hi All
first I have to say that I am new to PIO having moved across from Arduino
My project is a direct copy from an Arduino project which compiles and runs with no problems.
an excerpt from my main.cpp file is: (the whole file is quire large)
#include <WiFi.h>
WiFiClient net;
#include <ArduinoOTA.h>
#include <MQTT.h>
#include <MQTTClient.h>
MQTTClient client(256);
#include <Streaming.h>
#include <EEPROM.h>
#include <Ticker.h>
#include <stdio.h>
#include <OneWire.h>
const int oneWireBus = 4;
OneWire oneWire(oneWireBus);
#include <DallasTemperature.h>
DallasTemperature sensors(&oneWire);
// use sensors.begin(); in setup
#include "variables.h"
the first problem:
the line WiFiClient net; was showing as an error WiFiClient does not name a type
I was trying to resolve this when i had an error from PIO saying:
Can not remove temporary directory c:\Users\Dave\Documents\PlatformIO\Projects\WiFiMqtt Module\.pio\build.
Please remove it manually to avoid build issues
i did remove it manually but this error persists, i can see that PIO has replaced the directory but it comes up with the same error again and again
there are other errors being shown by the system but i am sure most of those will be resolved when i can find the solution to these two.
my project.ini file is unchanged:
;PlatformIO Project Configuration File
[env:fm-devkit]
board = fm-devkit
i am sure i am experiencing âteethingâ problems if anyone can point me in the right direction i would be most grateful
thanks in advance
Dave
