Error when compiling empty Project for ESP32
Hi, I am on an Linux Arch system and got a error while I was compiling a new Project with the CLI / VSCode Plugin. The Project was created with VSCode and the NEW Button in Platformio.
Same Code copied to Windows works just fine. :frowning:
Hope someone could give me a hint.
Env:
Processing esp32dev (platform: espressif32; board: esp32dev; framework: arduino
Error:
Compiling .pio/build/esp32dev/src/main.cpp.o
Generating partitions .pio/build/esp32dev/partitions.bin
Compiling .pio/build/esp32dev/FrameworkArduino/Esp.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/IPAddress.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/IPv6Address.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/MD5Builder.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/Print.cpp.o
as: Unbekannte Option »–longcallsĀ«
*** [.pio/build/esp32dev/FrameworkArduino/HardwareSerial.cpp.o] Error 1
*** [.pio/build/esp32dev/src/main.cpp.o] Error 1
*** [.pio/build/esp32dev/FrameworkArduino/IPAddress.cpp.o] Error 1
*** [.pio/build/esp32dev/FrameworkArduino/FunctionalInterrupt.cpp.o] Error 1
*** [.pio/build/esp32dev/FrameworkArduino/MD5Builder.cpp.o] Error 1
*** [.pio/build/esp32dev/FrameworkArduino/IPv6Address.cpp.o] Error 1
*** [.pio/build/esp32dev/FrameworkArduino/Esp.cpp.o] Error 1
*** [.pio/build/esp32dev/FrameworkArduino/Print.cpp.o] Error 1
===================================== [FAILED] Took 1.72 seconds =====================================
Platformio Version: PlatformIO, version 4.3.4
Seems like it’s attempting to invoke the as assembler… of the system to do stuff?
Are you compiling on the console with pio run? What’s the output of a pio run -v / ā€œVerbose Buildā€?
Hi, I am running in VSCode and Commandline. Got same error in both.
Here the output of pio run -v:
xtensa-esp32-elf-g++ -o .pio/build/esp32dev/src/main.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -Os -g3 -Wall -nostdlib -Wpointer-arith -Wno-error=unused-but-set-variable -Wno-error=unused-variable -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wno-error=deprecated-declarations -Wno-error=unused-function -Wno-unused-parameter -Wno-sign-compare -fstack-protector -fexceptions -Werror=reorder -DPLATFORMIO=40304 -DARDUINO_ESP32_DEV -DESP32 -DESP_PLATFORM -DF_CPU=240000000L -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DARDUINO=10805 -DARDUINO_ARCH_ESP32 -DARDUINO_VARIANT=\"esp32\" "-DARDUINO_BOARD=\"Espressif ESP32 Dev Module\"" -Iinclude -Isrc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/config -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_trace -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_update -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/asio -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bootloader_support -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/coap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/console -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/driver -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-tls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_adc_cal -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_event -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_client -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_server -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_https_ota -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_ringbuf -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ethernet -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/expat -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fatfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freemodbus -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freertos -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/heap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/idf_test -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/jsmn -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/json -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/libsodium -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/log -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/lwip -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mbedtls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mdns -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/micro-ecc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mqtt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/newlib -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nghttp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nvs_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/openssl -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protobuf-c -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protocomm -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/pthread -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/sdmmc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/smartconfig_ack -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/soc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spi_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spiffs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcp_transport -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcpip_adapter -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ulp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/vfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wear_levelling -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wifi_provisioning -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wpa_supplicant -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/xtensa-debug-module -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32-camera -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fb_gfx -I/HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/variants/esp32 src/main.cpp
xtensa-esp32-elf-g++ -o .pio/build/esp32dev/FrameworkArduino/Esp.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -Os -g3 -Wall -nostdlib -Wpointer-arith -Wno-error=unused-but-set-variable -Wno-error=unused-variable -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wno-error=deprecated-declarations -Wno-error=unused-function -Wno-unused-parameter -Wno-sign-compare -fstack-protector -fexceptions -Werror=reorder -DPLATFORMIO=40304 -DARDUINO_ESP32_DEV -DESP32 -DESP_PLATFORM -DF_CPU=240000000L -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DARDUINO=10805 -DARDUINO_ARCH_ESP32 -DARDUINO_VARIANT=\"esp32\" "-DARDUINO_BOARD=\"Espressif ESP32 Dev Module\"" -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/config -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_trace -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_update -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/asio -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bootloader_support -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/coap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/console -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/driver -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-tls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_adc_cal -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_event -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_client -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_server -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_https_ota -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_ringbuf -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ethernet -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/expat -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fatfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freemodbus -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freertos -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/heap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/idf_test -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/jsmn -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/json -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/libsodium -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/log -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/lwip -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mbedtls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mdns -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/micro-ecc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mqtt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/newlib -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nghttp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nvs_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/openssl -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protobuf-c -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protocomm -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/pthread -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/sdmmc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/smartconfig_ack -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/soc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spi_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spiffs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcp_transport -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcpip_adapter -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ulp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/vfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wear_levelling -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wifi_provisioning -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wpa_supplicant -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/xtensa-debug-module -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32-camera -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fb_gfx -I/HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/variants/esp32 /HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32/Esp.cpp
