I am seeing compile errors related to uint8_t, int32_t and int16_t type definitions in a library that I’m trying to include in my main source file:
In file included from src/main.cpp:1:0:
.piolibdeps/XLR8Quadrature_ID1855/src/XLR8Quadrature.h:76:3: error: ‘uint8_t’ does not name a type
uint8_t sample_rate;
.piolibdeps/XLR8Quadrature_ID1855/src/XLR8Quadrature.h:92:5: error: ‘int32_t’ does not name a type
int32_t readCount();
.piolibdeps/XLR8Quadrature_ID1855/src/XLR8Quadrature.h:93:5: error: ‘int16_t’ does not name a type
int16_t readRate();
.piolibdeps/XLR8Quadrature_ID1855/src/XLR8Quadrature.h:96:5: error: ‘uint8_t’ does not name a type
uint8_t quadratureIndex;
If I use those type definitions in main.cpp, I don’t see errors, but I get them in the included file. I have tried moving the library to my local /lib directory and also putting the .h and .cpp files directly in the src/ directory. No luck.
Here are the settings from my platformio.ini file:
[env:alorium_sno]
board = alorium_sno
board_build.f_cpu = 32000000L ; change MCU frequency
lib_archive = false
lib_deps = XLR8Quadrature, KMeans
Any suggestions?
Thanks!
Jason
#include <stdint.h> (or directly Arduino.h, it includes it) as the first line in your main.cpp or fix the XLR8Quadrature.h file which is trying to declare functions without pulling in stdint.h first.
Thanks for the recommendation. That did indeed work.
Though, it’s somewhat curious, IMO. The fact that the types are not a problem in the main.cpp led me to believe that stdint.h was being included somewhere in the framework setup by PlatformIO. So, I was expecting it to apply to includes, as well.
Though, admittedly, I don’t really understand what’s going on under the hood very well.
Thanks for your help!
Jason
The problem is within the XLR8Quadrature/XLR8Quadrature.h at master · AloriumTechnology/XLR8Quadrature · GitHub file and partly in the Arduino IDE
- the
XLR8Quadrature.h uses uint8_t etc from stdint.h but does not #include this header file first; that’s an error, it should #include <stdint.h> or #include <Arduino.h> first
- this will still work in the Arduino IDE because it automatically places the line
#include <Arduino.h> as the first line in your sketch without you seeing it. Thus when the program does
#include <Arduino.h> //auto-gened by Arduino-IDE
#include "XLR8Quadrature.h"
- the
uint8_t types etc are pulled in correctly before the XLR8Quadrature.h header is and thus compiles
- since you’re using a
main.cpp file and not a main.ino file, you must take care that you #include <Arduino.h> as the first thing. If you first do #include "XLR8Quadrature.h" then the needed types won’t exist; if you had named your file main.ino then PIO would have auto-included Arduino.h for you and it would have worked, too.
For more see Redirecting....
In the spirit of Full Disclosure, I want to share that I just realized I had done something very foolish.
When I created my new project from the PlatformIO Home page and then opened the resulting main.cpp file, the first thing I did was Select-All, Delete. I did so because I had code from another project that I wanted to paste into the file.
What I just realized is that the template code added to main.cpp when the project is created is:
The first #include being the most important - as it relates to the issue I saw with the compile.
So, had I been paying attention, I’d have noticed that Arduino.h was included for me. My bad!
I apologize for wasting everyone’s time. Sigh…
Jason
