I’m using VS Code on a Windows machine and trying to compile the GUIslice example the ex46_ard_togglebtn.ino
example which compiled in fine in the Arduino IDE.
The error that happens is:
Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
.pio/libdeps/esp32dev/GUIslice/src/GUIslice_drv_tft_espi.cpp: In function 'bool gslc_DrvGetTxtSize(gslc_tsGui*, gslc_tsFont*, const char*, gslc_teTxtFlags, int16_t*, int16_t*, uint16_t*, uint16_t*)':
.pio/libdeps/esp32dev/GUIslice/src/GUIslice_drv_tft_espi.cpp:394:31: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
m_disp.setFreeFont((const GFXfont *)pFont->pvFont);
When I follow the trail to GUIslice_drv_tft_espi.cpp:394:31
VS Code tells me that GFXfont
is undefined but it is defined in Adafruit-GFX-Library/gfxfont.h at master · adafruit/Adafruit-GFX-Library (github.com) which is included in Adafruit-GFX-Library/Adafruit_GFX.h at master · adafruit/Adafruit-GFX-Library (github.com)
My platformio.ini file has the following
[platformio]
;lib_dir = .
[env]
;lib_ldf_mode = chain+ ;i also tried deep
;platform = https://github.com/platformio/platform-espressif32.git ; will force to use the 2.0 board package
SPI
Wire
adafruit/Adafruit BusIO
adafruit/Adafruit GFX Library
impulseadventure/GUIslice
TFT_eSPI
adafruit/Adafruit FT6206 Library ; needed for GUIslice
-DUSER_CONFIG_LOADED
-DUSER_CONFIG_INC_FILE
-DUSER_CONFIG_INC_FNAME=\"../configs/esp-tftespi-default-ft6206.h\"
# Now TFT_eSPI Build Flags
So the Adafruit GFX Library is included but I can’t seem to find why it’s not found and as you can see I’ve tried a couple of different options in my platformio.ini
file.
I could be wrong with the root cause of the compile error so I can provide more details if needed.
Unable to reproduce. Using your exact platformio.ini
with this as src/main.cpp
but with #include <Arduino.h>
at the top produces
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (3.5.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 36 compatible libraries
|-- <SPI> 1.0
|-- <Wire> 1.0.1
|-- <Adafruit BusIO> 1.11.2
| |-- <Wire> 1.0.1
| |-- <SPI> 1.0
|-- <Adafruit GFX Library> 1.10.13
| |-- <SPI> 1.0
| | |-- <Wire> 1.0.1
| | |-- <SPI> 1.0
| |-- <Wire> 1.0.1
|-- <GUIslice> 0.17.0
| |-- <Adafruit FT6206 Library> 1.0.6
| | |-- <Wire> 1.0.1
| |-- <Adafruit STMPE610> 1.1.4
| | |-- <SPI> 1.0
| | |-- <Wire> 1.0.1
| |-- <SPI> 1.0
| | |-- <SPI> 1.0
| | | |-- <Wire> 1.0.1
| | | |-- <SPI> 1.0
| | |-- <Wire> 1.0.1
| |-- <Adafruit ILI9341> 1.5.10
| | | |-- <SPI> 1.0
| | | | |-- <Wire> 1.0.1
| | | | |-- <SPI> 1.0
| | | |-- <Wire> 1.0.1
| | |-- <SPI> 1.0
| |-- <SD(esp32)> 1.0.5
| | |-- <FS> 1.0
| | |-- <SPI> 1.0
| |-- <Adafruit TouchScreen> 1.1.3
| |-- <Wire> 1.0.1
| |-- <FS> 1.0
| |-- <TFT_eSPI> 2.4.42
| | |-- <SPIFFS> 1.0
| | | |-- <FS> 1.0
| | |-- <FS> 1.0
| | |-- <SPI> 1.0
| |-- <SPIFFS> 1.0
| | |-- <FS> 1.0
| |-- <FS> 1.0
| |-- <SPI> 1.0
| |-- <Wire> 1.0.1
Compiling .pio\build\esp32dev\src\main.cpp.o
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [ ] 4.9% (used 16024 bytes from 327680 bytes)
Flash: [== ] 22.2% (used 291479 bytes from 1310720 bytes)
======================== [SUCCESS] Took 5.67 seconds ========================
I didn’t change the name to main.cpp so it still shows as the ino file in the src directory so maybe that’s it?
You still have the original includes, right?
#include "GUIslice.h"
#include "GUIslice_drv.h"
Thanks for testing for me!
OK drilling down on the problem. I too can compile as long as I don’t have the TFT_eSPI build flags. Once I add these to my platformio.ini
I’m back to the error. I started with a fresh workspace and just created a new project and copied and pasted the example code into main.cpp
-DUSER_SETUP_LOADED=1
-DBOARD_HAS_PSRAM=1
-DILI9488_DRIVER=1 ; Select ILI9488 driver
-DTFT_WIDTH=320 ; Set TFT size
-DTFT_HEIGHT=480
-DTFT_MISO=19 ; Define SPI pins
-DTFT_MOSI=23
-DTFT_SCLK=18
-DTFT_CS=5
-DTFT_DC=14 ; Data/Comand pin
-DTFT_RST=13 ; Reset pin
-DTFT_BL=12 ; LED backlight control pin
-DTFT_BACKLIGHT_ON=HIGH ; Level to turn on backlight
; -DTOUCH_CS=21 ; Not used but needed for compile
-DLOAD_GLCD=1 ; Load Fonts
-DLOAD_FONT2=1 ; Font 2. Small 16 pixel high font, needs ~3534 bytes in FLASH, 96 characters
-DLOAD_FONT4=1 ; Font 4. Medium 26 pixel high font, needs ~5848 bytes in FLASH, 96 characters
-DLOAD_FONT6=1 ; Font 6. Large 48 pixel font, needs ~2666 bytes in FLASH, only characters 1234567890:-.apm
-DLOAD_FONT7=1 ; Font 7. 7 segment 48 pixel font, needs ~2438 bytes in FLASH, only characters 1234567890:-.
-DLOAD_FONT8=1 ; Font 8. Large 75 pixel font needs ~3256 bytes in FLASH, only characters 1234567890:-.
-DSMOOTH_FONT=1
-DSPI_FREQUENCY=27000000 ; Set SPI frequency
OK, just stumbled across that if I comment out
; -DUSER_SETUP_LOADED=1
I can get it to compile. Since I still have the rest of my build flags I think I’m OK and things will work but I’m a bit confused on why I’m getting that compile error