xtensa-esp32-elf-g++ -o .pio/build/esp32dev/FrameworkArduino/FunctionalInterrupt.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -Os -g3 -Wall -nostdlib -Wpointer-arith -Wno-error=unused-but-set-variable -Wno-error=unused-variable -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wno-error=deprecated-declarations -Wno-error=unused-function -Wno-unused-parameter -Wno-sign-compare -fstack-protector -fexceptions -Werror=reorder -DPLATFORMIO=40304 -DARDUINO_ESP32_DEV -DESP32 -DESP_PLATFORM -DF_CPU=240000000L -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DARDUINO=10805 -DARDUINO_ARCH_ESP32 -DARDUINO_VARIANT=\"esp32\" "-DARDUINO_BOARD=\"Espressif ESP32 Dev Module\"" -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/config -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_trace -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_update -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/asio -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bootloader_support -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/coap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/console -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/driver -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-tls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_adc_cal -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_event -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_client -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_server -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_https_ota -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_ringbuf -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ethernet -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/expat -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fatfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freemodbus -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freertos -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/heap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/idf_test -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/jsmn -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/json -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/libsodium -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/log -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/lwip -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mbedtls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mdns -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/micro-ecc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mqtt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/newlib -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nghttp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nvs_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/openssl -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protobuf-c -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protocomm -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/pthread -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/sdmmc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/smartconfig_ack -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/soc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spi_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spiffs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcp_transport -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcpip_adapter -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ulp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/vfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wear_levelling -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wifi_provisioning -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wpa_supplicant -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/xtensa-debug-module -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32-camera -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fb_gfx -I/HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/variants/esp32 /HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32/FunctionalInterrupt.cpp
xtensa-esp32-elf-g++ -o .pio/build/esp32dev/FrameworkArduino/HardwareSerial.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -Os -g3 -Wall -nostdlib -Wpointer-arith -Wno-error=unused-but-set-variable -Wno-error=unused-variable -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wno-error=deprecated-declarations -Wno-error=unused-function -Wno-unused-parameter -Wno-sign-compare -fstack-protector -fexceptions -Werror=reorder -DPLATFORMIO=40304 -DARDUINO_ESP32_DEV -DESP32 -DESP_PLATFORM -DF_CPU=240000000L -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DARDUINO=10805 -DARDUINO_ARCH_ESP32 -DARDUINO_VARIANT=\"esp32\" "-DARDUINO_BOARD=\"Espressif ESP32 Dev Module\"" -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/config -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_trace -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_update -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/asio -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bootloader_support -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/coap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/console -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/driver -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-tls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_adc_cal -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_event -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_client -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_server -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_https_ota -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_ringbuf -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ethernet -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/expat -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fatfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freemodbus -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freertos -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/heap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/idf_test -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/jsmn -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/json -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/libsodium -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/log -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/lwip -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mbedtls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mdns -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/micro-ecc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mqtt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/newlib -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nghttp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nvs_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/openssl -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protobuf-c -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protocomm -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/pthread -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/sdmmc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/smartconfig_ack -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/soc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spi_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spiffs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcp_transport -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcpip_adapter -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ulp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/vfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wear_levelling -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wifi_provisioning -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wpa_supplicant -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/xtensa-debug-module -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32-camera -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fb_gfx -I/HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/variants/esp32 /HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32/HardwareSerial.cpp
