Hi PlatformIO Community,
I wanted to start a project where I use esp-idf directly without going through Arduino. When trying to setup Bluetooth, I ran into the obnoxious problem of the copmiler not finding bt.h. The solution quoted on the forum is to run platformio run -t menuconfig and enable the respective configuration options. Unfortunately, running Menuconfig fails for me with the following output (German Windows 10 Pro, PlatformIO upgraded & updated to whatever is latest):
PS C:\Users\Damian\Documents\GitHub\WeatherEsp32> & C:\Users\Damian\.platformio\penv\Scripts\platformio.exe run -t menuconfig
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: espidf)
PLATFORM: Espressif 32 1.12.4 > DOIT ESP32 DEVKIT V1
- framework-espidf 3.40001.200521 (4.0.1)
- tool-cmake 3.16.4
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.190618 (2.28.51)
- toolchain-xtensa32 2.80200.200226 (8.2.0)
Found 0 compatible libraries
Running menuconfig...
[0/1] CMakeFiles\menuconfig-5f29641.bat bd8a8efa19fdd265
Python path configuration:
PYTHONHOME = (not set)
PYTHONPATH = 'C:\Users\Damian\.platformio\penv\Scripts\platformio.exe;c:\users\damian\.platformio\penv\scripts\python27.zip;c:\users\damian\.platformio\penv\DLLs;c:\users\damian\.platformio\penv\lib;c:\users\damian\.platformio\penv\lib\plat-win;c:\users\damian\.platformio\penv\lib\lib-tk;c:\users\damian\.platformio\penv\scripts;C:\Users\Damian\.platformio\python27\Lib;C:\Users\Damian\.platformio\python27\DLLs;C:\Users\Damian\.platformio\python27\Lib\lib-tk;c:\users\damian\.platformio\penv;c:\users\damian\.platformio\penv\lib\site-packages'
program name = 'python'
isolated = 0
environment = 1
user site = 1
import site = 1
sys._base_executable = 'C:\\Program Files (x86)\\Python38-32\\python.exe'
sys.base_prefix = 'C:\\Program Files (x86)\\Python38-32'
sys.base_exec_prefix = 'C:\\Program Files (x86)\\Python38-32'
sys.executable = 'C:\\Program Files (x86)\\Python38-32\\python.exe'
sys.prefix = 'C:\\Program Files (x86)\\Python38-32'
sys.exec_prefix = 'C:\\Program Files (x86)\\Python38-32'
sys.path = [
'C:\\Users\\Damian\\.platformio\\penv\\Scripts\\platformio.exe',
'c:\\users\\damian\\.platformio\\penv\\scripts\\python27.zip',
'c:\\users\\damian\\.platformio\\penv\\DLLs',
'c:\\users\\damian\\.platformio\\penv\\lib',
'c:\\users\\damian\\.platformio\\penv\\lib\\plat-win',
'c:\\users\\damian\\.platformio\\penv\\lib\\lib-tk',
'c:\\users\\damian\\.platformio\\penv\\scripts',
'C:\\Users\\Damian\\.platformio\\python27\\Lib',
'C:\\Users\\Damian\\.platformio\\python27\\DLLs',
'C:\\Users\\Damian\\.platformio\\python27\\Lib\\lib-tk',
'c:\\users\\damian\\.platformio\\penv',
'c:\\users\\damian\\.platformio\\penv\\lib\\site-packages',
'C:\\Program Files (x86)\\Python38-32\\python38.zip',
'C:\\Program Files (x86)\\Python38-32\\DLLs',
'C:\\Program Files (x86)\\Python38-32\\lib',
'C:\\Program Files (x86)\\Python38-32',
Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encoding
Python runtime state: core initialized
File "c:\users\damian\.platformio\penv\lib\encodings\__init__.py", line 123
raise CodecRegistryError,\
SyntaxError: invalid syntax
Current thread 0x00001e84 (most recent call first):
<no Python frame>
Batch file failed at line 3 with errorcode 1
FAILED: CMakeFiles/menuconfig
ninja: build stopped: subcommand failed.
Error: Couldn't execute 'menuconfig' target.
scons: *** [menuconfig] Explicit exit, status 1
=============================================================================================================== [FAILED] Took 8.13 seconds ===============================================================================================================
This error occurs no matter what shell I am using to run it. Options are PowerShell, cmd.exe, Git Bash. I found no mentions of the problem related to PlatformIO. However, general Google results for the CodecRegistryError point towards the wrong python installation being used. I do indeed have another systemwide Python 3.8 installation I use for other projects. When I run python from the command line, the system-wide installation is used.
I know that PlatformIO comes with its own Python 2.7 distribution. I cannot find that distribution on my PATH and frankly would like to keep it that way. Things run from the general command line should run using the system-wide installation under my personal control, not the separate Python distribution that is used to make PlatformIO work. However, I would have expected calls made through platformio.exe to use the “correct” Python enviornment - whatever Platformio.exe determines what that would be. From the above log, it appears to me that Platformio.exe is making subsequent calls using my systemwide python 3.8, despite listing the PlatformIO-integrated Python paths just a few lines above.
What can I do to fix this problem and make run -t menuconfig work?
Regards
Damian
