I came to use VSC today and got this error:
I had it a couple of times before and usually a fresh install solved it, but not today. I get the same when using the CLI.
Can anyone give me a fix please?
Many thanks,
Andy
Many thanks,
Andy
The stacktrace is cut-off, please post it in text fully.
Does this happen with the latest PlatformIO core too? CLI → pio upgrade --dev + pio run.
Hi Max,
Here is the full trace:
Platform Manager: Installing espressif32
Platform Manager: espressif32@5.2.0 has been installed!
Tool Manager: Installing espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
Tool Manager: toolchain-xtensa-esp32@8.4.0+2021r2-patch3 has been installed!
Tool Manager: Installing platformio/framework-arduinoespressif32 @ ~3.20005.0
Tool Manager: framework-arduinoespressif32@3.20005.220925 has been installed!
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.40201.0
Tool Manager: tool-esptoolpy@1.40201.0 has been installed!
Removing unused dependencies...
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/__main__.py", line 102, in main
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/click/core.py", line 1130, in __call__
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/cli.py", line 71, in invoke
return super().invoke(ctx)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/click/core.py", line 1657, in invoke
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/click/core.py", line 1404, in invoke
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/click/core.py", line 760, in invoke
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/click/decorators.py", line 26, in new_func
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/run/cli.py", line 144, in cli
process_env(
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/run/cli.py", line 201, in process_env
result = {"env": name, "duration": time(), "succeeded": ep.process()}
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/run/processor.py", line 83, in process
install_project_env_dependencies(
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/package/commands/install.py", line 132, in install_project_env_dependencies
_install_project_env_libraries(project_env, options),
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/package/commands/install.py", line 204, in _install_project_env_libraries
_uninstall_project_unused_libdeps(project_env, options)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/package/commands/install.py", line 280, in _uninstall_project_unused_libdeps
lm.uninstall(spec)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/package/manager/_uninstall.py", line 29, in uninstall
return self._uninstall(spec, skip_dependencies)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/package/manager/_uninstall.py", line 34, in _uninstall
pkg = self.get_package(spec)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/package/manager/base.py", line 263, in get_package
spec = self.ensure_spec(spec)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/package/manager/base.py", line 133, in ensure_spec
return spec if isinstance(spec, PackageSpec) else PackageSpec(spec)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/package/meta.py", line 184, in __init__
self._parse(self.raw)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/package/meta.py", line 291, in _parse
raw = parser(raw)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/package/meta.py", line 316, in _parse_requirements
self.requirements = tokens[1].strip()
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/package/meta.py", line 231, in requirements
else semantic_version.SimpleSpec(str(value))
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/semantic_version/base.py", line 647, in __init__
self.clause = self._parse_to_clause(expression)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/semantic_version/base.py", line 1043, in _parse_to_clause
return cls.Parser.parse(expression)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/semantic_version/base.py", line 1063, in parse
raise ValueError("Invalid simple block %r" % block)
ValueError: Invalid simple block '^4.1.build_flags ='
`pip install -U platformio` command
✘ andy ~/Documents/PlatformIO/Projects/Heltec_LoRaWan
pio upgrade
You're up-to-date!
PlatformIO 6.1.5 is currently the newest version available.
pio upgrade --dev
Please wait while upgrading PlatformIO ...
PlatformIO has been successfully upgraded to 6.1.6a4
Release notes: https://docs.platformio.org/en/latest/history.html
pio run
Please wait while upgrading PlatformIO...
PlatformIO has been successfully upgraded to 6.1.6a4!
If you like PlatformIO, please:
- follow us on Twitter to stay up-to-date on the latest project news > https://twitter.com/PlatformIO_Org
- star it on GitHub > https://github.com/platformio/platformio
- try PlatformIO IDE for embedded development > https://platformio.org/platformio-ide
Processing heltec_wifi_lora_32_V2 (platform: espressif32; board: heltec_wifi_lora_32_V2; framework: arduino)
process_env(
lm.uninstall(spec)
raw = parser(raw)
The problem occurs in 6.1.5, 6.1.6a4 VSC and CLI. I also keep getting multiple core messages, but don’t really understand or how to avoid it.
I’ve updated Python (to 3.11.1), installed pyenv, deleted .platformio multiple times and reinstalled platformio in VSC several times.
No luck with your suggestion:
pio upgrade --dev
Please wait while upgrading PlatformIO …
Release notes: Redirecting...
Removing unused dependencies…
File “/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/platformio/main.py”, line 102, in main
File “/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/click/core.py”, line 1130, in call
File “/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/click/core.py”, line 1055, in main
/Library/Frameworks/Python.framework should normally not be in theh stacktraceplatformio.ini? Where does ^4.1.build_flags = come from?The last attempt I made was using the installation script. I also had the error with a local installation.
platformio.ini:
[env:heltec_wifi_lora_32_V2]
board = heltec_wifi_lora_32_V2
lib_deps = mcci-catena/MCCI LoRaWAN LMIC library@^4.1.1
Thanks for the quick answer btw!
I have no problems with that platformio.ini.
The error suggests that the last part has some .build_flags = ... stuff after it. The file is possibly corrupted?
Try and delete the platformio.ini and create it anew with that exact content.
I tested it to compile with source code
#include <lmic.h>
#include <SPI.h>
void setup(){}
void loop(){}
Resulting in
Linking .pio\build\heltec_wifi_lora_32_V2\firmware.elf
Retrieving maximum program size .pio\build\heltec_wifi_lora_32_V2\firmware.elf
Checking size .pio\build\heltec_wifi_lora_32_V2\firmware.elf
RAM: [ ] 4.9% (used 16144 bytes from 327680 bytes)
Flash: [= ] 6.4% (used 213009 bytes from 3342336 bytes)
Building .pio\build\heltec_wifi_lora_32_V2\firmware.bin
esptool.py v4.2.1
Creating esp32 image...
Merged 2 ELF sections
============================================= [SUCCESS] Took 10.05 seconds =============================================
Back in VSC now:
Same result again with:
#include <SPI.h>
void setup(){}
void loop(){}
At the start of the day, my Python was 3.9.
The project is a reference version that I fall back on when I want a basic LoRaWan connection. As such it hasn’t changed. The problem seemed to come from nowhere this morning .
Also, I didn’t change anything or carry out any upgrades prior to switching to the project. I had been working on a another project before switching back to this one.
Just before I turn my laptop off, the problem seems to be limited to the one project. I’m going to have to scrap it and start again, but at least everything else sems to work.
Thanks again for your time Max:-).
Hi Max,
Just to finish the story and for anyone else with the problem, I created a new folder this morning and copied the platformio.ini to it. Using the minimal program above, I still got the error message. I removed the libdeps line with the reference to the lmic library and was able to compile a minimal installation (without the reference to lmic, of course). Then I reinserted the library line and copied the original program into main.cpp and everything worked! It seems very weird. Deleting the platform.ini didn’t work yesterday, in the original folder.
I learned a lot from this episaode and now know how to deal with multiple Python installations on the Mac and best of all, I’ve been able to move away from VSC and use Vim as my editor of choice. I wasn’t aware that this was possible until yesterday!
