Hi all,
I wanted to use ESP-NOW for a project with the ESP32 thing, but simply calling esp_now_init() crashes the program and causes the guru meditation error.
I tried running an empty project, and it does not cause this error.
It might be incompatible with one of the peripherals I am using… I am using an I2C port, an SPI port and the ESP-PROG for debugging.
Any idea or reference for limitations for ESP-NOW that could explain this? I was thinking I should just use BLE instead but it looks more complicated to use between 2 ESP32 devices.
my .ini just in case:
[env:esp32thing]
board = esp32thing
; ESP32-PROG Environment (remove if uploading directly to ESP32)
debug_tool = esp-prog
debug_speed = 12000
upload_protocol = esp-prog
upload_port = COM14
; board_build.mcu = esp32
; board_build.f_cpu = 240000000L
-DTFT_MOSI=23
-DTFT_SCLK=18
-DUSER_SETUP_LOADED=1
-DST7789_DRIVER=1
-DTFT_WIDTH=240
-DTFT_HEIGHT=240
-DST7789_GREENTAB2=1
-DTFT_RST=2
-DTFT_CS=-1
-DTFT_DC=4
-DLOAD_GLCD=1
-DLOAD_FONT2=1
-DLOAD_FONT4=1
-DLOAD_FONT6=1
-DLOAD_FONT7=1
-DLOAD_FONT8=1
-DLOAD_FONT8N=1
-DLOAD_GFXFF=1
-DSMOOTH_FONT=1
-DSPI_FREQUENCY=27000000
; Project Libraries
bodmer/TFT_eSPI@^2.3.66
khoih-prog/ESP32TimerInterrupt@^1.0.3
pololu/VL53L1X@^1.3.0
