Hello All, I’m about at my wits end. yesterday all my code compiled fine. Now this morning I haven’t been able to get anything to compile. The only think I can think of that I did between last night and tonight is I started a new project now neither it or anything else using these same libraries and boards will compile.
I have gone as far as uninstalling both VSCode and PlatformIO and reinstalling also creating all new projects from scratch and only copying my main.cpp code in and letting pIO generate new files and (I assume) loading in the lib dependencies anew.
I’m not sure what exactly you need to help me trace the issue so I’ll start with the build errors.
Processing esp-wrover-kit (platform: espressif32; board: esp-wrover-kit; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp-wrover-kit.html
PLATFORM: Espressif 32 1.11.1 > Espressif ESP-WROVER-KIT
DEBUG: Current (ftdi) On-board (ftdi) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES: toolchain-xtensa32 2.50200.80 (5.2.0), framework-arduinoespressif32 2.10004.191002 (1.0.4), tool-esptoolpy 1.20600.0 (2.6.0)
Found 35 compatible libraries
|-- <WiFi> 1.2.7
| |-- <SPI> 1.0
|-- <HTTPClient> 1.2
| |-- <WiFi> 1.2.7
| | |-- <SPI> 1.0
| |-- <WiFiClientSecure> 1.0
| | |-- <WiFi> 1.2.7
| | | |-- <SPI> 1.0
|-- <ESP Async WebServer> 1.2.3 #f13685e
| |-- <AsyncTCP> 1.1.1 #ca8ac5f
| |-- <WiFi> 1.2.7
| | |-- <SPI> 1.0
|-- <EEPROM> 1.0.3
Compiling .pio\build\esp-wrover-kit\libc71\WiFiClientSecure\WiFiClientSecure.cpp.o
Compiling .pio\build\esp-wrover-kit\libc71\WiFiClientSecure\ssl_client.cpp.o
Compiling .pio\build\esp-wrover-kit\lib4e1\HTTPClient\HTTPClient.cpp.o
Archiving .pio\build\esp-wrover-kit\lib745\libAsyncTCP.a
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In constructor 'WiFiClientSecure::WiFiClientSecure()':
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:33:5: error: '_connected' was not declared in
this scope
_connected = false;
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In constructor 'WiFiClientSecure::WiFiClientSecure(int)':
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:50:5: error: '_connected' was not declared in
this scope
_connected = false;
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'WiFiClientSecure& WiFiClientSecure::operator=(const WiFiClientSecure&)':
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:80:5: error: '_connected' was not declared in
this scope
_connected = other._connected;
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:80:24: error: 'const class WiFiClientSecure' has no member named '_connected'
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'virtual void WiFiClientSecure::stop()':
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:89:9: error: '_connected' was not declared in
this scope
_connected = false;
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'int WiFiClientSecure::connect(const char*, uint16_t, const char*, const char*, const char*)':
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:136:5: error: '_connected' was not declared in this scope
_connected = true;
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'int WiFiClientSecure::connect(const char*, uint16_t, const char*, const char*)':
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:156:5: error: '_connected' was not declared in this scope
_connected = true;
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'virtual size_t WiFiClientSecure::write(const uint8_t*, size_t)':
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:185:10: error: '_connected' was not declared in this scope
if (!_connected) {
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'virtual int WiFiClientSecure::available()':
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:229:10: error: '_connected' was not declared in this scope
if (!_connected) {
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp: In member function 'virtual uint8_t WiFiClientSecure::connected()':
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp:245:12: error: '_connected' was not declared in this scope
return _connected;
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\ssl_client.cpp: In function 'int start_ssl_client(sslclient_context*, const char*, uint32_t, int, const char*, const char*, const char*, const char*, const char*)':
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\WiFiClientSecure\src\ssl_client.cpp:68:9: error: 'WiFiGenericClass' has not been declared
if(!WiFiGenericClass::hostByName(host, srv)){
Compiling .pio\build\esp-wrover-kit\lib5f1\ESP Async WebServer\AsyncEventSource.cpp.o
Compiling .pio\build\esp-wrover-kit\lib5f1\ESP Async WebServer\AsyncWebSocket.cpp.o
Compiling .pio\build\esp-wrover-kit\lib5f1\ESP Async WebServer\SPIFFSEditor.cpp.o
Compiling .pio\build\esp-wrover-kit\lib5f1\ESP Async WebServer\WebAuthentication.cpp.o
*** [.pio\build\esp-wrover-kit\libc71\WiFiClientSecure\WiFiClientSecure.cpp.o] Error 1
*** [.pio\build\esp-wrover-kit\libc71\WiFiClientSecure\ssl_client.cpp.o] Error 1
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\HTTPClient\src\HTTPClient.cpp: In member function 'bool HTTPClient::connect()':
C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\HTTPClient\src\HTTPClient.cpp:1017:63: error: no matching function for call to 'WiFiClient::connect(const char*, uint16_t&, int32_t&)'
if(!_client->connect(_host.c_str(), _port, _connectTimeout)) {
In file included from C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\HTTPClient\src\HTTPClient.h:34:0,
from C:\users\atcla\.platformio\packages\framework-arduinoespressif32\libraries\HTTPClient\src\HTTPClient.cpp:40:
.pio\libdeps\esp-wrover-kit\WiFi_ID870\src/WiFiClient.h:34:15: note: candidate: virtual int WiFiClient::connect(IPAddress, uint16_t)
virtual int connect(IPAddress ip, uint16_t port);
.pio\libdeps\esp-wrover-kit\WiFi_ID870\src/WiFiClient.h:34:15: note: candidate expects 2 arguments, 3 provided
.pio\libdeps\esp-wrover-kit\WiFi_ID870\src/WiFiClient.h:35:15: note: candidate: virtual int WiFiClient::connect(const char*, uint16_t)
virtual int connect(const char *host, uint16_t port);
.pio\libdeps\esp-wrover-kit\WiFi_ID870\src/WiFiClient.h:35:15: note: candidate expects 2 arguments, 3 provided
*** [.pio\build\esp-wrover-kit\lib4e1\HTTPClient\HTTPClient.cpp.o] Error 1
In file included from .pio\libdeps\esp-wrover-kit\ESP Async WebServer\src\SPIFFSEditor.h:3:0,
from .pio\libdeps\esp-wrover-kit\ESP Async WebServer\src\SPIFFSEditor.cpp:1:
.pio\libdeps\esp-wrover-kit\ESP Async WebServer\src/ESPAsyncWebServer.h:27:16: fatal error: FS.h: No such file or directory
* Looking for FS.h dependency? Check our library registry!