xtensa-esp32-elf-g++ -o .pio/build/esp32dev/FrameworkArduino/IPAddress.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -Os -g3 -Wall -nostdlib -Wpointer-arith -Wno-error=unused-but-set-variable -Wno-error=unused-variable -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wno-error=deprecated-declarations -Wno-error=unused-function -Wno-unused-parameter -Wno-sign-compare -fstack-protector -fexceptions -Werror=reorder -DPLATFORMIO=40304 -DARDUINO_ESP32_DEV -DESP32 -DESP_PLATFORM -DF_CPU=240000000L -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DARDUINO=10805 -DARDUINO_ARCH_ESP32 -DARDUINO_VARIANT=\"esp32\" "-DARDUINO_BOARD=\"Espressif ESP32 Dev Module\"" -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/config -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_trace -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_update -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/asio -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bootloader_support -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/coap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/console -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/driver -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-tls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_adc_cal -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_event -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_client -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_server -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_https_ota -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_ringbuf -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ethernet -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/expat -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fatfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freemodbus -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freertos -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/heap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/idf_test -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/jsmn -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/json -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/libsodium -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/log -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/lwip -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mbedtls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mdns -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/micro-ecc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mqtt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/newlib -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nghttp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nvs_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/openssl -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protobuf-c -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protocomm -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/pthread -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/sdmmc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/smartconfig_ack -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/soc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spi_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spiffs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcp_transport -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcpip_adapter -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ulp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/vfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wear_levelling -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wifi_provisioning -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wpa_supplicant -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/xtensa-debug-module -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32-camera -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fb_gfx -I/HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/variants/esp32 /HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.cpp
1/2
2/2
xtensa-esp32-elf-g++ -o .pio/build/esp32dev/FrameworkArduino/IPv6Address.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -Os -g3 -Wall -nostdlib -Wpointer-arith -Wno-error=unused-but-set-variable -Wno-error=unused-variable -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wno-error=deprecated-declarations -Wno-error=unused-function -Wno-unused-parameter -Wno-sign-compare -fstack-protector -fexceptions -Werror=reorder -DPLATFORMIO=40304 -DARDUINO_ESP32_DEV -DESP32 -DESP_PLATFORM -DF_CPU=240000000L -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DARDUINO=10805 -DARDUINO_ARCH_ESP32 -DARDUINO_VARIANT=\"esp32\" "-DARDUINO_BOARD=\"Espressif ESP32 Dev Module\"" -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/config -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_trace -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_update -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/asio -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bootloader_support -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/coap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/console -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/driver -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-tls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_adc_cal -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_event -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_client -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_server -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_https_ota -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_ringbuf -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ethernet -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/expat -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fatfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freemodbus -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freertos -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/heap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/idf_test -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/jsmn -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/json -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/libsodium -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/log -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/lwip -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mbedtls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mdns -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/micro-ecc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mqtt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/newlib -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nghttp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nvs_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/openssl -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protobuf-c -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protocomm -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/pthread -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/sdmmc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/smartconfig_ack -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/soc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spi_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spiffs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcp_transport -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcpip_adapter -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ulp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/vfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wear_levelling -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wifi_provisioning -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wpa_supplicant -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/xtensa-debug-module -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32-camera -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fb_gfx -I/HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/variants/esp32 /HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPv6Address.cpp
xtensa-esp32-elf-g++ -o .pio/build/esp32dev/FrameworkArduino/MD5Builder.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -Os -g3 -Wall -nostdlib -Wpointer-arith -Wno-error=unused-but-set-variable -Wno-error=unused-variable -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wno-error=deprecated-declarations -Wno-error=unused-function -Wno-unused-parameter -Wno-sign-compare -fstack-protector -fexceptions -Werror=reorder -DPLATFORMIO=40304 -DARDUINO_ESP32_DEV -DESP32 -DESP_PLATFORM -DF_CPU=240000000L -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DARDUINO=10805 -DARDUINO_ARCH_ESP32 -DARDUINO_VARIANT=\"esp32\" "-DARDUINO_BOARD=\"Espressif ESP32 Dev Module\"" -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/config -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_trace -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_update -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/asio -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bootloader_support -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/coap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/console -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/driver -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-tls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_adc_cal -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_event -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_client -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_server -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_https_ota -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_ringbuf -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ethernet -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/expat -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fatfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freemodbus -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freertos -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/heap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/idf_test -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/jsmn -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/json -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/libsodium -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/log -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/lwip -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mbedtls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mdns -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/micro-ecc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mqtt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/newlib -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nghttp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nvs_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/openssl -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protobuf-c -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protocomm -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/pthread -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/sdmmc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/smartconfig_ack -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/soc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spi_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spiffs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcp_transport -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcpip_adapter -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ulp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/vfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wear_levelling -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wifi_provisioning -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wpa_supplicant -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/xtensa-debug-module -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32-camera -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fb_gfx -I/HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/variants/esp32 /HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32/MD5Builder.cpp
xtensa-esp32-elf-g++ -o .pio/build/esp32dev/FrameworkArduino/Print.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -Os -g3 -Wall -nostdlib -Wpointer-arith -Wno-error=unused-but-set-variable -Wno-error=unused-variable -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wno-error=deprecated-declarations -Wno-error=unused-function -Wno-unused-parameter -Wno-sign-compare -fstack-protector -fexceptions -Werror=reorder -DPLATFORMIO=40304 -DARDUINO_ESP32_DEV -DESP32 -DESP_PLATFORM -DF_CPU=240000000L -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DARDUINO=10805 -DARDUINO_ARCH_ESP32 -DARDUINO_VARIANT=\"esp32\" "-DARDUINO_BOARD=\"Espressif ESP32 Dev Module\"" -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/config -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_trace -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_update -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/asio -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bootloader_support -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/coap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/console -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/driver -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-tls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_adc_cal -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_event -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_client -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_server -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_https_ota -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_ringbuf -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ethernet -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/expat -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fatfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freemodbus -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freertos -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/heap -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/idf_test -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/jsmn -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/json -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/libsodium -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/log -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/lwip -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mbedtls -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mdns -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/micro-ecc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mqtt -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/newlib -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nghttp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nvs_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/openssl -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protobuf-c -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protocomm -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/pthread -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/sdmmc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/smartconfig_ack -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/soc -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spi_flash -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spiffs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcp_transport -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcpip_adapter -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ulp -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/vfs -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wear_levelling -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wifi_provisioning -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wpa_supplicant -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/xtensa-debug-module -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32-camera -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-face -I/HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fb_gfx -I/HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32 -I/HOME/.platformio/packages/framework-arduinoespressif32/variants/esp32 /HOME/.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.cpp
as: Unbekannte Option »--longcalls«
After here same error mention in first post.
The invocation doesn’t differ from my computer. I also see xtensa-esp32-elf-g++ being invoked with -mlongcalls and it throws no error.
Is PlatformIO and the platform + packages up to date (pio platform update, pio upgrade --dev)?
What’s the package information at the start of compilation? Example:
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/firebeetle32.html
PLATFORM: Espressif 32 1.12.4 > FireBeetle-ESP32
Found 30 compatible libraries
Do you have manual installs of xtensa-esp32-elf-g++? Do you have special configs in place for overriding CC or AS environment variabes?
Hi here is the startpart:
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 1.12.4 > Espressif ESP32 Dev Module
  • framework-arduinoespressif32 3.10004.200129 (1.0.4)
  • tool-esptoolpy 1.20600.0 (2.6.0)
  • toolchain-xtensa32 2.50200.80 (5.2.0)
    Found 33 compatible libraries
    Scanning dependencies…
I don not have any special installations or configs and don not have installed xtensa-esp32… my self. I Only installed VSCode and after i got errors here i installed core and try it on the bash.
pio update →
latform Atmel AVR
Updating atmelavr @ 2.2.0 [Up-to-date]
Updating toolchain-atmelavr @ 1.50400.190710 [Up-to-date]
Platform Espressif 32
Updating espressif32 @ 1.12.4 [Up-to-date]
Updating toolchain-xtensa32 @ 2.50200.80 [Up-to-date]
Updating framework-arduinoespressif32 @ 3.10004.200129 [Up-to-date]
Updating tool-esptoolpy @ 1.20600.0 [Up-to-date]
Updating tool-openocd-esp32 @ 1.1000.20190708[Up-to-date]
Updating tool-mkspiffs @ 2.230.0 [Up-to-date]
Platform Espressif 8266
Updating espressif8266 @ 2.5.3 [Up-to-date]
Updating toolchain-xtensa @ 2.40802.200502 [Up-to-date]
Updating framework-arduinoespressif8266 @ 3.20701.0 [Up-to-date]
Updating tool-esptool @ 1.413.0 [Up-to-date]
Updating tool-esptoolpy @ 1.20800.0 [Up-to-date]
Updating espressif8266 @ 1.5.0 [Detached]
Updating framework-arduinoespressif8266 @ 1.20300.1 [Up-to-date]
Updating tool-esptool @ 1.409.0 [Up-to-date]
Platform NXP Arduino LPC176x
Updating nxplpc-arduino-lpc176x @ 0.1.1 [Detached]
Updating toolchain-gccarmnoneeabi @ 1.90201.191206 [Up-to-date]
Updating framework-arduino-lpc176x @ 0.2.4 [Up-to-date]
after update and upgrade i got the same error :frowning:
Both this Espressif post and this github comment indicate that this is a system-level configuration error regarding the toolchain.
