Hi all!
I’ve encountered a strange error with the menuconfig task (pio run -t menuconfig), where it fails to execute with the following error (full logs at the end):
%userprofile%/.platformio/packages/framework-espidf/components/esp_hw_support/Kconfig:17: syntax error
%userprofile%/.platformio/packages/framework-espidf/components/esp_hw_support/Kconfig:16: unknown option "rsource
Deleting .platformio/packages/framework-espidf and restarting VSCode appears to fix it, but it’s still a highly frustrating bug. Do older, wiser heads than mine have any suggestions, or should I open a bug report in the repo?
To reproduce, I merely need to restart VSCode. Sometimes even just adding a library will break it. [EDIT:] Running menuconfig more than once also breaks it now.
Full log (user profile path redacted):
$ pio run -t menuconfig
Processing defaults (platform: espressif32; board: esp32dev; framework: espidf)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (5.2.0) > Espressif ESP32 Dev Module
- framework-espidf @ 3.40402.0 (4.4.2)
- tool-cmake @ 3.16.4
- tool-esptoolpy @ 1.40201.0 (4.2.1)
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-ninja @ 1.9.0
Found 0 compatible libraries
Running menuconfig...
[0/1] cmd.exe /C "cd /D %userprofile%\OneDrive\Documents\VSCode_Projects\ESP32_RTK\.pio\build\defaults &...ENV_FPGA= --output config %userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/sdkconfig.defaults"Loading defaults file %userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/sdkconfig.defaults...
%userprofile%/.platformio/packages/framework-espidf/Kconfig:11:warning: environment variable IDF_ENV_FPGA undefined
%userprofile%/.platformio/packages/framework-espidf/components/esp_hw_support/Kconfig:16: unknown option "rsource"
FAILED: CMakeFiles/menuconfig
cmd.exe /C "cd /D %userprofile%\OneDrive\Documents\VSCode_Projects\ESP32_RTK\.pio\build\defaults && %userprofile%\.platformio\penv\Scripts\python.exe %userprofile%/.platformio/packages/framework-espidf/tools/kconfig_new/prepare_kconfig_files.py --env-file %userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/.pio/build/defaults/config.env && %userprofile%\.platformio\penv\Scripts\python.exe %userprofile%/.platformio/packages/framework-espidf/tools/kconfig_new/confgen.py --kconfig %userprofile%/.platformio/packages/framework-espidf/Kconfig --sdkconfig-rename %userprofile%/.platformio/packages/framework-espidf/sdkconfig.rename --config %userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/sdkconfig.defaults --defaults %userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/sdkconfig.defaults --env-file %userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/.pio/build/defaults/config.env --env IDF_TARGET=esp32 --env IDF_ENV_FPGA= --dont-write-deprecated --output config %userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/sdkconfig.defaults && %userprofile%\.platformio\packages\tool-cmake\bin\cmake.exe -E env COMPONENT_KCONFIGS_SOURCE_FILE=%userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/.pio/build/defaults/kconfigs.in COMPONENT_KCONFIGS_PROJBUILD_SOURCE_FILE=%userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/.pio/build/defaults/kconfigs_projbuild.in IDF_CMAKE=y KCONFIG_CONFIG=%userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/sdkconfig.defaults IDF_TARGET=esp32 IDF_ENV_FPGA= "C:/Program Files/Git/usr/bin/winpty.exe" "%userprofile%/.platformio/packages/tool-mconf/mconf-idf.exe" %userprofile%/.platformio/packages/framework-espidf/Kconfig && %userprofile%\.platformio\penv\Scripts\python.exe %userprofile%/.platformio/packages/framework-espidf/tools/kconfig_new/confgen.py --kconfig %userprofile%/.platformio/packages/framework-espidf/Kconfig --sdkconfig-rename %userprofile%/.platformio/packages/framework-espidf/sdkconfig.rename --config %userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/sdkconfig.defaults --defaults %userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/sdkconfig.defaults --env-file %userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/.pio/build/defaults/config.env --env IDF_TARGET=esp32 --env IDF_ENV_FPGA= --output config %userprofile%/OneDrive/Documents/VSCode_Projects/ESP32_RTK/sdkconfig.defaults"
ninja: build stopped: subcommand failed.
Error: Couldn't execute 'menuconfig' target.
scons: *** [menuconfig] Explicit exit, status 1
platformio.ini:
[env]
framework = espidf
upload_port = COM4
monitor_port = COM4
upload_speed = 921600
board_build.partitions = partitions.csv
build_unflags = -Werror=all
[env:defaults]
[EDIT 2]: It appears that the issue is in the project folder, not %userprofile%/.platformio. Performing a diff on the framework before and after menuconfig works shows no change. However, git tracking .pio (while menuconfig is open) and then reverting fixes menuconfig. The files only appear to change after menuconfig exits.
After running menuconfig once and exiting, only the sdkconfig.defaults (see my environment name) and a .ninja_log file are modified. However, after discarding these changes, menuconfig fails to run. This failure leaves a whole lot of changes - build.ninja, CMakeCache.txt, compile_commands.json, and head-ref are all changed. Additionally, target, codemodel, and index files are all replaced with a new one containing a different hash in the filename. Reverting these changes fixes menuconfig.
[YET ANOTHER EDIT]: Moved to PIO IDE because I accidentally posted in General instead.
