I continue to get an error when I try to upload a simple (Blink) sketch to my Arduino WiFi Rev 2.:
avrdude: jtagmkII_getsync(): sign-on command: status -1
avrdude: jtagmkII_getsync(): timeout/error communicating with programmer (status -1)
The sketch is the “Blink example” and I am trying to set up VSCode with PlatformIO to be able to program this board.
I have already uploaded and run the sketch using the Arduino IDE and it works fine.
I’ve imported the project into VSCode/Platformio. I’ve added the #include <Arduino.h> line but cannot get it to upload.
I’m running on a Mac.
Any ideas?
What’s the platformio.ini
Full log of the project task “Advanced → Verbose Upload”?
Thank you for responding.
This is the platformio.ini file:
[env:ATmega4809]
platform = atmelmegaavr
board = ATmega4809
Here’s the output from the serial monitor when I try to upload:
"CONFIGURATION: https://docs.platformio.org/page/boards/atmelmegaavr/ATmega4809.html
PLATFORM: Atmel megaAVR (1.4.0) > ATmega4809
HARDWARE: ATMEGA4809 16MHz, 6KB RAM, 48KB Flash
- framework-arduino-megaavr-megacorex 1.0.7
- tool-avrdude-megaavr 2.60300.210128 (6.3.0)
- toolchain-atmelavr 2.70300.201015 (7.3.0)
Found 40 compatible libraries
MethodWrapper(["checkprogsize"], [".pio/build/ATmega4809/firmware.elf"])
RAM: [ ] 0.1% (used 4 bytes from 6144 bytes)
Flash: [ ] 1.6% (used 804 bytes from 49152 bytes)
.pio/build/ATmega4809/firmware.elf :
section size addr
.data 0 8398848
.text 804 0
.bss 4 8398848
.comment 17 0
.note.gnu.avr.deviceinfo 64 0
.debug_aranges 128 0
.debug_info 10070 0
.debug_abbrev 8934 0
.debug_line 945 0
.debug_str 3973 0
Total 24939
<lambda>(["upload"], [".pio/build/ATmega4809/firmware.hex"])
AVAILABLE: jtag2updi
CURRENT: upload_protocol = jtag2updi
BeforeUpload(["upload"], [".pio/build/ATmega4809/firmware.hex"])
Auto-detected: /dev/cu.usbmodem143302
Forcing reset using 1200bps open/close on port /dev/cu.usbmodem143302
avrdude -v -p atmega4809 -C /Users/smiller85715/.platformio/packages/tool-avrdude-megaavr/avrdude.conf -c jtag2updi -b 115200 -P "/dev/cu.usbmodem143302" -U flash:w:.pio/build/ATmega4809/firmware.hex:i
avrdude: Version 6.3-20201216
System wide configuration file is "/Users/smiller85715/.platformio/packages/tool-avrdude-megaavr/avrdude.conf"
User configuration file is "/Users/smiller85715/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem143302
Using Programmer : jtag2updi
Overriding Baud Rate : 115200
avrdude done. Thank you.
*** [upload] Error 1
================================================================================= [FAILED] Took 166.30 seconds =================================================================================
The terminal process "platformio 'run', '--target', 'upload'" terminated with exit code: 1.
I’m not sure how to format this stuff in the post…
Steve
Desertgeek:
board = ATmega4809
Why that? Per documentation you’re supposed to select board = uno_wifi_rev2
here.
Markdown .
Thanks again. I did not see your second response until this morning after I had tried the experiment where I reconfigured the project for Arduino Uno Atmega 328P. Uploading the same program worked perfectly.
It has been a while since I worked with PlatformIO and I was unsure of how to set things up. Changing the board as the documentation shows elliminates the problem…duh!
Thank you for the help.
