the code is as follows:
pinMode(2, OUTPUT);
digitalWrite(2, LOW);
digitalWrite(2, HIGH);
Serial.println("LED: ON");
delay(500);
Serial.println("LED: OFF");
delay(500);
“C:\Users\GGG.platformio\penv\Scripts\platformio.exe ‘run’” terminated with exit code: 1.
Hi, I’m a new hand in esp32. I’ve tried Arduino IDE to compile the code, but it also failed.
I have searched in various forums, but I can’t find any solution. (T_T)
Is the compiler crashed ? And what should I do.
Thanks.
A package (framework, compiler) may be corrupted. Try a clean reinstallation:
- Close VSCode
- Delete
C:\Users\<user>\.platformio
- Reopen VSCode
- Wait for PlatformIO to reinstall itself
- Upload again
Thanks for your reply. I try it. But it doesn’t work.
Open a PIO CLI and execute
pio run -v -j1
What’s the last few lines of this output?
as follows:
- IC:/Users/GGG/platformio/packages/framework-arduinoespressif32/variants/esp32 src/main.cpp
xtensa-esp32-elf-g++@D:\commands\esp32\Test1\.pio\build\esp32dev\tmpessildao.tmp
**[.pio\build\esp32dev\src\main.cpp.o] Error 1
=====[FAILED] took 11.09 seconds======
What if you move the project to the C: drive?
errors still occur as written above.
Check if Antivirus / Windows Defender interferes.
If you’re out of ideas, please file an issue in https://github.com/platformio/platform-espressif32/issues.
OK. Thank you for providing so many ideas.
