ESP-NOW Web Server Error
I’m currently working on an ESP-Now project where I’m creating a web server to control several relays.
I have the following error in the receiver code:
*** [.pio\build\upesy_wroom\firmware.elf] Error 1
This is what my code looks like. I was looking into it and I’m not sure if its a driver issue or something in my code. I’m very new to all of this and don’t really know what I’m doing.
#include <esp_now.h>
#include <WiFi.h>
#include <FS.h>
#include "ESPAsyncWebServer.h"
// Set to true to define Relay as Normally Open (NO)
#define RELAY_NO    true
// Set number of relays
#define NUM_RELAYS  8
// Assign each GPIO to a relay
int relayGPIOs[NUM_RELAYS] = {19, 18, 5, 17, 16, 4, 2, 15};
// Structure example to receive data
// Must match the sender structure
typedef struct struct_message {
    char a[32];
    int b;
    float c;
    bool d;
} struct_message;
// Create a struct_message called myData
struct_message myData;
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
  memcpy(&myData, incomingData, sizeof(myData));
  Serial.print("Bytes received: ");
  Serial.println(len);
  Serial.print("Char: ");
  Serial.println(myData.a);
  Serial.print("Int: ");
  Serial.println(myData.b);
  Serial.print("Float: ");
  Serial.println(myData.c);
  Serial.print("Bool: ");
  Serial.println(myData.d);
  Serial.println();
  // Initialize Serial Monitor
  // Set device as a Wi-Fi Station
  WiFi.mode(WIFI_STA);
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  // Once ESPNow is successfully Init, we will register for recv CB to
  // get recv packer info
  esp_now_register_recv_cb(OnDataRecv);
That’s not the real error message. That would be the one coming one line before it, which you didn’t show.
Plugging your code in a new project with the following platformio.ini (which you also didn’t show the version you’re using):
[env:upesy_wroom]
board = upesy_wroom
   ottowinter/ESPAsyncWebServer-esphome@^3.0.0
you indeed get the error
c:/users/max/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/bin/…/lib/gcc/xtensa-esp32-elf/8.4.0/…/…/…/…/xtensa-esp32-elf/bin/ld.exe: .pio\build\upesy_wroom\libFrameworkArduino.a(main.cpp.o):(.literal._Z8loopTaskPv+0x8): undefined reference to loop()' c:/users/max/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\upesy_wroom\libFrameworkArduino.a(main.cpp.o): in function loopTask(void*)‘:
C:/Users/Max/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp:48: undefined reference to `loop()’
In which it says
Arduino sketches must define both setup() and loop() functions. Even if you don’t plan on doing anything in the loop() functions since you have that callback based ESP-NOW architecture, it must at least be defined as an empty function. Hence, adding
void loop() {}
to the bottom makes it compile succesfully.
When you look at the most prominent tutorial available online for ESP-NOW, you will see the same thing: Getting Started with ESP-NOW (ESP32 with Arduino IDE) | Random Nerd Tutorials
Main takeaway: Post error messages in full and read them carefully, post problems as minimal, self-contained projects with code and configuration file (platformio.ini).
