The following error is occurring in while compiling this project in my mac. The same error do not happens both on windows and linux
In file included from /Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:31:0,
from /Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.cpp:25:
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/IPAddress.h:52:31: error: ‘String’ does not name a type
bool fromString(const String &address) { return fromString(address.c_str()); }
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/IPAddress.h:52:39: error: ISO C++ forbids declaration of ‘address’ with no type [-fpermissive]
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/IPAddress.h:80:9: error: ‘String’ does not name a type
String toString() const;
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/IPAddress.h:87:28: error: ‘String’ does not name a type
static bool isValid(const String& arg);
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/IPAddress.h:87:36: error: ISO C++ forbids declaration of ‘arg’ with no type [-fpermissive]
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/IPAddress.h: In member function ‘bool IPAddress::fromString(const int&)’:
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/IPAddress.h:52:76: error: request for member ‘c_str’ in ‘address’, which is of non-class type ‘const int’
In file included from /Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:33:0,
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiType.h: At global scope:
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiType.h:107:5: error: ‘String’ does not name a type
String ssid;
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiType.h:114:5: error: ‘String’ does not name a type
String ssid;
In file included from /Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:34:0,
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.h:65:9: error: ‘String’ does not name a type
String macAddress();
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.h:71:9: error: ‘String’ does not name a type
String hostname();
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.h:74:23: error: ‘String’ has not been declared
bool hostname(String aHostname);
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.h:78:9: error: ‘String’ does not name a type
String SSID() const;
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.h:79:9: error: ‘String’ does not name a type
String psk() const;
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.h:82:9: error: ‘String’ does not name a type
String BSSIDstr();
In file included from /Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:35:0,
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiAP.h:48:9: error: ‘String’ does not name a type
String softAPmacAddress(void);
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiAP.h:50:2: error: ‘String’ does not name a type
String softAPSSID() const;
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiAP.h:51:2: error: ‘String’ does not name a type
String softAPPSK() const;
In file included from /Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:36:0,
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiScan.h:44:50: error: ‘String’ has not been declared
bool getNetworkInfo(uint8_t networkItem, String &ssid, uint8_t &encryptionType, int32_t &RSSI, uint8_t* &BSSID, int32_t &channel, bool &isHidden);
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiScan.h:46:9: error: ‘String’ does not name a type
String SSID(uint8_t networkItem);
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiScan.h:50:9: error: ‘String’ does not name a type
String BSSIDstr(uint8_t networkItem);
from /Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiAP.cpp:25:
String ssid;
String ssid;
Compiling .pioenvs/nodemcuv2_prod/libc44/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
In file included from /Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.cpp:25:0:
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:63:36: error: no members matching ‘ESP8266WiFiSTAClass::SSID’ in ‘class ESP8266WiFiSTAClass’
using ESP8266WiFiSTAClass::SSID;
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:66:36: error: no members matching ‘ESP8266WiFiSTAClass::BSSIDstr’ in ‘class ESP8266WiFiSTAClass’
using ESP8266WiFiSTAClass::BSSIDstr;
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:68:37: error: no members matching ‘ESP8266WiFiScanClass::SSID’ in ‘class ESP8266WiFiScanClass’
using ESP8266WiFiScanClass::SSID;
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:72:37: error: no members matching ‘ESP8266WiFiScanClass::BSSIDstr’ in ‘class ESP8266WiFiScanClass’
using ESP8266WiFiScanClass::BSSIDstr;
String hostname();
String psk() const;
String BSSIDstr();
*** [.pioenvs/nodemcuv2_prod/libc44/ESP8266WiFi/ESP8266WiFi.cpp.o] Error 1
In file included from /Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiAP.cpp:25:0:
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiAP.cpp:334:8: error: prototype for ‘String ESP8266WiFiAPClass::softAPmacAddress()’ does not match any in class ‘ESP8266WiFiAPClass’
String ESP8266WiFiAPClass::softAPmacAddress(void) {
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiAP.cpp:325:10: error: candidate is: uint8_t* ESP8266WiFiAPClass::softAPmacAddress(uint8_t*)
uint8_t* ESP8266WiFiAPClass::softAPmacAddress(uint8_t* mac) {
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiAP.cpp:347:41: error: no ‘String ESP8266WiFiAPClass::softAPSSID() const’ member function declared in class ‘ESP8266WiFiAPClass’
String ESP8266WiFiAPClass::softAPSSID() const {
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiAP.cpp:362:40: error: no ‘String ESP8266WiFiAPClass::softAPPSK() const’ member function declared in class ‘ESP8266WiFiAPClass’
String ESP8266WiFiAPClass::softAPPSK() const {
*** [.pioenvs/nodemcuv2_prod/libc44/ESP8266WiFi/ESP8266WiFiAP.cpp.o] Error 1
from /Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiGeneric.cpp:27:
String ssid;
String ssid;
String hostname();
String psk() const;
String BSSIDstr();
In file included from /Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiGeneric.cpp:27:0:
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiGeneric.cpp: In lambda function:
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiGeneric.cpp:104:13: error: ‘struct WiFiEventStationModeConnected’ has no member named ‘ssid’
dst.ssid = String(reinterpret_cast<char*>(src.ssid));
/Users/joaotrevizoliesteves/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFiGeneric.cpp:118:13: error: ‘struct WiFiEventStationModeDisconnected’ has no member named ‘ssid’
*** [.pioenvs/nodemcuv2_prod/libc44/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o] Error 1
