Hi there,
I am new to PlatformIO. Came over from Arduino IDE. I forked a ESP32 project from github and now i am trying to upload it to my chip. But I get this error message which leaves me without a clue:
esptool write_flash: error: argument : Address “C:\Users\Clouseau.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32\bin\bootloader_dio_40m.bin” must be a number
Here is the full terminal output when I try to upload:
Executing task: C:\Users\Clouseau\.platformio\penv\Scripts\platformio.exe run --target upload
-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (4.3.0) > Espressif ESP32 Dev Module
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.20003.0 (2.0.3)
- tool-mkfatfs @ 2.0.1
Found 37 compatible libraries
|-- WiFiManager @ 2.0.16-rc.2+sha.5656e57
|-- ArduinoJson @ 6.21.3+sha.7517ecb
|-- PubSubClient @ 2.8.0+sha.2d228f2
|-- ESPHTTPUpdateServer @ 1.0.0+sha.42971eb
|-- FS @ 2.0.0
|-- LittleFS @ 2.0.0
|-- WiFi @ 2.0.0
|-- WiFiClientSecure @ 2.0.0
|-- WebServer @ 2.0.0
Retrieving maximum program size build\esp32dev\firmware.elf
Checking size build\esp32dev\firmware.elf
RAM: [= ] 12.0% (used 39468 bytes from 327680 bytes)
Flash: [======= ] 71.2% (used 933037 bytes from 1310720 bytes)
AVAILABLE: cmsis-dap, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: COM3
Uploading build\esp32dev\firmware.bin
usage: esptool write_flash [-h] [--erase-all]
[--flash_freq {keep,80m,60m,48m,40m,30m,26m,24m,20m,16m,15m,12m}]
[--flash_mode {keep,qio,qout,dio,dout}]
[--flash_size FLASH_SIZE]
[--spi-connection SPI_CONNECTION] [--no-progress]
[--verify] [--encrypt]
[--encrypt-files <address> <filename> [<address> <filename> ...]]
[--ignore-flash-encryption-efuse-setting]
[--compress | --no-compress]
esptool write_flash: error: argument <address> <filename>: Address "C:\Users\Clouseau\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32\bin\bootloader_dio_40m.bin" must be a number
*** [upload] Error 2
======================================================================== [FAILED] Took 9.73 seconds ========================================================================
Environment Status Duration
esp32dev FAILED 00:00:09.730
