ESP-IDF new project build error
Hello, I’m a bit new with this world of c programming and I have stumble into a little problem I don’t understand how to solve.
I started a completly new project for esp32 with ESP-IDF in platformio. I write the command “pio run” to start a compilation and this appears:
PS C:\Repos\NAC-1\NAC-1> pio run
Processing esp32dev (platform: espressif32; board: esp32dev; framework: espidf)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via -v, --verbose option
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 (3.3.2) > Espressif ESP32 Dev Module
  • framework-espidf 3.40300.0 (4.3.0)
  • tool-cmake 3.16.4
  • tool-esptoolpy 1.30100.210531 (3.1.0)
  • tool-idf 1.0.1
  • tool-mconf 1.4060000.20190628 (406.0.0)
  • tool-ninja 1.9.0
  • toolchain-esp32ulp 1.22851.191205 (2.28.51)
  • toolchain-xtensa32 2.80400.210211 (8.4.0)
    WARNING: You are using pip version 21.1.2; however, version 21.2.4 is available.
    You should consider upgrading via the ‘c:\users\gpe.platformio\penv\scripts\python.exe -m pip install --upgrade pip’ command.
    Reading CMake configuration…
    Generating assembly for certificate bundle…
    CMake Error at C:/Users/GPE/.platformio/packages/framework-espidf/tools/cmake/scripts/data_file_embed_asm.cmake:26 (file):
    file failed to open for reading (No such file or directory):
    C:\Repos\NAC-1\NAC-1.pio\build\esp32dev\x509_crt_bundle
*** Error 1
Found 0 compatible libraries
Scanning dependencies…
*** [.pio\build\esp32dev.pio\build\esp32dev\x509_crt_bundle.o] Source .pio\build\esp32dev\x509_crt_bundle.S' not found, needed by target .pio\build\esp32dev.pio\build\esp32dev\x509_crt_bundle.o’.
I don’t understand what the problem is, can someone point me in the right direction?
Discussed in ESP-PROG - openocd path contains "undefined" - #10 by drk, bug in ESP-IDF, please search the forum first.
Thank you very much max! I found in this post the solution!
