ESP PROG Debug error
Hello .
My hardware : debug (JTAG) esp32 wroom-doit-kit using esp-prog.
It all worked pretty well , until it (debug) stoped working.
log from debug console:
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32dev; framework: espidf)
PLATFORM: Espressif 32 1.11.1 > Espressif ESP32 Dev Module
PACKAGES: toolchain-xtensa32 2.50200.80 (5.2.0), framework-espidf 3.30300.190916 (3.3.0), tool-esptoolpy 1.20600.0 (2.6.0)
Found 0 compatible libraries
Building in debug mode
Retrieving maximum program size .pio\build\esp32doit-devkit-v1\firmware.elf
Checking size .pio\build\esp32doit-devkit-v1\firmware.elf
DATA:    [          ]   3.8% (used 12400 bytes from 327680 bytes)
PROGRAM: [==        ]  21.3% (used 223652 bytes from 1048576 bytes)
========================= [SUCCESS] Took 22.30 seconds =========================
Reading symbols from c:\Users\moran\Documents\PlatformIO\Projects\uDiscrete-2\.pio\build\esp32doit-devkit-v1\firmware.elf...
done.
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger  v0.10.0-esp32-20190708 (2019-07-08-11:04)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
Warn : Bypassing JTAG setup events due to errors
Error: No symbols for FreeRTOS
Error: Target not examined yet
Error: Target not halted
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
Error: error during select: Unknown error
Warn : Flash driver of esp32.flash does not support free_driver_priv()
Warn : Flash driver of irom does not support free_driver_priv()
Warn : Flash driver of drom does not support free_driver_priv()
.pioinit:15: Error in sourced command file:
Remote communication error.  Target disconnected.: No error.
I’ve also tried to update
pio update
get :
no debug adapter
Please advise.
Thanks in advance’
Moran.
The log indicates you have a working communication between Visual Studio Code, gdb, OpenOCD and your debug probe (whatever make it is). The problem is between the debug probe and your ESP32 board.
Can you show how you wired it?
ESP32_JTAG_Signals
I remind you that it worked for a while.
The fact it has worked before indicates that you have changed something or that you have unreliable connections. So:
  • Check that the wiring between ESP-Prog and ESP makes good contact and is reliably working.
  • Power the ESP via USB and disconnect the VDD/3V3 between ESP-Prog and ESP
  • Make sure your firmware doesn’t use any of the JTAG pins (IO12 to IO15)
BTW: What ESP32 board do you have? Is it a DOIT board?
Yes - DOIT board.
Thanks I’ll go over all JTAG wires again
OK it is working now. probably it was wiring issue.
I’ve just take out all wires and connect them again and it started to play.
Thanks for your help.
