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
** Programming Started **
auto erase enabled
auto erase enabled
Info : Target halted. PRO_CPU: PC=0x400916EE (active) APP_CPU: PC=0x40000400
wrote 16384 bytes from file /Users/nick/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_80m.bin in 0.860183s (18.601 KiB/s)
** Programming Finished **
** Verify Started **
read 15856 bytes from file /Users/nick/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin/bootloader_dio_80m.bin and flash bank 0 at offset 0x00001000 in 0.326285s (47.457 KiB/s)
contents match
contents match
** Verified OK **
** Verified OK **
auto erase enabled
auto erase enabled
wrote 4096 bytes from file /Users/nick/Documents/ESPLED/Arduino/ESP32_Artnet/.pio/build/esp-wrover-kit/partitions.bin in 0.659934s (6.061 KiB/s)
read 3072 bytes from file /Users/nick/Documents/ESPLED/Arduino/ESP32_Artnet/.pio/build/esp-wrover-kit/partitions.bin and flash bank 0 at offset 0x00008000 in 0.290918s (10.312 KiB/s)
contents match
contents match
** Verified OK **
** Verified OK **
auto erase enabled
auto erase enabled
wrote 8192 bytes from file /Users/nick/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin in 0.727178s (11.001 KiB/s)
read 8192 bytes from file /Users/nick/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin and flash bank 0 at offset 0x0000e000 in 0.299664s (26.697 KiB/s)
contents match
contents match
** Verified OK **
** Verified OK **
auto erase enabled
auto erase enabled
.pioinit:15: Error in sourced command file:
