We are trying to burn a bootloader to a custom ATMega4809 board over serialUPDI. We are following the .ini template provided by MegaCoreX, with adjustments to fit our board specifications
board_build.f_cpu = 4000000L
board_build.variant = 40pin-standard
upload_port = COM3
board_hardware.uart = uart0
Running code
pio run -e fuses_bootloader -t bootloader -v
Produces the error
avrdude: 1 byte of lock verified
avrdude: leaving NVM programming mode
avrdude serialupdi_close() warning: releasing DTR/RTS handshake lines
avrdude done. Thank you.
avrdude -p atmega4809 -C C:\Users\rn71\.platformio\packages\tool-avrdude\avrdude.conf -P usb -c serialupdi -xrtsdtr=high -U flash:w:C:\Users\rn71\.platformio\packages\framework-arduino-megaavr-megacorex\bootloaders\optiboot\bootloaders\mega0\115200\Optiboot_mega0_UART0_DEF_115200_A7.hex:i
avrdude error: cannot open port usb: The system cannot find the file specified.
avrdude error: unable to open programmer serialupdi on port usb
*** [bootloader] Error 1
================================================= [FAILED] Took 3.65 seconds ===========================================
Upload_UPDI IGNORED
Upload_UART IGNORED
fuses_bootloader FAILED 00:00:03.647
============================================ 1 failed, 0 succeeded in 00:00:03.647 ============================================
Does anyone know what we may be doing wrong? Thanks in advance!
