Hi guys, in my project I have barebone ESP32 MCU on custom PCB. It is connected to USB switch via generic FT232H USB<->JTAG converter. When I try to start debugging, hardware breakpoint is ignored completely. For a second, something appears in stack view, but then it vanishes.
I am left with empty debug view - no stack, no registers, nothing.
Debug console:
Reading symbols from /Users/username/Projects/SmartSense/main_esp_unit/.pio/build/esp32dev/firmware.elf...
done.
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.10.0-esp32-20210721 (2021-07-21-13:34)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 500 kHz
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 500 kHz
Warn : No symbols for FreeRTOS!
Info : esp32.cpu0: Target halted, PC=0x40009049, debug_reason=00000000
Info : Set GDB target to 'esp32.cpu0'
Info : esp32.cpu1: Target halted, PC=0x400076E0, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x400928DA, debug_reason=00000001
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 101 KB
Info : Flash mapping 1: 0x30020 -> 0x400d0020, 565 KB
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.irom' size 568 KB
Info : Using flash bank 'esp32.cpu0.drom' size 104 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
Warn : negative reply, retrying
0x40009049 in ?? ()
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Info : esp32.cpu0: Target halted, PC=0x500000CF, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x40000400, debug_reason=00000000
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : esp32.cpu1: Target halted, PC=0x40000400, debug_reason=00000000
Info : Auto-detected flash bank 'esp32.cpu1.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu1.flash' size 4096 KB
** Programming Started **
Info : PROF: Data transferred in 1119.08 ms @ 25.0206 KB/s
** Programming Finished **
** Verify Started **
** Verified OK **
** Verified OK **
Info : PROF: Data transferred in 171.394 ms @ 23.338 KB/s
** Verified OK **
** Verified OK **
Info : PROF: Data transferred in 31744.9 ms @ 24.3189 KB/s
** Verified OK **
** Verified OK **
Temporary breakpoint 1 at 0x400d32d8: file src/main.c, line 161.
PlatformIO: Resume the execution to `debug_init_break = tbreak app_main`
PlatformIO: More configuration options -> http://bit.ly/pio-debug
Note: automatically using hardware breakpoints for read-only addresses.
The weird thing is, that it worked before. I did some changes in platformio.ini to append more debug information, because I was not seeing function names for some addresses. I added:
-DCOMPONENT_EMBED_FILES=components/ss_mqtt/certs/ca.pem:components/ss_mqtt/certs/client.pem:components/ss_mqtt/certs/key.pem
-Og
-ggdb3
build_unflags = -Os
to platformio.ini. Then I battled with this error. I tried updating platformio, settings custom ESP-iDF version to the latest available on github and deleting .platformio directory completely.
Something had to broke the platformio. For some reason, I can not compile the code due to error linked above and in addition, I can not debug the code, because I am unable to set breakpoints.
Full platformio.ini:
framework = espidf
upload_protocol = esp-prog
-Og
-ggdb3
build_unflags = -Os
Do you have any idea how to solve the problem with debugging? Thank you for any suggestion.
