Hi all,
Trying to debug a simple blink sketch in my PlatformIO project within Visual Studio Code on my MAC (10.15) for the first time but getting following errors.
Been all over the internet but now lost and confused. Any help or links to a resolution will be greatly appreciated.
Not a MAC expert, so any Terminal commands, please tell me where to change directory (cd) to first. Thanks.
Visual Studio Code/PlatformIO Pop-Up Error
Failed to launch GDB: .pioinit:11: Error in sourced command file:
Remote connection closed (from interpreter-exec console “source .pioinit”)
Debug Consol error message
[…compiling]
========================= [SUCCESS] Took 1.11 seconds =========================
Reading symbols from /Users/JoeBloggs/Documents/PlatformIO/Projects/AZ Delivery ESP32 DEV > Kit C V2/.pio/build/esp32dev/firmware.elf…
done.
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.10.0-esp32-20190708 (2019-07-08-11:04)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6010, description ‘', serial '’ at bus location ‘*’
Warn : Flash driver of esp32.flash does not support free_driver_priv()
Warn : Flash driver of irom does not support free_driver_priv()
Warn : Flash driver of drom does not support free_driver_priv()
My PlatformIO.ini
upload_port = /dev/cu.SLAB_USBtoUART
