So I have been stuck for a few days here, mind you this is my first board programming with platformIO but I have gone through everything I can think of. I keep getting this error when trying to upload my Marlin config to a BIGTREE TECH SKR 1.3 board:
Unable to find destination disk (a bytes-like object is required, not ‘str’)
Please select it in platformio.ini using the upload_port keyword (Redirecting...) or copy the firmware (.pio/build/LPC1768/firmware.bin) manually to the appropriate disk
Looking for upload disk…
Error: Please specify upload_port for environment or use global --upload-port option.
The IDE is detecting the board as you can see here
Here are the relevant parts of the .ini file.
[platformio]
src_dir = Marlin
build_dir = .pioenvs
lib_dir = .plotlib
libdeps_dir = .piolibdeps
boards_dir = buildroot/share/PlatformIO/boards
default_envs = LPC1768
# NXP LPC176x ARM Cortex-M3
[env:LPC1768]
platform = https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/master.zip
# I added upload_port =COM[9] after autodetect failed to work
upload_port = COM[9]
board = nxp_lpc1768
build_flags = -DTARGET_LPC1768 -DU8G_HAL_LINKS -IMarlin/src/HAL/HAL_LPC1768/include -IMarlin/src/HAL/HAL_LPC1768/u8g ${common.build_flags}
# debug options for backtrace
# -funwind-tables
# -mpoke-function-name
lib_ldf_mode = off
lib_compat_mode = strict
extra_scripts = Marlin/src/HAL/HAL_LPC1768/upload_extra_script.py
src_filter = ${common.default_src_filter} +<src/HAL/HAL_LPC1768>
monitor_speed = 250000
lib_deps = Servo
LiquidCrystal
U8glib-HAL=https://github.com/MarlinFirmware/U8glib-HAL/archive/bugfix.zip
TMCStepper@<1.0.0
Adafruit NeoPixel=https://github.com/p3p/Adafruit_NeoPixel/archive/master.zip
SailfishLCD=https://github.com/mikeshub/SailfishLCD/archive/master.zip
