Hi All
Problem and trace in one image
A week ago, using ststm32 earlier version, no problem occured.
Currently, platformio self-updated, and we have image:
C:\.platformio\packages\framework-arduinoststm32-maple\STM32F1\cores\maple/WCharacter.h: In function 'isControl':
C:\.platformio\packages\framework-arduinoststm32-maple\STM32F1\cores\maple/WCharacter.h: In function 'isAlpha':
C:\.platformio\packages\framework-arduinoststm32-maple\STM32F1\cores\maple/WCharacter.h: In function 'isWhitespace':
C:\.platformio\packages\framework-arduinoststm32-maple\STM32F1\cores\maple/WCharacter.h:62:30: error: 'false' undeclared (first use in this function); did you mean 'fabsl'?
return ( isalpha(c) == 0 ? false : true);
fabsl
C:\.platformio\packages\framework-arduinoststm32-maple\STM32F1\cores\maple/WCharacter.h:62:38: error: 'true' undeclared (first use in this function); did you mean 'trunc'?
trunc
C:\.platformio\packages\framework-arduinoststm32-maple\STM32F1\cores\maple/WCharacter.h:78:31: error: 'false' undeclared (first use in this function); did you mean 'fabsl'? The terminal process terminated with exit code: 1
... [very long repeating errors such as this] ...
In file included from .pio\libdeps\blackpill_f103c8\STM32duino FreeRTOS_ID2093\src\cmsis_os.c:9:0:
.pio\libdeps\blackpill_f103c8\STM32duino FreeRTOS_ID2093\src\../portable/CMSIS_RTOS/cmsis_os.c:79:12: fatal error: cmsis_gcc.h: No such file or directory
* Looking for cmsis_gcc.h dependency? Check our library registry!
* CLI > platformio lib search "header:cmsis_gcc.h"
* Web > https://platformio.org/lib/search?query=header:cmsis_gcc.h
#include "cmsis_gcc.h"
compilation terminated.
*** [.pio\build\blackpill_f103c8\lib27e\STM32duino FreeRTOS_ID2093\port.c.o] Error 1
*** [.pio\build\blackpill_f103c8\lib27e\STM32duino FreeRTOS_ID2093\heap.c.o] Error 1
*** [.pio\build\blackpill_f103c8\lib27e\STM32duino FreeRTOS_ID2093\STM32FreeRTOS.c.o] Error 1
*** [.pio\build\blackpill_f103c8\lib27e\STM32duino FreeRTOS_ID2093\cmsis_os.c.o] Error 1
======================================================================================== [FAILED] Took 7.74 seconds ========================================================================================
