Error: You are not connected to the Internet - pio 3.6.7
I’m still using pio version 3.6.7 - I have docker containter build with my CI.
Recently it stopped working - also locally Im not able to download dependencies because of no internet issue. Has anything changed ? Is there a way to fix this ?
pio platform install atmelavr --with-package=uploader --with-package=framework-arduino-avr
PlatformManager: Installing atmelavr
atmelavr @ 2.2.0 is already installed
PackageManager: Installing tool-micronucleus @ ~1.200.0
Error: You are not connected to the Internet.
If you build a project first time, we need Internet connection to install all dependencies and toolchains.
That is 2 major versions behind the current 5.2.0 version. Are you 100% sure about this? pio --version?
Maybe @ivankravets has some ideas.
Could you share with us your Dockerfile? Please use the next lines
RUN pip install -U platformio
yes Im using version 3.6.7 - because since version 4 my code is not able to finish compilation, it’s falling into some kind of loop and never finishes, so Im keep using version which works for me.
Everything was working fine - but stopped some time ago - even when I run command to install avr locally on my laptop (also with version 3.6.7) its failnig with same error which I get on gitlab
here is my docker file
FROM registry.gitlab.com/*******/platformio-core:3.6.7
RUN apt-get update
RUN apt-get install -y udev
RUN mkdir -p /home-firmware-libs &&
mkdir -p /home-firmware-cpu-libs/cpu &&
mkdir -p /workspace/modules &&
mkdir -p /workspace/upload
COPY libraries/common /home-firmware-libs
COPY libraries/cpu /home-firmware-cpu-lib/cpu
COPY modules /workspace/modules
COPY upload /workspace/upload
RUN sed -i “/^PIO_PATH/c\PIO_PATH=‘platformio’” /workspace/upload/upload.sh
RUN sed -i “/^BASE_PATH/c\BASE_PATH=‘/workspace/modules’” /workspace/upload/upload.sh
RUN sed -i “/^LIBRARIES/c\LIBRARIES=‘/home-firmware-cpu-lib’” /workspace/upload/upload.sh
RUN platformio platform install atmelavr --with-package=uploader --with-package=framework-arduino-avr
RUN platformio platform install atmelsam --with-package=uploader --with-package=framework-cmsis --with-package=framework-cmsis-atmel --with-package=framework-arduino-sam
RUN platformio platform install ststm32 --with-package=uploader --with-package=toolchain-gccarmnoneeabi --with-package=framework-arduinoststm32
RUN platformio platform install espressif8266 --with-package=uploader --with-package=toolchain-xtensa --with-package=tool-esptool --with-package=tool-esptoolpy --with-package=framework-arduinoespressif8266
ENTRYPOINT [“/bin/bash”, “/workspace/upload/upload.sh”]
You need to provide a simple project that DOES NOT WORK with the latest PlatformIO Core 5.0. Please include it here.
All projects are compatible with PlatformIO Core 5.0.
sure we can do this in some near future :slight_smile: but for now is there anything I can do to make 3.6.7 version working again ?
@ivankravets is there anything I can change to make it work with 3.6.7 ?
Please use the latest PlatformIO Core 5. It is compatible with previous projects. If you have compilation issue with Core 5, please report them.
