I’m having a heck of a time. I’ve run these programs, but they aren’t including the library.
PIO registry comes up with the wrong thing. The github address isn’t straightforward- it’s in the Espressif repository.
Does anyone know how to type it?
This is the code- and it worked already:
Rui Santos
Complete project details at https://RandomNerdTutorials.com/esp-now-esp32-arduino-ide/
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
#include <esp_now.h>
#include <WiFi.h>
// REPLACE WITH YOUR RECEIVER MAC Address
uint8_t broadcastAddress[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
// Structure example to send data
// Must match the receiver structure
typedef struct struct_message
char a[32];
int b;
float c;
String d;
bool e;
} struct_message;
// Create a struct_message called myData
struct_message myData;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status)
Serial.print("\r\nLast Packet Send Status:\t");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
void setup()
// Init Serial Monitor
Serial.begin(9600);
// Set device as a Wi-Fi Station
WiFi.mode(WIFI_STA);
// Init ESP-NOW
if (esp_now_init() != ESP_OK)
Serial.println("Error initializing ESP-NOW");
return;
// Once ESPNow is successfully Init, we will register for Send CB to
// get the status of Trasnmitted packet
esp_now_register_send_cb(OnDataSent);
// Register peer
esp_now_peer_info_t peerInfo;
memcpy(peerInfo.peer_addr, broadcastAddress, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
// Add peer
if (esp_now_add_peer(&peerInfo) != ESP_OK)
Serial.println("Failed to add peer");
return;
void loop()
// Set values to send
strcpy(myData.a, "THIS IS A CHAR");
myData.b = random(1, 20);
myData.c = 1.2;
myData.d = "Hello";
myData.e = false;
// Send message via ESP-NOW
esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *)&myData, sizeof(myData));
if (result == ESP_OK)
Serial.println("Sent with success");
else
Serial.println("Error sending the data");
delay(2000);
Monsterthews
I am new to PlatformIO/Arduino but wanted to try ESPP-Now myself.
so I did. First I used the “example sketch for Broadcast.”
#include <WifiEspNowBroadcast.h>
#if defined(ARDUINO_ARCH_ESP8266)
#include <ESP8266WiFi.h>
#elif defined(ARDUINO_ARCH_ESP32)
#include <WiFi.h>
static const int BUTTON_PIN = 0; // "flash" button on NodeMCU, Witty Cloud, etc
static const int LED_PIN = 2; // ESP-12F blue LED
int ledState = HIGH;
void
processRx(const uint8_t mac[6], const uint8_t* buf, size_t count, void* cbarg)
Serial.printf("Message from %02X:%02X:%02X:%02X:%02X:%02X\n", mac[0], mac[1], mac[2], mac[3],
mac[4], mac[5]);
for (size_t i = 0; i < count; ++i) {
Serial.print(static_cast<char>(buf[i]));
Serial.println();
digitalWrite(LED_PIN, ledState);
ledState = 1 - ledState;
void
setup()
Serial.println();
WiFi.persistent(false);
bool ok = WifiEspNowBroadcast.begin("ESPNOW", 3);
if (!ok) {
Serial.println("WifiEspNowBroadcast.begin() failed");
ESP.restart();
WifiEspNowBroadcast.onReceive(processRx, nullptr);
pinMode(BUTTON_PIN, INPUT_PULLUP);
pinMode(LED_PIN, OUTPUT);
Serial.print("MAC address of this node is ");
Serial.println(WiFi.softAPmacAddress());
Serial.println("Press the button to send a message");
void
sendMessage()
char msg[60];
int len = snprintf(msg, sizeof(msg), "hello ESP-NOW from %s at %lu",
WiFi.softAPmacAddress().c_str(), millis());
WifiEspNowBroadcast.send(reinterpret_cast<const uint8_t*>(msg), len);
Serial.println("Sending message");
Serial.println(msg);
Serial.print("Recipients:");
const int MAX_PEERS = 20;
WifiEspNowPeerInfo peers[MAX_PEERS];
int nPeers = std::min(WifiEspNow.listPeers(peers, MAX_PEERS), MAX_PEERS);
for (int i = 0; i < nPeers; ++i) {
Serial.printf(" %02X:%02X:%02X:%02X:%02X:%02X", peers[i].mac[0], peers[i].mac[1],
peers[i].mac[2], peers[i].mac[3], peers[i].mac[4], peers[i].mac[5]);
Serial.println();
void
loop()
if (digitalRead(BUTTON_PIN) == LOW) { // button is pressed
sendMessage();
while (digitalRead(BUTTON_PIN) == LOW) // wait for button release
WifiEspNowBroadcast.loop();
delay(10);
Create a new project.
Add this as the src - main.cpp
Add project library - yoursunny/WifiEspNow@^0.0.20190814
Checkk and run.
I have yet found out how to get the PlatformIO monitor to play nice (aside from adding to the .ini file – monitor_speed = 115200
so for output I used the Arduino monitor instead.)
