Hello Community,
I am working on the PlatformIO IDE to create ThreadX platformbased Quectel BG-96 project.
While creating it I am getting following error,
PIO Core Call Error:
"The current working directory D:\\test\\PlatformIO\\bg96_test will be used for the project.
\n\r
\nThe next files/directories have been created in D:\\test\\PlatformIO\\bg96_test\ninclude - Put project header files here
\nlib - Put here project specific (private) libraries\nsrc - Put project source files here
\nplatformio.ini - Project Configuration File
\n
\n
\nError: Processing bg96 (platform: quectel; board: bg96; framework: threadx)
\n-------------------------------------------------------------------------------
\nCorePackageManager: Installing tool-scons @ ~2.20501.7
\ntool-scons @ 2.20501.190826 has been successfully installed!
\nVerbose mode can be enabled via `-v, --verbose` option
\n<<<<<<<<<<<< QUECTEL BG96 MODULE 2018 Georgi Angelov >>>>>>>>>>>>
\nCONFIGURATION: https://docs.platformio.org/page/boards/quectel/bg96.html
\nPLATFORM: Quectel 2.0.14 #adb27bc > Quectel BG96 module
\nHARDWARE: ARM, MDM9206 1200MHz, 3.00MB RAM, 3.00MB Flash
\nDEBUG: Current (uart) On-board (uart)
\nPACKAGES: framework-quectel fc4089a, toolchain-gccarmnoneeabi 1.70201.0 (7.2.1)
\n File \"C:\\users\\embed\\.platformio\\platforms\\quectel\\builder\\frameworks\\QDL.py\", line 122
\n
\nSyntaxError: Non-ASCII character '\\xd0' in file C:\\users\\embed\\.platformio\\platforms\\quectel\\builder\\frameworks\\QDL.py on line 122, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
\n
\n========================= [FAILED] Took 10.65 seconds ========================="
will you please help me to solve this problem?
Regards,
Shiv Patil.