* CLI > platformio lib search "header:FS.h"
* Web > https://platformio.org/lib/search?query=header:FS.h
compilation terminated.
In file included from .pio\libdeps\esp-wrover-kit\ESP Async WebServer\src\AsyncEventSource.h:31:0,
from .pio\libdeps\esp-wrover-kit\ESP Async WebServer\src\AsyncEventSource.cpp:21:
In file included from .pio\libdeps\esp-wrover-kit\ESP Async WebServer\src\AsyncWebSocket.h:32:0,
from .pio\libdeps\esp-wrover-kit\ESP Async WebServer\src\AsyncWebSocket.cpp:22:
*** [.pio\build\esp-wrover-kit\lib5f1\ESP Async WebServer\SPIFFSEditor.cpp.o] Error 1
*** [.pio\build\esp-wrover-kit\lib5f1\ESP Async WebServer\AsyncWebSocket.cpp.o] Error 1
*** [.pio\build\esp-wrover-kit\lib5f1\ESP Async WebServer\AsyncEventSource.cpp.o] Error 1
=================================================================== [FAILED] Took 4.29 seconds ===================================================================
And my main.cpp
#include <WiFi.h>
#include <HTTPClient.h>
#include <EEPROM.h> // include library to read and write from flash memory
#define EEPROM_SIZE 4 // define the number of bytes you want to access in flash memory
#define modeButton 13 // define the pin the mode changing button is on
char ssid[] = "SampleNetwork";
const char* password = "987654321";
int timeout_counter = 0;
//float numToDisplay = 0.00;
String mac;
int remoteMode = 0;
bool isModeChange = false;
int maxMode = 4;
unsigned long lastModeTime = 0;
unsigned long modeTimeDelay = 1500;
unsigned long firstbootTimeDelay = 6000;
bool firstboot = true;
String fallbackWeight;
void modeInt() {
isModeChange = true;
Serial.println("Opening Serial Monitor..");
delay(100);
Serial2.begin(9600, SERIAL_8N1,19,21);
Serial.println("Opening Serial2 to Display..");
delay(100);
// initialize EEPROM with predefined size
EEPROM.begin(EEPROM_SIZE);
pinMode(modeButton, INPUT_PULLUP);
// read the last LED state from flash memory
remoteMode = EEPROM.read(0);
WiFi.begin(ssid, password);
delay(100);
Serial2.println("Er02"); // Error 02 Unable to connect to wifi
Serial.println("Connecting to WiFi..");
Serial.println("Connected to the WiFi network");
// mac = WiFi.macAddress();
Serial.println(mac);
attachInterrupt(digitalPinToInterrupt(modeButton),modeInt, FALLING);
lastModeTime = millis();
String payloadWeight;
if ((millis() - lastModeTime) < modeTimeDelay) {
String mode = " F" + String(remoteMode) + " ";
Serial2.println(mode);
} else {
firstboot = false;
if ((WiFi.status() == WL_CONNECTED)) { //Check the current connection status
HTTPClient http;
http.begin("http://192.168.1.184/remote"); //Specify the URL
int httpCode = http.POST(String(remoteMode)); //Make the request
if (httpCode > 0) { //Check for the returning code
payloadWeight = http.getString();
fallbackWeight = payloadWeight;
} else {
payloadWeight = fallbackWeight;
Serial.println("Error on HTTP request");
//Serial2.println("Er04"); // Error 04 on HTTP remote request
http.end(); //Free the resources
}else {
timeout_counter++;
Serial.println(payloadWeight);
// If a colon is found in string then we know it's lb/oz
// if (payloadWeight.indexOf(":") != -1){
// Serial2.println(payloadWeight.substring(0, payloadWeight.indexOf(".")));
// } else {
// Serial2.println(payloadWeight.substring(0, 5));
//delay(30);
if (timeout_counter > 20) {
Serial.println("Restarting: Attempting to reestablish wi-fi connecton");
delay(1000);
ESP.restart();
if(isModeChange) {
String payloadMaxMode = "";
HTTPClient http;
http.begin("http://192.168.1.184/getmaxmode"); //Specify the URL
int httpCode = http.GET(); //Make the request
payloadMaxMode = http.getString();
maxMode = std::atoi(payloadMaxMode.c_str());
} else {
Serial2.println("Er03"); // Error on Max Mode HTTP Request
}else {
if(remoteMode >= maxMode) {
remoteMode = 1;
} else {
remoteMode++;
Serial.print("Mode Button Pressed: ");
Serial.println(remoteMode);
EEPROM.write(0, remoteMode);
EEPROM.commit();
Serial.println("Remote Mode saved in flash memory");
Finally my platformio.ini:
;PlatformIO Project Configuration File
[env:esp-wrover-kit]
board = esp-wrover-kit
WiFi
HTTPClient
eeprom
ESP Async WebServer
AsyncTCP