Does which xtensa-esp32-elf-g++ (or where) return anything in a normal shell? :sweat_smile:
Both return not found
xtensa-esp32-elf-g++ not found
where xtensa-esp32-elf-g++
It’s hard for me to reprocue this with such a customized build as Arch Linux. Running on Ubuntu 20.04 LTS gives no problems at all
max@max-VirtualBox:~/esp$ pio run
Found 26 compatible libraries
Archiving .pio/build/esp32dev/libFrameworkArduinoVariant.a
Indexing .pio/build/esp32dev/libFrameworkArduinoVariant.a
Compiling .pio/build/esp32dev/FrameworkArduino/Stream.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/StreamString.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/WMath.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/WString.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/base64.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/cbuf.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-adc.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-bt.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-cpu.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-dac.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-gpio.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-i2c.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-ledc.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-matrix.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-misc.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-psram.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-rmt.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-spi.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-time.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-timer.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-touch.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/esp32-hal-uart.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/libb64/cdecode.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/libb64/cencode.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/main.cpp.o
Compiling .pio/build/esp32dev/FrameworkArduino/stdlib_noniso.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/wiring_pulse.c.o
Compiling .pio/build/esp32dev/FrameworkArduino/wiring_shift.c.o
Archiving .pio/build/esp32dev/libFrameworkArduino.a
Indexing .pio/build/esp32dev/libFrameworkArduino.a
Linking .pio/build/esp32dev/firmware.elf
Retrieving maximum program size .pio/build/esp32dev/firmware.elf
Building .pio/build/esp32dev/firmware.bin
Checking size .pio/build/esp32dev/firmware.elf
RAM:   [          ]   4.5% (used 14700 bytes from 327680 bytes)
Flash: [==        ]  16.0% (used 209791 bytes from 1310720 bytes)
esptool.py v2.6
=========================================== [SUCCESS] Took 4.28 seconds ===========================================
I can try Manjaro which should be closer to Arch, but I doubt there’ll be problems in the official install.
And again a successful compilation on a default Manjaro XFCE 20.0.3 installation. A Linux distro based on Arch shouldn’t be the problem here.
[max@max-virtualbox esp]$ uname -a
Linux max-virtualbox 5.6.16-1-MANJARO #1 SMP PREEMPT Wed Jun 3 14:26:28 UTC 2020 x86_64 GNU/Linux
[max@max-virtualbox esp]$ pio run
PlatformManager: Installing espressif32
espressif32 @ 1.12.4 has been successfully installed!
The platform 'espressif32' has been successfully installed!
The rest of packages will be installed automatically depending on your build environment.
PackageManager: Installing toolchain-xtensa32 @ ~2.50200.0
Downloading  [####################################]  100%
Unpacking  [####################################]  100%
toolchain-xtensa32 @ 2.50200.80 has been successfully installed!
PackageManager: Installing framework-arduinoespressif32 @ ~3.10004.191002
framework-arduinoespressif32 @ 3.10004.200129 has been successfully installed!
PackageManager: Installing tool-esptoolpy @ ~1.20600.0
tool-esptoolpy @ 1.20600.0 has been successfully installed!
CorePackageManager: Installing tool-scons @ ~3.30102.0
tool-scons @ 3.30102.0 has been successfully installed!
esptool.py v2.6
================================================ [SUCCESS] Took 45.70 seconds ================================================
BIG THX for your research.
I will try to reinstall VSCode and Platformio. Hope that will help.
Don’t forget to complete delete the ~/.platformio folder after uninstalling PlatformIO – forces a redownload of the framework and compiler.
OK looks like it was a F*up with the installation … :frowning: Sorry.
Prev i do not have delete the .Platformio Folder .
No a empty project compiles :slight_smile:
Got now some error that the Lib will not be found that I am using . But that is not a problem for this place :wink:
